Suppose that a finite set of polynomials in C[x,y,z] has a finite number of solutions (i.e. the generated ideal is 0-dimensional).
Suppose also that the Groebner basis wrt plex(x,y,z) is
[f(z), g(y,z), h(y,z), k(x,y,z)]
As well known, the system can be now easily solved: choose a root z0 of f, plug it into g and h and look for a common root (y0) etc.
The question is the following:
Is it true that for EVERY root z0 of f there exist y0, z0 such that (x0,y0,z0) satisfy the system?
In all the examples I have seen this is true, but I don't know whether this is true in general or there is a counterexample.
[This is not a pure Maple question but I know that some members here work in this area].
This is what I did:
It seems like it's working. But is there a way to make the time spit out time smaller than seconds? And to automatically generate how much time it took rather than me looking at it and saying "well 43 seconds minus 41 seconds is 2 seconds"? I suspect there might be.
The rest of the sheet is pretty long. NN is a uniform distribution, which worked fine.
I suspect the issue is the Pi. How can I make it give me a histogram with a numerical solution instead?
My code
checkInSet := proc(L, x)
    local i;
    if nops(L) = 0 then
        return 0;
        for i from 1 to nops(L) do
            if x = L[i] then
                return i;
            fi;
        end;
    end;
Let
M := {(a-2*b-2*c)^2*(2*a-b+2*c)^2, (a-2*b-c)^2*(a-b+2*c)^2, (a-2*b+c)^2*(a+b-2*c)^2, (a-2*b+2*c)^2*(2*a+b-2*c)^2, (a-b-2*c)^2*(2*a-b+c)^2, (a-b-c)^2*(a-b+c)^2, (a-b+c)^2*(a+b-c)^2, (a-b+2*c)^2*(2*a+b-c)^2, (a+b-2*c)^2*(2*a-b-c)^2};
But checkInSet(M, (a-2*b-2*c)^2*(2*a-b+2*c)^2) not work? Someone please help me.
Thanks you very much.
when i use the command evalf(Int(f(y),y=-b..b)), i expect that the output of this command to be an integer. but the output is to form of below:
i think that the problem is because of the form of the function f(y) that is the form of below:
f(y) = a*10^354*(b*10^-356*g(sin(y) , cos(y) and exp(y)))
but i dont know how i solve this problem:(
please help me. thank you
if just expect to find whether equation is like
(a-b)*(c-d) + (e-f)*(g-h) = i
if use equal , it will care the variable name, is it possible treat the variable name as a wildcard to match the equation structure only
the structure i mean is *, +, -, =, ()
I followed the steps given in the example of Maple help "Example 5: Adding a MathMLViewer Region" but I get the next error window.
Do you know what is my mistake?
thank you.
I am experimenting with rotating a group of pionts, lines cylinders etc. the only aminations that  will display are where I put the transformations directly as the point coordinates. This is very tedious. Is there a way around this problem efficiently? Attached worksheet shows problem(s). Ultimately I will have a whole group of objects to rotate.
with(plots)
with(plottools)
[annulus, arc, arrow, circle, cone, cuboid, curve, cutin, cutout, cylinder, disk, dodecahedron, ellipse, ellipticArc, exportplot, extrude, getdata, hemisphere, hexahedron, homothety, hyperbola, icosahedron, importplot, line, octahedron, parallelepiped, pieslice, point, polygon, prism, project, rectangle, reflect, rotate, scale, sector, semitorus, sphere, stellate, tetrahedron, torus, transform, translate]
a1 := proc (t) options operator, arrow; display(line([0, 0, 0], [10*sin(t), 0, 0], colour = red), point([10*sin(t), 0, 0], colour = green, symbolsize = 50, symbol = solidsphere), line([0, 0, 0], [0, 10*sin(t+1.6), 0], colour = orange), point([0, 10*sin(t+1.6), 0], colour = green, symbolsize = 40, symbol = solidsphere), line([0, 0, 0], [0, 0, 10*sin(t+.5)^2], colour = yellow), point([0, 0, 10*sin(t+.5)^2], colour = green, symbolsize = 30, symbol = solidsphere)) end proc
animate(a1, [t], t = 0 .. 2*Pi, frames = 100)
c1 := Vector(3, [1, -.2, 0]):
c2 := Vector(3, [-1, -.2, 0]):
c3 := Vector(3, [0, 1, 0]):
c4 := Vector(3, [1, -.2, 0]):
c5 := Vector(3, [-1, -.2, 0]):
c6 := Vector(3, [0, 1, 0]):
c7 := Vector(3, [.5, 0, 0]):
c8 := Vector(3, [0, .5, 0]):
c9 := Vector(3, [0, 0, .5]):
c := [seq(c || n, n = 1 .. 9)]
[Vector[column](%id = 18446744074349586662), Vector[column](%id = 18446744074349586782), Vector[column](%id = 18446744074349586902), Vector[column](%id = 18446744074349587022), Vector[column](%id = 18446744074349587142), Vector[column](%id = 18446744074349587382), Vector[column](%id = 18446744074349587502), Vector[column](%id = 18446744074349587622), Vector[column](%id = 18446744074349587742)]
Rot := Matrix([[cos(w*t), -sin(w*t), 0], [sin(w*t), cos(w*t), 0], [0, 0, 1]])
Matrix(%id = 18446744074349582806)
d := seq(Rot.c[n], n = 1 .. 9)
Vector[column](%id = 18446744074349577870), Vector[column](%id = 18446744074349577990), Vector[column](%id = 18446744074349578110), Vector[column](%id = 18446744074349578230), Vector[column](%id = 18446744074349578350), Vector[column](%id = 18446744074349578590), Vector[column](%id = 18446744074349578710), Vector[column](%id = 18446744074349578830), Vector[column](%id = 18446744074349578950)
w := .25
.25
[d[1][1], d[1][2], d[1][3]]
[cos(.25*t)+.2*sin(.25*t), sin(.25*t)-.2*cos(.25*t), 0.]
