t is removed from gamma(t)
sqrt(1+(cos(alpha(t))^2-1)*cos(gamma(t))^2)
(1+(cos(alpha(t))^2-1)*cos(gamma(t))^2)^(1/2)
simplify((1+(cos(alpha(t))^2-1)*cos(gamma(t))^2)^(1/2))
(cos(alpha(t))^2*cos(gamma)^2-cos(gamma)^2+1)^(1/2)
lprint((1+(cos(alpha(t))^2-1)*cos(gamma(t))^2)^(1/2))
subs(gamma(t) = gamma(t), (1+(cos(alpha(t))^2-1)*cos(gamma(t))^2)^(1/2))
(1+(cos(alpha(t))^2-1)*cos(`γ`(t))^2)^(1/2)
simplify((1+(cos(alpha(t))^2-1)*cos(`γ`(t))^2)^(1/2))
(cos(`γ`(t))^2*cos(alpha(t))^2-cos(`γ`(t))^2+1)^(1/2)
lprint((1+(cos(alpha(t))^2-1)*cos(`γ`(t))^2)^(1/2))
Download arg_removed.mw
If i matrix of order
m1 cross n1
other of order
m2 cross n2
and say n1 >n2
The function change(A,B) and make the matrices of order m1 cross n1 and m2 cross n1 by appending zero columns to the other where n2 is the smaller one to make it n1=n2
Download a.mw
The question is in the picture.
y(x) is the result of the last calculation. How do I apply diff to the last result?
Can pacemaker and corosync work with maple?
How to setup pacemaker and Corosync to maple work in Amazon EC2?
i had only one installed License in linux
how to make it work in clusters ?
what is the difference with supercomputing in Amazon ?
which consulting company in Hong Kong can help to use supercomputing in Amazon in my case ? I would like to run batch of batch total 100 script running maple in one instance , but total numbers need to run around 60 years. Any consultant to calculate and setup this supercomputing or pacemaker to make calculations into one day or a few days ?
Suppose their are two matrices A and B say
A has dimension  n1   rows  and m columns
B has dimension n2 rows and m columns
I need to find if any two rows of A are same as that of B  or not
How many are same.
If they are same in some rows which row of A is same as which row of B
Function     checkrowsuniquie(A,B)
I want the resulting shape of the 3D matrix M (ٍExcel file) to be placed in below grids codes.
The range of x and y is between 0 and 1 and the range of z is 1/1 e-4 to 1/1 e-10.
PlotTest.xlsx
grids := proc (M, x_min, x_max, y_min, y_max) local z_min, z_max, plot_f, xz, yz, xy; z_min := 0.11e-6; z_max := 0.1e-2; plot_f := plot3d(M, x = x_min .. x_max, y = y_min .. y_max); xz := plot3d([x, y_min, z], x = x_min .. x_max, z = z_min .. z_max, style = line, color = blue, thickness = 0, grid = [6, 6]); yz := plot3d([x_min, y, z], y = y_min .. y_max, z = z_min .. z_max, style = line, color = blue, thickness = 0, grid = [6, 6]); xy := plot3d([x, y, z_min], x = x_min .. x_max, y = y_min .. y_max, style = line, color = blue, thickness = 0, grid = [6, 6]); return plots:-display(plot_f, xz, yz, xy, lightmodel = none, tickmarks = [6, 6, 6], labels = [x, y, "Error"], labeldirections = [horizontal, horizontal, vertical], axes = frame, orientation = [45, 70, 0], view = 0.11e-6 .. 0.1e-2) end proc
grids(M, 0, 1, 0, 1)
Warning, expecting only range variables [x, y] in expression M to be plotted but found name M
Download eeeeeee.mw
I would like to simplify the expression a*f(x)=0 with a>0.
It is expected to give f(x)=0, but maple still returns a*f(x)=0
I have tried this
assume(a>0)
simplify(a*f(x)=0)
It gives
a~ f(x)=0, not f(x)=0
Dear Mapler
I want to find all real and complex solutions to the following equation. then calculate the omega based on these values and finally select the present the omega with the smallest imaginary part.
