I'm doing a Maximum/Minimum problem ( Calculus 3).
I need to plot f(x,y) =   x2  + y 2 -2y + 1
over R={x,y): x 2 + y 2         (less than or equal sign) 4}
When I use Maple solve on functions that involves exp, ln to decide the maxima, minima points by solving derivative equals zero, it only returns the first point, not the second point.
Which by definition it shall return two points, one at 2.030837315, the other around 6.7.
See the Maple code and exported PDF attached.
Maple_Solve_MinMaxma.mw
Maple_Solve_MinMaxma.pdf
Digits:=10;
to 10 do
evalf(add(sin(k), k = 1 .. 10000)) od;
10
1.633891035
1.633891035
1.633891035
1.633891046
1.633891046
1.633891046
1.633891012
1.633891012
1.633891012
1.633891049
restart;   # execute several times to obtain randomness
`Standard Worksheet Interface, Maple 2016.2, Windows 7, January 13 2017 Build ID 1194701`
Digits:=18;
18
to 10 do
1.63389102179246197
1.63389102179246223
1.63389102179246223
1.63389102179246233
1.63389102179246233
1.63389102179246242
1.63389102179246242
1.63389102179246371
1.63389102179246371
1.63389102179246410
Hello i need a tutor to help me with  Numerical analysis on Maple and the programming part. Im In UAE but we can do this online as well
The excel file consists of data (v2, Re, t) and I would like plot the variable "t" aginst the variables "v2" and "Re". Could anyone point me out?
Attached is the excel data.Collapsetime.xlsx
Very kind wishes,
Wang Zhe
Hello, everyone. I have a group project where we have to explain the Josephus problem and use Maple to solve the problem. I am trying to solve the problem in multiple ways (because why not), but I am struggling with my third procedure. I understand the logic behind it and how its supposed to achieve O(k*logn), but the code that I wrote for it doesn't seem to produce the correct result.
JosephusImproved := proc (n, k)
local count, result:
if n = 1 then
return 0:
elif 1 < n < k then
return JosephusImproved(n - 1, k) + k + 1 mod n:
count := floor(n / k):
result := JosephusImproved(n - count, k):
result := result - n mod k:
if result < 0 then
result := result + n
result := floor(result /(k - 1)):
return result:
end if:
end if:
Note: The regular recursive expression [Josephus(n - 1, k) + k + 1 mod n] has a "+ 1" since that was the only way I could make Maple do the calculation correctly. Proven with a Cyclic procedure I already made.
Note 2: I am using Maple 2016 and 2D Math.
I would like some insight as to how I could fix this so that it works, just like the regular recursive procedure and cyclic list that I have.
Cheers.
I am plotting the following function using implicitplot command.:
plots[implicitplot3d]((17.31626331*M^3-(4*(z[1]-z[2])^2*M^2-1.171300684*(z[1]+z[2])^2)*(1.082266457-2*M)*(1.082266457-3*M))^2 = 4.598621420*(z[1]+z[2])^2*M*(1.082266457-2*M)^3*(4*(z[1]-z[2])^2*M^2-1.171300684*(z[1]+z[2])^2), M = 0 .. 1, z[1] = 0 .. 10, z[2] = -10 .. 0);
How can I extract data points from the plot obtained
Ive been trying to plot the following system
With these initial conditions (Also G*M=1)
ics:=[x(0)=1, y(0)=0,vx(0)=0,vy(0)=1];
I use this command to try and do this
with(DEtools):
DEplot(subs({G=1,M=1},satODE1),{x(t),y(t),vx(t),vy(t)},t=-2..2,ics,scene=[x(t),y(t)],scaling=constrained);
But I get this error message
Error, (in DEtools/DEplot/CheckInitial) too few initial conditions: [x(0) = 1]
Which I find odd because I have an initial condition for each variable
Im not sure what makes this different to other DE's Ive plotted other than having more equations in the system
How can I plot a paraboloid?
How can I accelerate the convergence rate of the following series:
I can't get the Real and Imaginary parts of matrix to seperate out as required. It is an SU(2) matrix. Want to convert is to a 4 Vector (quaternion). I think because Maple doesnt know what psi(t) is being conservative so to speak. Tried assume, assuming...
