When pressing !!! (Execute entire worksheet) it seems to me that startup code is executed.
Is that correct, and if - why is that so?
How can I transform the following differential equation from (x,t) to (X,T) coordinate, where, for example, X=x-alpha*t, T=beta*t (alpha and beta are constant)
diff(z, t)+(diff(R, x))*L+A*(diff(L, x))+diff(k, x, x)-(diff(k, t, t)) = 0
D(u(x,t),t,t)=c^2*D(u(x,t),x,x);
Where u(x,0)=f(x),D[2](u)(x,0)=g(x),u(0,t)=0=u(L,t),L=2
please do this as mentioned above
I use Maple 2018 and have following problem:
I define following procedure and want to plot it. However Maple displays the coordinate system but does not plot anything nor gives and error message. Hope you can help.
Murad
b:=proc(n)
local b,i:
 for i from 0 to n do
  if i=0 then
   b[0]:=0:
  elif i=1 then
   b[1]:=1:
   b[i]:=(b[i-1]+b[i-2])/2:
  end if:
return b[n]
plot(b,0..10)
Why was the question and answer deleted for this?
https://www.mapleprimes.com/questions/229329-How-Can-We-Solve-Following-1D-Wave-Equation
proctes.mw
load this Maple code done'nt work!!!
Hi All
I've been trying to plot multiple data sets using the dataplot function but it doesn't seem to work. It just outputs what I've written. I was wondering is there some package I need to run dataplot? Or is there any other way to plot multiple data sets?
I'm using Maple2019.
Here is my code:
with(geometry);
point(o, 0, 0);
point(A, 0, 1);
point(d, 0, 2);
point(F, 0.8944271920, 1.4472135960);
line(lOD, [o, d]);
line(lAF, [A, F]);
alpha := FindAngle(lOD, lAF);
                      alpha := 2.034443936
FindAngle is supposed to return the smaller angle between two lines.
Here it is greater than Pi/2
How can that be ?
Thank you for your advice
Today I Installed  Physics Updates" version "642 in Maple2020, why does it tell me  it has installed but is not active? How to active it?
Physics:-Version(latest)
`The "Physics Updates" version "642" is installed but is not active. The active version of Physics is within the library D:\\Program Files\\Maple 2020\\lib\\maple.mla, created 2020, March 5, 9:36 hours`
diff(u(x,t),t,t)=c^2*diff(u(x,t),x,x);
 Where u(x,0)=f(x),D[2](u)(x,0)=g(x),u(0,t)=0=u(0,1)
I keep getting errors empty sets or only header information using the HTTP or URL package to when trying to download files from here through Maple.
How do I download the csv files from here?
https://github.com/CSSEGISandData/COVID-19/tree/master/csse_covid_19_data/csse_covid_19_time_series
is it possible to solve the attached partial differential equation with zero initial boundary condition?
If not by assuming diff(u(sigma, tau, phi, t), t, t)=0 is there an answer for the equation?
lapla.mw
Is there anyway to animate d'Alemberts wave solution as time goes on?
Suppose I have the initial value problem:
PDE:   utt = uxx
ICS:    u(x,0) = x
            ut(x,0) = f(x)
where f(x) is piecewise defined as:
f(x) = cos(pi*x), -1/2 < x < 1/2               and
             0             otherwise
Hello, I was wondering about the following.
cos(Pi/2^n) can be converted to a radical for each integer n, because cos(Pi/2)=0 is known and successively
cos(x)=sqrt( (1+cos(2x))/2 )
so in principle radical expressions should exist for all integers n. But maple only converts cos(Pi/8) to a radical, but not cos(Pi/16) and higher powers. Is there a simple way without writing an own program to obtain these radical expressions using convert(*,radical)?
Suppose two following Eqs.:
(1) du/dt+d(u*w)/dx=0
(2) dw/dt+wdw/dx=0
I want to expand u(x,t) and w(x,t) in the power series of epsilon
u=u0+epsilon*u1+epsilon^2*u2+…
w=w0+epsilon*w1+epsilon^2*w2+…
and change the variables x,t to X,T as follows
 X=(x-alpha*t) and T=beta*t,
and solving Eqs. (1) and (2) for different order of epsilon (epsilon, epsilon^2, epsilon^3,…) to finding u0,w0,u1,w1,…
How do I do that?
First 598 599 600 601 602 603 604 Last Page 600 of 2459