ff1 := proc (t) options operator, arrow; plots:-display([plottools:-line([0, 0, 0], [d[1][1], d[1][2], d[1][3]], colour = red, thickness = 4)]) end proc
plots:-animate(ff1, [t], t = 0 .. 5, frames = 100)
Lend1 := [cos(w*t)+.2*sin(w*t), sin(w*t)-.2*cos(w*t), 0.]
ff2 := proc (t) options operator, arrow; plots:-display([plottools:-line([0, 0, 0], Lend1, colour = red, thickness = 4)]) end proc
plots:-animate(ff2, [t], t = 0 .. 5, frames = 100)
ff3 := proc (t) options operator, arrow; plots:-display([plottools:-line([0, 0, 0], [cos(.35*t)+.2*sin(.35*t), sin(.35*t)+(-1)*.2*cos(.35*t), 0.], colour = red, thickness = 4)]) end proc
proc (t) options operator, arrow; plots:-display([plottools:-line([0, 0, 0], [cos(.35*t)+.2*sin(.35*t), sin(.35*t)-.2*cos(.35*t), 0.], colour = red, thickness = 4)]) end proc
plots:-animate(ff3, [t], t = 0 .. 5, frames = 100)
Download Anim_How-1.mw
with(plots)
with(plottools)
w := .25
.25
Connecting to a linux x2go server with an x2go client (tried Mac and Linux) and try to start maple2016 in a terminal, I get this error:
$ /opt/maple2016/bin/xmaple
Picked up JAVA_TOOL_OPTIONS:
Exception in thread "Request id 1" java.lang.UnsupportedOperationException: PERPIXEL_TRANSLUCENT translucency is not supported
    at java.awt.Window.setBackground(Window.java:3842)
    at java.awt.Frame.setBackground(Frame.java:988)
    at com.maplesoft.worksheet.application.WmiSplashScreen.<init>(Unknown Source)
    at com.maplesoft.worksheet.application.WmiGenericStartupStrategy.showSplash(Unknown Source)
    at com.maplesoft.worksheet.application.WmiGenericStartupStrategy.doStartup(Unknown Source)
    at com.maplesoft.worksheet.application.WmiWorksheetStartupStrategy.doStartup(Unknown Source)
    at com.maplesoft.application.Maple.doStartup(Unknown Source)
    at com.maplesoft.application.Application.startup(Unknown Source)
    at com.maplesoft.application.ServerProtocol$StartApplicationHandler.processCommand(Unknown Source)
    at com.maplesoft.application.ServerProtocol.executeCommand(Unknown Source)
    at com.maplesoft.application.ServerProtocol.processNextStep(Unknown Source)
    at com.maplesoft.application.ExchangeProtocol.executeProtocol(Unknown Source)
    at com.maplesoft.application.ApplicationManager$Listener.run(Unknown Source)
    at java.lang.Thread.run(Thread.java:745)
The same xmaple will start graphically if I connect with a normal remote X connection. However a normal remote X connection is unusable on a slow network connection.
I have 5 equations mentioned as below,
a[0]=L+(2*beta*mu)/(3*alpha*omega^2);
a[1]=sqrt((4*mu)/(3*alpha*omega^2));
a[2]=(2*beta*mu)/(9*alpha*omega^2);
a[3]=sqrt(mu^3/(432*alpha*omega^2));
omega[s]=omega-(mu^2/16*omega)-((2*beta^2mu)/(9*alpha*omega));
Left-hand parameters i.e. a[0],a[1],a[2],a[3], omega[s] are known , and each equation on right hand contain unkonowns i.e alpha, mu, beta, omega.