with(SignalProcessing):
n:=8;
kk:=FFT(GenerateJaehne(n,1));
#params:= [p,    s, nu,   rho, h,    sigma, C1[1], C1[2], C2[1], C2[2], k1,  k2,  m1[1], m1[2], m2[1], m2[2] ]
 params:= [1e-7, 0, 1e-6, 1e3, 1e-2, 0,     5e-4,  5e-4,  5e-4,  5e-4,  1.4, 1.4, 1+I,   1+I,   1-I,   1-I   ]:
for i from 1 to n do
    x:=kk[i]:
    mm[i]:=[solve(
             eval(
                  ( (x*h)*( (y*h)*sinh((x*h))*cosh((y*h))-(x*h)*cosh((x*h))*sinh((y*h)))*(1+s*(x*h)^2)
                    +p*(-4*(x*h)^2*(y*h)*((x*h)^2+(y*h)^2)+(y*h)*((y*h)^4+2*(x*h)^2*(y*h)^2+5*(x*h)^4)*cosh((x*h))*cosh((y*h))
                    -(x*h)*((y*h)^4+6*(x*h)^2*(y*h)^2+(x*h)^4)*sinh((x*h))*sinh((y*h))))
                  /((x*h)^2*(y*h)*cosh((y*h)))
                 , [p=params[1], s=params[2], h=params[5] ]), y
            , AllSolutions=true)]:
    print(kk[i]);
    print(mm[i]);
    for j from 1 to nops(mm[i]) do
        omega[i][j]:=eval(-I*nu*((x*h)^2-mm[i][j]^2), [nu=params[3],h=params[5]]);
        print(omega[i][j]);
    print(`======`);
Given two terms in expression of type  `+` where the first is rational and the second is not, I wanted to combine both under on common denominator to obtain one term (not `+` any more).
I expected that combine will do that.
expr:=A/B+C;
combine(expr);
But the above leaves the original expression as is. Ofcourse I can just do
numer(expr)/denom(expr);
Here is screen shot
My question is why combine does not do that automatically? For reference, Mathematica command Together is the equivalent to Maple combine and this is what it does
Which is what one would expect to happen.
I am just trying to understand the logic why Maple's combine did not work as one would expect. That is all. I looked at help and tried different option to combine, but non worked.
Is there  a specific type name for vectors in Physics[Vectors]?  Specifically, Let's say we want to write a proc whose argument is expected to be a (Physics) Vector, as in  these (trivial) demos:
with(Physics[Vectors]);
f := proc(a_::???)
    return a_ . a_;
g := proc(a_::???, b_::???)
    return a_ &x b_;
What do we put in place of "???".
I want to create and modify the same worksheet at different times on two different computers in two different locations.
To avoid transferring files between the two machines, it seems most convenient to reference all objects within Maple cloud.
I am a beginner at this and have several questions:
1) I have downloaded the DirectSearch package as directed in help text but the only result from issuing the command kernelopts(toolboxdir) is " ".
How can I establish a path which enables my worksheet to execute commands within this package?
2) How can my worksheet invoke procedures within my .mla file referencing only objects in Maple cloud?
 How can I update (save and delete procedures) within my .mla file?
Maple knows how to obtain differntials using D.
So typing  D(x*y) it gives   D(x)*y+x*D(y)
But what I want is given as input  D(x)*y+x*D(y) have Maple return back D(x*y)
Nothing I tried work. I tried simplify and convert(...,D)
I am looking for a function that takes an expression with differentials like the above output, and return, if possible ONE differnetial in the form  D(  f(x,y) )
What I mean, given as INPUT any of these expressions on the RHS in the image below
To return back  the  D(...)  in the LHS above. I know Maple can do it going from the LHS to the RHS. But I want the other way around.
Does Maple support such operations?
Maple 2022.1
If I have a list say
L:=[1,"2","3",4,5,"6",7,8,9,"10"]
Now i would like to have fuction which takes L as input say    split(L)
and would return two list one with characters from that namely ["2","3","6","10"] and another of integers [1,4,5,7,8,9] like this
The list will have characters and integers only
Kind help it will be acknowleged
Q1: clicking on a variable in the attached I get
What does it mean and how can I fix that when it happens?
Initialisation_diagnostics_error.msim
Q2: Why are initial conditions which are set to "Ignore" listed as "Guess"?
I intend to use the initialization diagnostics to filter a model for components that have initial conditions set. In the attached example (excerpt from a larger model), this does not work the way I want it to (i.e. I don't want P1 to be listed a guess).
Init_diagnostics_ignore_listed_as_guess.msim
Q3: The app seems to be a powerfull tool. Is it explained somewhere how to use the app to debug a model?
Given a diagonal metric of signature (++- -)  for example the diagonal elements are [1,1,-1,-1], then how to find the Dirac gamma matrix in the standard representation or any representation.
First 334 335 336 337 338 339 340 Last Page 336 of 2469
