How could this be set up in Maplesim?  A vibration signal is imparted on the box and we want to observe the behavior of the sprung object inside the box.
Assume we have the following "intervals" (I am not sure what is its formal name in Maple)
C :=[0,1/11],[1/11,1/9],[1/9, 1/7],[1/3,1/2],[1/2,1]
How can we get the "union" of these intervals? That is to say, obtain  [0,1/7],[1/3,1]
Many thanks in advance for your comments and suggestions.
I'm trying to plot a 3 dimensional vector equation of motion in Maple for my dissertation. The equation is as follows:
vec(vr) = (vb)*i + (vg*cos(Omega*t))*j + (vg*sin(Omega*t))*k
where Omega is the gyrofrequency, vb is the velocity parallel with the i direction, and vg is the perpendicular velocity of gyration. vg and vb are both in terms of the velocity of incidence and two angles, which are all just numerical values that I've introduced.
It should look like a helix spiralling around the i axis, but I'm fairly new to Maple and I've tried everything I can think of and I can't get it to work.
When I use plot3d it turns out looking like a sphere or a cylinder. When I use spacecurve, it doesn't work at all and I get the error message " Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct.".
Any help is greatly appreciated.
I have an ODE. I solved it numerically by Runge Kutta method.
The solution is X(t).
Now, I want to multiply X(t) by sin(y) and to plot in 3D.
How can we do it?
question.mw
I am trying to find the number a and b (-20 < a < 20, -20 < b <20) so that two circles (x+1)^2+(y+3)^2 = 125 and (x-a)^2+(y-b)^2 = 225 cut at two points A and B and coordinates A and B are pairs of integers.
I tried
restart; L := [];
for a from -20 to 20 do
for b from -20 to 20 do
for x from -20 to 20 do
for y from -20 to 20 do
if (x+1)^2+(y+3)^2 = 125 and (x-a)^2+(y-b)^2 = 225 and nops({a, b, x, y}) = 4 and x*y*a*b <> 0 then
L := {op(L), {[a, b], [x, y]}}
od: od: od: od:
nops(L);
L
How to select the number a and b so that the system of equations (x+1)^2+(y+3)^2 = 125  and (x-a)^2+(y-b)^2 = 225 have two integral solutions. For example
solve({(x-6)^2+(y+2)^2 = 225, (x+1)^2+(y+3)^2 = 125}, {x, y})
Digits := 32;
t0 := 1;
eq := 1-w*v^2-2*v*exp(-t/v);
equ := eval(eq, v = -t/ln(u));
us := solve(eval(equ, t = t0), u);
vs := -t0/ln(us);
plot(Re(vs), w = 0 .. 10, view = 0 .. 1)
I want to plot the solution of this equation, but it doesn't quite work. I tried to transform it, because I thought the singularity in the denominator of the exponential causes the issues.
any suggestions?
Dear all.
Trying to plot the function below:
         epsilon
    f := ------- = 0.78417289325174246201875653872811303 + (
          2 Pi
    -24.020590879328464004990474127244023 + Y
      (671.68643760557259657756434855357346 + (
    -314.15926532756339731350799859659950 Y
       - 48.382487297515945228479754993851165)^2))^(1/2)
want the (x-axis) be epsilon/(2*Pi) and the y-axis is Y
implicitplot(f,epsilon=0..100,Y=0..10,numpoints=1000,axes=boxed,thickness=2,color=black,font=[1,1,20],tickmarks=[3, 3],linestyle=1);
many thanks in advanced.
example1 := (x -> (2 + 3));
example2 := (x -> int(1, y));
When I execute these, Maple evaluates the "2 + 3" into 5, but it does not evaluate the "int(1, y)" into "y". Why does it evaluate the former but not the latter?
Also, how can I modifiy example 2 so that it evaluates the "int(1, y)" and returns "x -> y"?
I try to plot this matrix as shown below and I keep getting this error. First how do I simplify these units? Secondly how do I plot this because it seems like it doesn't let plot with units.
Using allvalues (twice) I can uncover the three roots of this expression: 1 real, 2 complex. But fsolve gives me just one real and 1 complex. Interestingly the free version of Woldframalpha.com gives the same single complex root.
Is there any way of coercing fsolve to give both?