I want expression for unknowns in terms of knowns.
Maple 2016 used to work fine on my PC but now it won't even load. Whenever I try to click the program I can see the loading icon next to the cursor and then nothing happens next. It works fine on my laptop and I'm using the program under a univsersity license. Yesterday I was able to open it once for some reason and now it's the same as before. I've tried uninstalling it again and again several time but that doesn't work.
Any help would be much appreaciated.
I have a problem in this form:
a1x1+a1x1+...anx1 +(x1)= b1
a1x2+a1x2+...anx2 +(x2)= b2
a1xn+a1xn+...anxn +(xn)= bn
Here, x1,x2,.......,xn  are unknowns, a1,a2,...,aand b1,b2,...,bare known contants.
Is there a possible way to find unknowns?
How to build cuboid in pyramid like this animation
http://www.irem.univ-mrs.fr/article/optimisation-du-volume-d-un-pave.html
Thanks !
I was creating this code for the "Müller Method" for Numerical Analysis. Everything works fine till the if (for getting the x3) goes on. The problem is, the Maple doesn't detects the if.
I tried checking every variable and every variable is calculated except "x3"; even "disc".
I would like to know what happened. Anyways, here's the code:
http://imgur.com/a/DGlgl
x0 := 0; x1 := 8.4; x2 := 10; iter := 1000; tol := 10^(-8); f := proc (x) options operator, arrow; 3*x^3+7*x^2+x+2 end proc; f(x); plot(f(x), color = green); printf(" n          x0               x1               x2              x3                Error \n"); for i to iter do d0 := evalf((f(x1)-f(x0))/(x1-x0)); d1 := evalf((f(x2)-f(x1))/(x2-x1)); h1 := evalf(x2-x1); h0 := evalf(x1-x0); a := evalf((d1-d0)/(h1-h0)); b := evalf(a*h1+d1); c := evalf(f(x2)); disc := sqrt(-4*a*c+b^2); if abs(b+disc) > abs(b-disc) then x3 := x2+(-2*c)*(1/(b+sqrt(-4*a*c+b^2))); erry := abs((x3-x2)/x3) else x3 := x2+(-2*c)*(1/(b-sqrt(-4*a*c+b^2))); erry := abs((x3-x2)/x3) end if; if erry > tol then x0 := x1; x1 := x2; x2 := x3; printf("%2d     %2.8f      %2.8f       %2.8f         %2.5 f     %2.8 f \n", i, a, b, c, x3, erry) else printf("una raiz es: %2.8f ", x3); break end if end do;
I put the image (as it looks on my maple) and the "code" so you can copy-paste it in Maple.
Dear hope you will be fine I want to represent the data in term of solid line not dotted, asterik etc of the following code. Please help me to fix this problem
restart; epsilon := 0; Pr := 1; beta := .1; Sc := 1; S := 0; L := 15;
                               15
for i from -L while i <= L do a[i] := 1.0*i/L end do;
for i2 from -L while i2 <= L do fw := a[i2]; Eq1[i2] := eval(diff(F(eta), eta, eta, eta)+F(eta)*(diff(F(eta), eta, eta))-(diff(F(eta), eta))^2+S*(epsilon-(diff(F(eta), eta)))+epsilon^2); Eq2[i2] := eval((diff(G(eta), eta, eta))/Pr-G(eta)*(diff(F(eta), eta))+F(eta)*(diff(G(eta), eta))); Eq3[i2] := eval(diff(H(eta), eta, eta)+Sc*(F(eta)*(diff(H(eta), eta))-beta*H(eta))); IC[i2] := F(0) = a[i2], (D(F))(0) = 1, (D(F))(L) = epsilon, G(0) = 1, G(L) = 0, H(0) = 1, H(L) = 0; dsys1[i2] := {Eq1[i2], Eq2[i2], Eq3[i2], IC[i2]}; dsol1[i2] := dsolve(dsys1[i2], numeric, output = listprocedure, range = 0 .. L); dsol1x[i2] := subs(dsol1[i2], diff(F(eta), eta, eta)); dsol1y[i2] := subs(dsol1[i2], G(eta)); dsol1z[i2] := subs(dsol1[i2], H(eta)) end do;
for j from -L while j <= L do g[j] := eval(-dsol1x[j](0)) end do;
g1 := pointplot({seq([n/L, g[n]], n = -L .. L)}, symbol = asterisk, symbolsize = 15, color = blue);
display(g1);
First 1044 1045 1046 1047 1048 1049 1050 Last Page 1046 of 2462
