When generating gaussian distribution I am getting the following error. Please help. Thank you
GAUSSIAN.mw
Is package SumTools supposed to be a superset of the sum command in Maple? Or is it supposed to be a complementary to it? When should one use SumTools vs. sum?
The help on SumTools says
The SumTools package contains commands that help find closed forms of definite and indefinite sums. The package consists of three commands and three subpackages.
But does not make it clear when to use it vs. sum or what is its relation to sum command.
I am asking because on one example, sum is able to give an answer, while SumTools can't. I have expected the other way, where if sum failed, then one will try SumTools.
sum(1/n*sin(n*x),n=1..infinity) assuming 0<x,x<Pi
SumTools:-IndefiniteSummation(1/n*sin(n*x),n=1..infinity) assuming 0<x, x<Pi
I am trying to solve CVRPSD by integer L shape method. I have some problems.
d=(0, 20,20,25,15,10): Demand
p=(1,1,1/3,1/2,1/4): the probability demand
K=50
1) How to write properly Recourse Policy (Q) in maple (I attached my problem) ? Recourse (Penalty cost) is applied when the demand exceed the vehicle capacity. We know that in CVRPSD, we don't know the demand until vehicle arrive at the node(customer).
(Look at my program)
Hopefully anybody could help me to solve this.
Thank you any way.
Exact_CVRPSD.mw
Hi everyone:
I want to calculate the value of eval(diff(y, x), x = 0.418e-1)-eval(diff(y, x), x = 0.1e-1), how?
y := (1-Heaviside(x-0.10e-1))*(cos(9.0218219*x)-.99533285*sin(9.0218219*x)-.99999991*cosh(9.0218219*x)+.99533285*sinh(9.0218219*x))+(Heaviside(x-0.10e-1)-Heaviside(x-0.418e-1))*(.24369100*cos(7.7520047*x)-.36109859*sin(7.7520047*x)-.23739778*cosh(7.7520047*x)+.19615343*sinh(7.7520047*x))+Heaviside(x-0.418e-1)*(.95680995*cos(9.0218219*x)-.80884870*sin(9.0218219*x)-1.0381918*cosh(9.0218219*x)+1.1704059*sinh(9.0218219*x))
with regards...
Hi there
Can anyone explain the following calculation error? (The task seems quite simple.)
Original - very unintuitive calculation error:
Vector(3, {(1) = 20.09230769, (2) = 32.43076923, (3) = 15.26153846}) = Vector[column](%id = 18446746432715486622)NULL
In 1D math it works:
Vector[column](3, [1306./65, 2108./65, 992./65]);
Approximate works:
Vector(3, {(1) = 1306/65, (2) = 2108/65, (3) = 992/65})"(->)"Vector[column](%id = 18446746432750076862)
Multiplying by 1. works:
Vector(3, {(1) = 20.09230769, (2) = 32.43076923, (3) = 15.26153846}) = Vector[column](%id = 18446746432750171550)NULL
Download Maple_-_vector_of_fractions_with_floats.mw
Kind regards,
Jens Jacob Thomsen
how to submit maple job through command line. Thank you.
This should be simple but I am missing something. I want to sum the product of combinations of numbers.
I know I can assign values to a0...a[n-1]. But that isn't nice.
(n,k):= (5,4);
add(mul~(combinat:-choose([a(||)[](0..n-1)], k))) ; =a0*a1*a2*a3+a0*a1*a2*a4+a0*a1*a3*a4+a0*a2*a3*a4+a1*a2*a3*a4  which is correct.
add(mul~(combinat:-choose([(0..n-1)], k))) ;   #should be 24 but I get 0
How I can remove this error.
also, i want to find answer via fsolve.
Error, (in fsolve) too many levels of recursion.
test.mw
Ok I am still not further... Lets assume wie have F_q with q=3^2 and the irreducible polynomial T^2+2T+2...
Be tau the alsias(tau=RootOf(T^2+2T+2));
Then I get in Maple the wrong (??) calculation
(tau+1)(2tau+2)= tau+1 \neq 1, which is supposed to be the right answer: =2tau^2+4tau+2=2(tau^2+2tau+2)-2=0-2=1 because our prime number is 3... WHY does Maple not calculate that stuff correctly??
