I am facing an issue while installing Maple on my Intel Evo laptop. The installation process starts but then it fails and I get an error message. I have tried to install it multiple times but the issue persists. I have also checked for any updates or patches but there are none available.I am not sure what could be causing this issue. Has anyone else faced a similar problem? If so, could you please share your experience and any solutions that worked for you? I would appreciate any help or suggestions on how to resolve this issue.
Thank you in advance for your time and assistance.
Is there any simple way that the colored shape created in the xy plane by the uploaded code can be projected in the z direction onto the surface of the unit sphere centred at the origin?
Projection.mw
I am now using maplesim to do research on railway vehicles. When I replace the rails with flexible beams in maplesim, I try to connect the rails and two sleepers with moving pairs, and I find that there are over-constraint problems. How to replace the rails with flexible bodies? Are the rails connected with multiple sleepers?
I hope you can give me some advice, thank you very much.
Let us begin with the official descriptions of loops. The Maple® documentation claims that:
Note that the examples above don't necessarily illustrate the best way to perform these operations. Often a functional form like seq, map, add, or mul is far more efficient.
Mma's tech tutorial also claims that:
If you have a big program full of If, Do, Return, etc., you're probably not doing things right.
Often, however, you can make more elegant and efficient programs using the functional programming constructs ….
Also, MatLab's Techniques to Improve Performance and Measure and Improve GPU Performance claims that:
You can achieve better performance by rewriting loops to make use of higher-dimensional operations. The performance of a wide variety of element-wise functions can be improved … instead of looping over the matrices.
Well, I'm confused. Why did the official help page say like this? Actually, I find that lots of users in this forum still (and usually) use traditional for-loops instead of something which fits in with the alleged functional programming ideas. Did I misconstrue those statements?
(For instance, as for the functional operations, it's unfortunate that Maple's built-in map cannot operate on arbitrary expression trees of any depth; so I have to use the loops to apply some procedure indirectly, which is not so convenient. In my opinion, owing to such limitation, people have to, and then gradually tend to, use the loops.)
Good day!
I attempted to download the geocoding package for Maple and I cannot get it to work. Executing the worksheet produces no results.
I am using Maple 2022.
Can anyone shed some light on this please?
Thanks for reading ..
https://maple.cloud/app/5769608062566400/Google+Maps+and+Geocoding?activeGroup=MathApps
How to use collect() or coeffs() on random variables instead of standard variables?
I need to re-organize a linear combination of RVs nu[1], nu[2], u[1], u[2], u[3] by collecting the coefficients on each of these 5 RVs. Note that the Xs are correlated with each other and the Ys are correlated with each other (but Xs and Ys are uncorrelated).
For example, nu is a 2D gaussian vector where nu[1] and nu[2] are defined in terms of _R1, _R2, means, standard deviations and correlation coefficient. They are quite "nested" and the 3D gaussian vector u is even worse, so when these enter a linear combination it becomes hard to identify them back as simply nu[1], nu[2], u[1], u[2], u[3].
Is there a way to "isolate" them in a linear combination by using collect()-like or coeffs()-like functions (i) directly on the RVs or (ii) indireclty on the explicit expressions of _Rs, means, standard devs, correlation coeffs?
(I already checked the answers to these two somewhat similar questions but did not help for my case:
https://mapleprimes.com/questions/235215-Reduce-Length-Of-Sum-Of-Products
https://mapleprimes.com/questions/234292-Re-How-To-Collect-Using-A-Term-By-Multiplication
See my script below:
For example, I would want collect() on nu[1] (or equivalently on _R1*sigma__v[1]+nu__0[1]) to give me X__1+X__3 (as you easily see from my definition of Omega).
# 2.2.1 Define the Omega random variable as Omega__1+Omega__2+Omega__3:
`Ω__1` := X__1*(nu[1]-`μ__1`-`λ__1`*(u[1]+X__1)); `Ω__2` := X__2*(nu[2]-`μ__2`-`λ__2`*(u[2]+X__2)); `Ω__3` := X__3*(nu[1]+nu[2]-`μ__3`-`λ__3`*(u[3]+X__3)); Omega := `Ω__1`+`Ω__2`+`Ω__3`
X__1*(sigma__v[1]*_R1+nu__0[1]-mu__1-lambda__1*(_R3*sigma__u[1]+X__1))+X__2*(sigma__v[2]*rho__v[1, 2]*_R1+(-rho__v[1, 2]^2+1)^(1/2)*sigma__v[2]*_R2+nu__0[2]-mu__2-lambda__2*(rho__u[1, 2]*sigma__u[2]*_R3+(-rho__u[1, 2]^2+1)^(1/2)*sigma__u[2]*_R4+X__2))+X__3*(sigma__v[1]*_R1+nu__0[1]+sigma__v[2]*rho__v[1, 2]*_R1+(-rho__v[1, 2]^2+1)^(1/2)*sigma__v[2]*_R2+nu__0[2]-mu__3-lambda__3*(rho__u[1, 3]*sigma__u[3]*_R3-sigma__u[3]*(rho__u[1, 2]*rho__u[1, 3]-rho__u[2, 3])*_R4/(-rho__u[1, 2]^2+1)^(1/2)+((-2*rho__u[1, 2]*rho__u[1, 3]*rho__u[2, 3]+rho__u[1, 2]^2+rho__u[1, 3]^2+rho__u[2, 3]^2-1)/(rho__u[1, 2]^2-1))^(1/2)*sigma__u[3]*_R5+X__3))
# 2.2.2 Simplify and re-arrange the Omega RV to obtain the easy-to-read version (a,b,c,d,e,f are the coefficients):
#Omega__* = a + b*nu[1] + c*nu[2] + d*u[1] + e*u[2] + f*u[3];