Many thanks for any advice
Fsolve5.mw
Examples of the fsolve command: not all complex roots found
expr := exp(x)+sin(x)-2
exp(x)+sin(x)-2
w := solve(expr)
RootOf(_Z-ln(-sin(_Z)+2))
w1 := evalf(allvalues(w))
.4486719164
w2 := allvalues(w)
RootOf(_Z-ln(-sin(_Z)+2), .4486719164), RootOf(_Z-ln(-sin(_Z)+2), 1.837819685+2.792964964*I), RootOf(_Z-ln(-sin(_Z)+2), -4.707337346-1.315656030*I)
q0 := evalf(w2[1])
.4486719164
q1 := evalf(w2[2])
q2 := evalf(w2[3])
eval(expr, x = q0); eval(expr, x = q1); eval(expr, x = q2)
0.
0.1e-8+0.1e-8*I
0.-0.786e-9*I
r1 := fsolve(expr)
.4486719164
r2 := fsolve(expr, complex)
Download Fsolve5.mw
What is the simplest method for adding a color bar for plottings? (a scale that shows the correspondence
between numbers and colors)
and could you interpret the graphics and the color bar?  I need your valuable comments.
I use Maple 2018.
For example;
question.mw
I mean
Hello Everyone,
First of all I want to thank you to pay attention to my post.
For some reasons I want to know when does the root of my solution is equal to 0 isolating α, which yields the following equation
(6*alpha^4*l^2-7*alpha^3*l^2+6*alpha^3*l+2*alpha^2*l^2-6*alpha^2*l+alpha*l+3*alpha-2*sqrt(alpha^3*l^2*(alpha*l-l+1)*(9*alpha^4*l-13*alpha^3*l+9*alpha^3+6*alpha^2*l-12*alpha^2-alpha*l+6*alpha-1))-1)*(-1+2*alpha)/(alpha^2*l-3*alpha+1)^2 = 0
  1/2, -1/l, (1/8)*(3*l+(9*l^2-16*l)^(1/2))/l, -(1/8)*(-3*l+(9*l^2-16*l)^(1/2))/l``
When I substitute 1/2 it verifies the equation, but when I substitute other solutions my equation is not verified. For instance substituting "α=-1/l" I get something different from 0 as you can see
(6*alpha^4*l^2-7*alpha^3*l^2+6*alpha^3*l+2*alpha^2*l^2-6*alpha^2*l+alpha*l+3*alpha-2*sqrt(alpha^3*l^2*(alpha*l-l+1)*(9*alpha^4*l-13*alpha^3*l+9*alpha^3+6*alpha^2*l-12*alpha^2-alpha*l+6*alpha-1))-1)*(2*alpha-1)/(alpha^2*l-3*alpha+1)^2
"(->)"(-2/l-2*(1/l^2)^(1/2))*(-2/l-1)/(4/l+1)^2"(=)"2*((1/l^2)^(1/2)*l+1)*(2+l)/(4+l)^2
My question is what are these "solutions" if they are not solutions ?
I attach the file in case you would take a look at it
Download Maple_question2.mw
This code used to work OK in an earlier version of Maple 2018. I do not know what changed and if it some change in Physics package that caused it.
pde:=diff(u(r,theta),r$2)+1/r*diff(u(r,theta),r)+1/r^2*diff(u(r,theta),theta$2)=0;
bc:=u(r,0)=0,u(r,Pi)=0,u(0,theta)=0,u(1,theta)=f(theta);
sol:=pdsolve([pde,bc],u(r,theta),HINT = boundedseries(r = 0));
Now it gives the error
Error, (in assuming) when calling 'assume'. Received: 'invalid arguments'
Workaround is to remove the HINT above. So the following now works
sol:=pdsolve([pde,bc],u(r,theta));
Should this error message show up when using the HINT option?
Maple 2018.2 with Physics package cloud version 205.
Here is screen shot showing it was working in Physics 170
How can I calculate the Euler-Lagrange equation from the Lagrangian density from Gauged Baby Skyrme model in maple using the physics package? Here, the rules of the operation in the inner space are the same that of the vectors conventional: dot and cross products, etc...
Following below the Lagrangian density.
Errata:
Hello everyone!
Can you help me with my problem?
How can I automatically paste parts of denominator from one equations to another? Now I must do this manualy. Example of my problem is in file2.
File_2.mw
First 788 789 790 791 792 793 794 Last Page 790 of 2464