assume*{psi(t), 'real'}
assume*{real, psi(t)}
V := Matrix(2, 2, {(1, 1) = (1/4)*cos((1/2)*psi(t))*sqrt(2)*sqrt(4-2*sech((1/6)*sqrt(3)*t))-I*cos((1/2)*psi(t))*sqrt(2)*tanh((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t))-((1/2)*I)*sin((1/2)*psi(t))*sqrt(2)*sqrt(3)*sech((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t)), (1, 2) = (1/2)*cos((1/2)*psi(t))*sqrt(2)*sqrt(3)*sech((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t))+((1/4)*I)*sin((1/2)*psi(t))*sqrt(2)*sqrt(4-2*sech((1/6)*sqrt(3)*t))-sin((1/2)*psi(t))*sqrt(2)*tanh((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t)), (2, 1) = ((1/4)*I)*sin((1/2)*psi(t))*sqrt(2)*sqrt(4-2*sech((1/6)*sqrt(3)*t))+sin((1/2)*psi(t))*sqrt(2)*tanh((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t))-(1/2)*cos((1/2)*psi(t))*sqrt(2)*sqrt(3)*sech((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t)), (2, 2) = ((1/2)*I)*sin((1/2)*psi(t))*sqrt(2)*sqrt(3)*sech((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t))+(1/4)*cos((1/2)*psi(t))*sqrt(2)*sqrt(4-2*sech((1/6)*sqrt(3)*t))+I*cos((1/2)*psi(t))*sqrt(2)*tanh((1/6)*sqrt(3)*t)/sqrt(4-2*sech((1/6)*sqrt(3)*t))})
Matrix(%id = 18446744074495800014)
v := Vector(4, [Re(V[1, 1]), Im(V[1, 2]), Re(V[2, 1]), Im(V[1, 1])])
Vector[column](%id = 18446744074531387982)
Download extract_R_and_I.mw
Since GramSchmidt does not take Matrix as an input (I wish it did), I would like to know how to normalize a matrix rows. For example if input matrix is:
M = [  1    2]
       [  3    4]
How do I convert it into
Mn = [ 1/sqrt(5)    2/sqrt(5) ]
         [ 3/5            4/5          ]
Each row of matrix Mn has length of 1.
How to get homogenous expressions from symmetric polynomial.
Example. Let P = (a^2 + 2)(b^2 + 2)(c^2 + 2), we have deg(P) = 6. I want to get polynomials of degree n on A[n] with n = 0, 1, ..., 6. Specific
P = a^2b^2c^2 + 2(a^2b^2 + b^2c^2 + c^2a^2) + 4(a^2 + b^2 + c^2) + 8.
And
A[0] = 8
A[1] = 0
A[2] = 4(a^2 + b^2 + c^2)
A[3] = 0
A[4] = 2(a^2b^2 + b^2c^2 + c^2a^2)
A[5] = 0
A[6] = a^2b^2c^2
Thank you very much.
I am not unfamiliar with the Wolfram syntax but also not very good with it, and there is a particular element in a Mathematica code I have been given which I do not entirely understand how to efficiently write in Maple. The basic idea is to read in a list of expressions from an external file (LIST) and process the non zero elements and assign them to a function (COEF) which can be called later on. Here is the Mathematica exert:
k = 0;
i = 0;
a = b = \[Theta];
Do[k = k + 1; KK = LIST[[k]];
  If[KK =!= 0, i = i + 1; ff = Factor[KK];
   COEF[x,y, z, l_, m_, n_] = ff], {z, -2,
   2}, {y, -2, 2}, {x, -2, 2}];
The LIST has the following form and only contains l, m and n and another factor E which is left undefined for now. It does not contain x, y or z. The LIST can contain any number of terms depending on the problem. Here is an example:
LIST={0, 0, 0, 0, 0, 0, 0, a^2 b m (-1 + n) n (a^2 + b^2 - 2 E), ... ,0,0, a^3 n(l+1+m) ... }
So the Do loop cycles through the LIST and extracts out the non zero terms. What I am unsure about is how it is looping over x,y and z when they do not appear in the LIST at all. I assume it is attaching a x,y,z combination to each COEF and they can be called like this:
COEF[0,1,1,0,2,3]
For the instance of when x=0, y=1, z=1, l=0, m=2 n=3. Is this correct? What would be the best way to replicate this in Maple?
- Yeti
This question concerns the package GraphTheory
( Maple 2015 on a Windows 7 PC )
Let G1 be some graph and V a list of vertices in G1
The default colors DrawGraph uses for the vertices is yellow
I define the graph G2 this way :
    G2 := copy(G1):
    HighlightVertex(G2, V, red);
    DrawGraph(G2);
Obviously the result is a graph where vertices in V are red while the remaining ones are still yellow
Question 1 :  Why does the command DrawGraph(G1) returns exactly the same picture ?
I have thought that defining G2 as a copy of G1 would have preserved the default colouring of the vertices.
Note that the same undesired (at least for me) thing occurs with the  HighlightEdges command.
Question 2 : Is it possible to retrieve the original colouring of G1 without using HighlightVertex(G1, V, yellow)  ?
Thank you in advance
First 1031 1032 1033 1034 1035 1036 1037 Last Page 1033 of 2462