Another problem:
Be f:= x^2+tau*x;
When I enter Rem(x^q,f,x) mod 3 then Maple returns x, whereas I calculate (tau+1)x...
Where is the mistake?
I build my finite field either via firred := T^2+2*T+2; alias(tau = RootOf(firred))
or
G := GF(3, 2); a := G:-extension; aOut := G:-ConvertOut(a); alias(tau = RootOf(aOut))
But both times the calculations are not correct... I dont know why?
Please, can somebody help?
I have another problem and maybe someone can help me.
When I enter the code:
with  alias(tau=RootOf(T^2+2T+2)) ;
then Maple gives me the output false???
Why is it false??
Can someone help me?
How do I tell Maple that for example f:= x^2+tau*x is a Polynom with x=variable, tau= RootOf?
Thank you!!
Some definition of n! where n are the negative integers is taken to be infinity. (this is Gamma function for negative integers).
https://en.wikipedia.org/wiki/Gamma_function
So 1/(-1)!  should be zero. And that is what Mathematica gives
But Maple does not like (-1)!, it gives division by zero, I assume because it is not using the above definition using Gamma function.  But then how come Maple is able to find correctly this sum
sum(1/factorial(n-1),n=0..infinity)
Which is exp(1).   The first term above, when n=0 is   1/(-1)!  which Maple does not like. Because if we take the first term as 1/infinity=0 then the sum is the same as if we had
sum(1/factorial(n-1),n=1..infinity)
And now it is exp(1) with no problem dealing with negative integer factorial.
Question is: Since Maple does not like negative integer factorial, how comes it accepted the above sum, whose first term contain negative integer factorial?
Just wondering how it did the above, that is all. When I solved this by hand, I used 1/(-1)! = 0 to be able to sum it.
Does anyone know of the simplest way to insert  a new line, or carriage return in a Maple Startup Script ?
I am brand new to Maple, so I really don't have a clue what I am doing, but essentially, I would like my new worksheet to start two lines down from the top.  I cannot seem to get the Startup Script to do this.
I have tried several things, and cannot find anything that works.
Any ideas ?
pellsolve := proc (D::posint) local P, Q, a, A, B, i; if type(sqrt(D), integer) then error "D must be a nonsquare integer" end if; P := 0; Q := 1; a := floor(sqrt(D)); A := 1, a; B := 0, 1; for i do P := a*Q-P; Q := (D-P^2)/Q; a := floor((P+sqrt(D))/Q); A := A[2], a*A[2]+A[1]; B := B[2], a*B[2]+B[1]; if Q = 1 and `mod`(i, 2) = 0 then break end if end do; return A[1], B[1] end proc;
pellsolve(107);
                            962, 93
isolve(x^2-107*y = 13);
       /                             2             \
      { x = 21 - 107 _Z1, y = 107 _Z1  - 42 _Z1 + 4 },
         /                             2               \
        { x = 86 - 107 _Z1, y = 107 _Z1  - 172 _Z1 + 69 }
genpellsolve := proc (D::posint, N::integer) local t, u, L1, L2, sols, x, y; if type(sqrt(D), integer) then error "D must be a nonsquare integer" end if; t, u := pellsolve(D); if 0 < N then L1 := 0; L2 := floor(sqrt((1/2)*N*(t-1)/D)) elif N < 0 then L1 := ceil(sqrt(-N/D)); L2 := floor(sqrt(-(1/2)*N*(t+1)/D)) else return {[0, 0]} end if; sols := {}; for y from L1 to L2 do x := sqrt(N+D*y^2); if type(x, integer) then sols := sols union {[x, y]}; if `mod`(x^2+D*y^2, N) <> 0 or `mod`(2*x*y, N) <> 0 then sols := sols union {[-x, y]} end if end if end do; DEBUG(); return sols end proc;
Debug inefficace
I have converted a single large worksheet into a workbook comprising many worksheets.  One of the worksheets contains start-up code.  Is that start-up code (which includes numerous subroutines/functions) automatically available/accessible/executable by all the other worksheets in the workbook?
Melvin
First 761 762 763 764 765 766 767 Last Page 763 of 2464
