Is there any formula in maple to find simplex multipliers vector?
I have this animation that displays a particle's position after reflection from a shock (the blue plane). I want to add a line that shows the particle coming in and reflecting and have them animate sequentially, but I cannot figure out how. The line should travel along the b axis, but offset in the xi axis to end where the helix begins. Here is the code for the helix animation:
restart; with(VectorCalculus); with(Student[LinearAlgebra]); with(plots);
v[i] := 145000; thetabn := (1/8)*Pi; thetavn := (1/6)*Pi; k := 10; omegac := .5;
v[b] := cos(2*thetabn)/cos(thetabn); v[g] := sin(2*thetabn)/cos(thetabn);
n := `<,>`(k*cos(thetabn), k*sin(thetabn), 0);
vr:=
[v[b]*t, v[g]*sin(omegac*t)/omegac, v[g]*cos(omegac*t)/omegac];
lambda := v[i]*cos(thetavn)/cos(thetabn);
shockplot := PlanePlot(n, caption = "", planeoptions = [colour = blue, transparency = .5], normaloptions = [shape = cylindrical_arrow, colour = red]);
t1 := textplot3d([k*cos(thetabn), k*sin(thetabn), 0, 'n'], align = above);
display(plots[animate](plot3d, [[v[b]*t, v[g]*sin(omegac*t)/omegac, v[g]*cos(omegac*t)/omegac], t = 0 .. x], x = 0 .. 6*Pi, axes = normal, colour = red, labels = ["b", zeta, xi], thickness = 2, paraminfo = false), shockplot, t1, scaling = constrained, tickmarks = [0, 0, 0]);
The Question:
'Produce a list of the primes p between 2000 and 3000 for which both 2 and 3 generate Fpx '
I have my code for producing the list of primes between 2000 and 3000:
p:=nextprime(2000):
primes:=[]:
while p<=3000 do
  primes:=[primes[],p];
  p:=nextprime(p);
I also have  code for finding the order of a number in Fpx
findOrderOf:=proc(g,p)
 local gpwr, i;
  gpwr:=1:
for i from 1 to p-1 do
  gpwr:=gpwr*g mod p;
if (gpwr = 1) then:
return i;
end if:
but I don't know how to relate them or how to create the overall code - any advice would be very helpful!!
how to solve ((√1 + y′ ² )/dy')
Hello pdsolve experts:
Using Maple 2018.2.1 and Physics 292 on windows 10.
pde := diff(w(x,y),x)+ (arccot(x)^n *y^2 + y-  arccot(x)^n )*diff(w(x,y),y) = 0;
pdsolve(pde,w(x,y));
When I try
PDEtools:-charstrip(pde,w(x,y))
It does not generate error.
Should pdsolve have generated this error message instead of returning no solution?
I found that when lambda2 take a small value this integration cannot be evaluated by maple is there any command to solve this problem
lambda1 := 0.733e-1; lambda2 := 5.3344; alpha := 4.8492
X[6] := evalf(int((Z^(lambda2/lambda1))^2*ln(Z)^2/((Z-1+alpha)^2*(Z^(lambda2/lambda1)-1+alpha)^3), Z = 1 .. infinity, numeric));
Download ask.mw
Good day everyone,
I have a problem building the code attached below. The series is not substituting F[0](eta) and T[0](eta).
Please, anyone with useful information should contact.
HAM_build.mw
i have a problem to solve this system ?
The program was written in 2004 with maple 6. Now i'am working by maple 18. And i did'nt launch the program. painleve_test.zip
Thank you for your interest in advance.
Hi everybody:
I have 12 equations with 12 unknowns(c(1),c(2),...,c(12) and omega), I want to obtain c(1),c(2),...,c(12) and omega, how can I do it? The Maple file(solve.mw) is attached.
with regards...
solve.mw
Hello my friends
I want to solve first order non-linear differential equation by maple 2018 but it does not give me the explicit form for a(t) as the function of time t.
this is my equation where z,k,c, and w are non zero constants
3*a(t)-a(t)^2-3*z*(diff(a(t), t))^2+k*c*a(t)+w/a(t) = 0
please guide me.
with the best regard
I would like to designate AU as currency for my application, rather than the USD.