# How to do it? Collect() does not work...simplify() doesn't make it any easier...
`Ω__*` := collect(Omega, [_R1*`σ__v`[1]+`ν__0`[1], `σ__v`[2]*`ρ__v`[1, 2]*_R1+sqrt(-`ρ__v`[1, 2]^2+1)*`σ__v`[2]*_R2+`ν__0`[2], `σ__u`[1]*_R3, `σ__u`[2]*`ρ__u`[1, 2]*_R3+sqrt(-`ρ__u`[1, 2]^2+1)*`σ__u`[2]*_R4, `σ__u`[3]*`ρ__u`[1, 3]*_R3-`σ__u`[3]*(`ρ__u`[1, 2]*`ρ__u`[1, 3]-`ρ__u`[2, 3])*_R4/sqrt(-`ρ__u`[1, 2]^2+1)+sqrt((-2*`ρ__u`[1, 2]*`ρ__u`[1, 3]*`ρ__u`[2, 3]+`ρ__u`[1, 2]^2+`ρ__u`[1, 3]^2+`ρ__u`[2, 3]^2-1)/(`ρ__u`[1, 2]^2-1))*`σ__u`[3]*_R5])
Error, (in collect) cannot collect _R1*sigma__v[1]+nu__0[1]
`Ω__col` := collect(Omega, [nu[1], nu[2], u[1], u[2], u[3]])
Download collect.mw
Is there a mathematical reason why Maple does not allow expansion point for solving an ode using series solution to be different than where initial conditions are located?
I do not see why this restriction is there. Here is first order ode, where expansion point is x=1 and initial condiitons are also at x=1
ode:=diff(y(x),x)=x^3;
dsolve([ode,y(1)=1],y(x),'series',x=1)
            y(x) = (1 + (x - 1)) + 3/2*(x - 1)^2 + (x - 1)^3 + 1/4*(x - 1)^4 + O((x - 1)^6)
No problem. But when expansion point at x=0, it complains
dsolve([ode,y(1)=1],y(x),'series',x=0)
Error, (in dsolve/SERIES) conflicting specifications of the series expansion point: 1 v.s. 0
I know help mentions that it uses initial conditions point for expansion if given, and if no IC is given, then it uses x=point if given and if no x=point is given then it default to x=0.
But my question is, why it does not handle the case when the expansion point is given explicitly and is at a different location than where IC are given? Is this simply just a feature missing that could be added in a future release if needed, or is it due to some mathematical reason that I do not see?
I would have expected it to first find the series solution around the given expansion point, then use the IC to determine the unknown constant after that, just like we normally do when solving an ode using standard methods not using series expansion.
I am using Maple 2023
S := t -> tanh(ln(1 + t^2))
diff(S(t), t $ n)=1/GAMMA(1-n)-1/4*pochhammer(-n,n)*Sum(_alpha^3*(t-_alpha)^(-1-n),_alpha =RootOf(_Z^4+2*_Z^2+2))
why the root of? its easy to see the roots are given by
solve(_Z^4 + 2*_Z^2 + 2 = 0);
(-1-I)^(1/2), -(-1-I)^(1/2), (-1+I)^(1/2), -(-1+I)^(1/2)
its equivalent to the roots of (z^2 + 1)^2 + 1
it seems very weird that maple stops here rather than turning it into a 4-element array
I read the article "ONEOptimal: A Maple Package for Generating One-Dimensional Optimal System of Finite Dimensional Lie Algebra", and also searched out in Maplesoft website, but couldn't found. Does anyone have the package?
designing  a block definition diagram for a smart pet feeder
I am trying to see if there is a way to submit maple code as a worksheet and get results back as worksheets in a cluster.
The following 2D integrals of 0 are seemingly trivial and one would expect them to evaluate to zero, but Maple evaluates them to undefined
int(0, x=0..infinity, y=0..1) # undefined
int(0, x=0..1, y=0..infinity) # undefined
When the 2D integral is split into two 1D integrals, it does evaluate to zero, as the following examples show
int(0,x=0..infinity) # 0
int(int(0,x=0..infinity), y=0..1) # 0
int(int(0,x=0..1),y=0..infinity) # 0
If infinity is replaced by a variable (say 'c'), the first two integrals are also evaluated to zero.
It may be connected by the following
int(a, x=0..infinity, y=0..1) # a*infinity
int(a, x=0..1, y=0..infinity) # a*infinity
int(a,x=0..infinity) # signum(a)*infinity
So for the 1D integrals the signum is applied to 'a' when the interval is infinite, but not for the 2D integrals. I'm not sure about this difference.
if i solved two integral seperately..it solved.. but i can't solve together..what's wrong...please help
"al_eq:=`D__11`*(∫)[0]^(a)((ⅆ)^2)/((ⅆ)^( )x^2) A*((ⅆ)^2)/((ⅆ)^( )x^2) A ⅆx (∫)[0]^(b)B*B ⅆy;"
Error, invalid product/quotient
"al_eq:=`D__11`*(∫)[0]^a((ⅆ)^2)/((ⅆx)^2) A*((ⅆ)^2)/((ⅆx)^2) A ⅆx (∫)[0]^bB*B ⅆy;"
B^2*b
Download 2.mw
i want to sovle this problem ..but i dont' know how to start..please help me.how to solve this eqution?
Hey Guys in the attached file below, how can i create a spatial motion (3 traditional + (1 rotational) )? i keep getting errors when i use both for my Rigid body frame. I just have to activate one of the Translational or Rotational block at same time , is there any solution here
Spatial_Motion2.msim
First 253 254 255 256 257 258 259 Last Page 255 of 2472
