Dragilev:=proc(Polynomials::depends(list(ratpoly(integer,Variables))),Variables::list(symbol),DEvar::symbol,DEsuffix::string)
The above procedure parameter Polynomials accepts a list of polynomials containing indeterminates contained in parameter Variables, but also accepts simple arithmetic expressions such as 34.
Is there any parameter qualifying coding which will only accept polynomials containing one or more of the indeterminates passed in parameter Variables?
Is it possible to have an information box pop out when cursor is hovered over a plotted point?
i want to solve the system of equation ( 1 )  , (2)  ,  (3)   under the assumation that x , y have the CDF in (4)  ,  (5)
diff(L(lambda[1], lambda[2], alpha), lambda[1]) = n/lambda[1]+sum(x[i], i = 1 .. n)-(sum(2*x[i]*exp(lambda[1])/(exp(x__i*`λ__1`)-1+alpha), i = 1 .. n))
diff(L(lambda[1], lambda[2], alpha), lambda[2]) = m/lambda[2]+sum(y[j], j = 1 .. m)-(sum(2*y[j]*exp(lambda[2])/(exp(y__j*`λ__2`)-1+alpha), j = 1 .. m))
diff(L(lambda[1], lambda[2], alpha), alpha) = (n+m)/alpha-(sum(2/(exp(x[i]*`λ__1`)-1+alpha), i = 1 .. n))-(sum(2/(exp(y[j]*`λ__2`)-1+alpha), j = 1 .. m))
G(x, lambda[1], alpha) = 1-alpha/(exp(lambda[1]*x)-1+alpha)
G(y, lambda[2], alpha) = 1-alpha/(exp(lambda[2]*x)-1+alpha)
Download internet.mw
How do we write code for optimal problem using Pontryagin's maximum principle for simulation.
I a have a question about factorizing real polynomials.
Suppose I have a real polynomial p(x) with integer coefficients. If the degree of p(x) is less than or equal to 4, we can factorize it into linear radical factors. On the other hand, if we require the factorization to be real, theoretically we can factorize it into linear and irreducible quadratic factors.
My question is, if the input p(x) is real polynomial with integer coefficients, is there any Maple function that can give me factorization output with real linear and irreducible quadratic factors, with radical coeffs?
For example, I tried q := 20*x^3+10*x^2+4*x+1, it has one real root and 2 complex roots. I want a factorization like q(x) = 20*(x-r1)*(a*x^2 + b*x + c), with r1, a, b, c, all real radicals.
I compared functions: factors(), solve(), sqrfree(), Splits(), and none of them give what I want.
factors(q) gives:
[20, [[x^3+(1/2)*x^2+(1/5)*x+1/20, 1]]]
factors(q, real)  gives:
[20., [[x+.3423840948583691316993036540027816871936619136844427977504078911, 1], [x^2+.1576159051416308683006963459972183128063380863155572022495921089*x+.1460348209828001458360112632660894203743660942160039146818509889, 1]]]
solve(q)   gives:
-(1/30)*(350+105*sqrt(15))^(1/3)+7/(6*(350+105*sqrt(15))^(1/3))-1/6, (1/60)*(350+105*sqrt(15))^(1/3)-7/(12*(350+105*sqrt(15))^(1/3))-1/6+(1/2*I)*sqrt(3)*(-(1/30)*(350+105*sqrt(15))^(1/3)-7/(6*(350+105*sqrt(15))^(1/3))), (1/60)*(350+105*sqrt(15))^(1/3)-7/(12*(350+105*sqrt(15))^(1/3))-1/6-(1/2*I)*sqrt(3)*(-(1/30)*(350+105*sqrt(15))^(1/3)-7/(6*(350+105*sqrt(15))^(1/3)))
simplify(convert(Splits(q,x),radical))    gives:
[20, [[(1/30)*(350+105*sqrt(5)*sqrt(3))^(1/3)+1/6-7/(6*(350+105*sqrt(5)*sqrt(3))^(1/3))+x, 1], [-(1/60)*(I*sqrt(3)*(350+105*sqrt(5)*sqrt(3))^(2/3)+(35*I)*sqrt(3)+(350+105*sqrt(5)*sqrt(3))^(2/3)-60*x*(350+105*sqrt(5)*sqrt(3))^(1/3)-10*(350+105*sqrt(5)*sqrt(3))^(1/3)-35)/(350+105*sqrt(5)*sqrt(3))^(1/3), 1], [(1/60*I)*sqrt(3)*(350+105*sqrt(5)*sqrt(3))^(1/3)+(7/12*I)*sqrt(3)/(350+105*sqrt(5)*sqrt(3))^(1/3)-(1/60)*(350+105*sqrt(5)*sqrt(3))^(1/3)+1/6+7/(12*(350+105*sqrt(5)*sqrt(3))^(1/3))+x, 1]]]
None of them give me what I want. Is there any build-in function that can help me do that?