I can do it to a degree, but when I use combine I have problems. Compare output 8 and 9 to 17 and 18. help?
CURRENCY.mw
I'm presently interested in PDE and I have just discovered the impressive work Nasser Abbasi,has done, and keeps doing, concerning the solution of PDE benchmarks with Maple and Mathematica.
https://www.12000.org/my_notes/pde_in_CAS/pdse3.htm
It seems that the result Maple returns for the test case below is not the general solution.
  • 4.19 first order PDE of three unknowns
    problem number 19
    (from example 3.5.4, p 212, nonlinear ode’s by Lokenath Debnath, 3rd edition)
It is rather simple to see that any spherical function u(x, y, z) =f(x^2+y^2+z^2) is a solution of the PDE.
Then any function of the form u(x, y, z) = f(x^2+y^2+z^2) * exp(x+y+z) *C1 (C1 being any constant) is also a solution.
Maple returns only the solution u(x, y, z) = exp(C2*(x^2+y^2+z^2)) * exp(x+y+z) * C1
u := (x, y, z) -> f(x^2+y^2+z^2)
proc (x, y, z) options operator, arrow; f(x^2+y^2+z^2) end proc
expr := (y-z)*diff(u(x, y, z), x)+(z-x)*diff(u(x, y, z), y)+(x-y)*diff(u(x, y, z), z)
2*(y-z)*(D(f))(x^2+y^2+z^2)*x+2*(z-x)*(D(f))(x^2+y^2+z^2)*y+2*(x-y)*(D(f))(x^2+y^2+z^2)*z
simplify(%);
u := (x, y, z) -> C*f(x^2+y^2+z^2)*exp(x+y+z)
proc (x, y, z) options operator, arrow; C*f(x^2+y^2+z^2)*exp(x+y+z) end proc
(y-z)*(2*C*(D(f))(x^2+y^2+z^2)*x*exp(x+y+z)+C*f(x^2+y^2+z^2)*exp(x+y+z))+(z-x)*(2*C*(D(f))(x^2+y^2+z^2)*y*exp(x+y+z)+C*f(x^2+y^2+z^2)*exp(x+y+z))+(x-y)*(2*C*(D(f))(x^2+y^2+z^2)*z*exp(x+y+z)+C*f(x^2+y^2+z^2)*exp(x+y+z))
simplify(%);
pdsolve((y-z)*diff(U(x, y, z), x)+(z-x)*diff(U(x, y, z), y)+(x-y)*diff(U(x, y, z), z)=0, U(x,y,z),'build')
U(x, y, z) = exp((1/2)*x^2*_C2)*exp(_C1*x)*exp((1/2)*y^2*_C2)*exp(_C1*y)*_C3*_C5*_C4*exp((1/2)*z^2*_C2)*exp(_C1*z)
combine(rhs(%), exp)
exp((1/2)*x^2*_C2+_C1*x+(1/2)*y^2*_C2+_C1*y+(1/2)*z^2*_C2+_C1*z)*_C3*_C5*_C4
Download Problem_19.mw
I got problem how to rewrite formula in maple, I have tried so many times but it is not working.
How to rewrite sum of double sum like this formula (4th constraints in the following picture)
H := numelems(N); for k from 2 to H do for i to k-1 do cons[k] := add(x[i, k], i = N)+add(x[k, j], N) = 2 end do end do;
                             H := 5
Error, invalid input: add received {1, 2, 3, 4, 5}, which is not valid for its 2nd argument, i
for example, there is an expression exp1=(a+b)*(a+c),  I want to find all the position in DAG of a specific operand, such as 'a' ; also I want to find the position in the DAG of  sub-expression which type is '+' .
 is there any function in maple which can return the  integers indicating position of an operand or type in an expression? i.e. with this function, assume its name is 'find',then
find(exp1, a) will return  [1,1],[2,1];
find(exp1,'+') will return  [1,0],[2,0];
First 762 763 764 765 766 767 768 Last Page 764 of 2464