William
I haven't soved yet why dchange is not working for this simple command. Any help out there?
Thanks a lot
how will i go about solving this problem, i want to return somthing like this (this anwser is from another function that did not contain sin, and therefor did not gave me problems).
thx in advance
Hey there folks - I have the following headcracker...
I have 2 equations:
                    cos(a t) = cos(b t + c)
                    sin(a t) = sin(b t + c)
Where a, b and c are known constants, and t is a variable.
I would like to find a way to solve these 2 equations simultaneously, i.e. find the t values that solve both equations at the same time. Of course, there will be an infinite number of solutions, so I also need a way to define an interval that t needs to be restricted to, e.g. t = 0..20 * Pi .
The best I've managed is:
   ... but I can't seem to make this work for solving the 2 trig. equations simultaneously
nor can I figure out the syntax for getting all solutions compiled as a list, e.g.
- which would be enormously helpful for further calculations.
Can anyone give some help on this?
Regards,  Matthew
Not to long ago i found a post showing that maple was able to show the steps behind math.
example:
twostep:=proc(expr::uneval)
   (convert(expr,name) =
    subsindets(expr,And(name,satisfies(t->type(eval(t),constant))),
               z->convert(eval(z),name)))
   = eval(expr):
a:=1:
b:=3:
c:=5:
h:=twostep(a+b*c);
                     (a+b*c = 1 + 3*5) = 16
However if I assign a unit to any of these numbers (a,b or c), the twostep code won't work.
Is there any way that maple can show the steps, while having it both show and convert the units?
example:
a:=70V:
b:=40Ohm:   (I can't insert the Omega sign)
c:= twostep(a/b);
                (a/b=70V/40Ohm) = 1,75A
I want to make the blue output my procedure spits out a another color, and align it to the right, is this even possible? Or something like it?
I basically want to make a Maple procedure that does certain calculations and writes the explanation for each calculation. I do however want Maple to write these explanations as a text field like in a normal Maple worksheet, instead of the blue output in the middle. Is this possible? Or is there any alternative ideas you have that I could try? Would really appreciate any kind of help, thanks.
I have included a transfer function of a 3 degree of freedom system.  There are special loci, aside from s = 0, where the numerator will equate to a REAL scalar value, and the denominator will reduce to a simple product of the individual z roots.  Does anyone know if there is some physical significance, interpretation, or analog to this condition and special loci?untitled.mw
I am using matrices to input data in order to plot it on a surface plot. Is it then possible to export an animation of this graph rotating around an axis?
My matrix is 40 x 3 Matrix
Hello friends!
I have one question, whenever I solved system of ODEs using numerical solution (bilton command i.e., dsolve(dsys1, numeric, output = listprocedure, range = 0 .. 1)), its accutacy always like 10 or 12 digits not above at all. I want to how i improve the accuracy. I am waiting your postive answer.
First 1032 1033 1034 1035 1036 1037 1038 Last Page 1034 of 2462
