Hi, i try resolve this equations numerical for the boundary between the spinglass and ferromagnetic phases:
how?
Regards.
I have the ODEs: x'=x
ode:=diff(x(t),t)-x(t);
sketch the phase space and extended phase space of previous ode.
theta := a-(1/2)*beta*a*y^2+(1/24)*beta^2*a*y^4-(1/720)*beta^3*a*y^6+(1/40320)*beta^4*a*y^8-(1/3628800)*beta^5*a*y^10+(1/479001600)*beta^6*a*y^12-(1/87178291200)*beta^7*a*y^14+(1/20922789888000)*beta^8*a*y^16-(1/6402373705728000)*beta^9*a*y^18+(1/2432902008176640000)*beta^10*a*y^20-(1/1124000727777607680000)*beta^11*a*y^22+(1/620448401733239439360000)*beta^12*a*y^24
Pls, anyone with useful informations on how to convert a series just like the one above to trigonometry or hyperbolic form. Need response as soon as possible. Thankin you in anticipation for your favorable response.
hello,I want to solve a quesstion about heat equation,that the quesstion like this:
I use the code like this
but the results is wrong obviously and what's wrong with this code?
anxious for your help,thanks.
hi
how can i plot a 3d polygonal cylinder for example a hexagonal?
Hi Dears,
I studied the concept of Grobner bases and some algorithm for computing them. I understood that the computation of grobner bases is related to the term ordering. Also, I knew that LEX ordering is very expensive. So, it is good idea to use the Grobner basis conversion algorithms such as FGLM and Grobner walk algorithm. Now, I want to know concerning the complexity of these algorithm (Buchbergers algorithm, F4 and F5 algorithm, FGLM algorithm and Grobner walk). I hope my question be appropriate in this site,
Thank you in advance.
I am looking forward to hearing from you.
Any help will be appreciated
I have a continuous time dynamical system
x in R ( set of real number)
t  a positive real time
and the function f_t(x)=x-t
How can we plot or sketch their behaviour in the phase space and in the extended phase space
Many thanks
Hello Guys,
I am having a problem plotting a graph from some sets of point. Please how do I plot a graph having some set of point.
Dear friends:
I am facing to search the command which zoom a sactor of graph, I know it can be done by using maple tools whose present tool bar but I need a command for zooming please help me to fix this problem (attached) I want to see th sactor eta=0.8 to eta=1.2.
graph_phi_varies.mw
Please see the problem and correct as soon as possible. I am waiting your positive respone.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
Greetings to all.
My apologies if this is a repeat, I could not ascertain if this question has been asked before. I am not able to enter a tilde in my home page URL in my profile. I used the escape sequence %7E as a workaround. This does not work in all browsers however, e.g. the page displays correctly in Chrome but not in Firefox. How to enter the tilde into my profile URL? (The tilde is commonly used to indicate the directory public_html in a user's home directory by the Apache web server.) Thank you.
Marko Riedel
Is there are way in maple to check if two expressions are equal for certain intervals for each variable?
I tried to create a formula to give me some propabilities in a card game scenario. I used two different methods to find it, and ended up with these two formulars that seems to give me the same results, but I don't know how I would go about showing by hand if they are equal.
All variables are whole numbers.
I added a picture with the variable intervals and the two formulas.
Not used to these kind of notations, so tell me if anything is unclear.
A man walks to different points.
I have to find the point that has a minimal length.
Perhaps through the Repetition Statement (for...while...do)
For the space curve in the linked worksheet, RadiusOfCurvature and Binormal give incorrect results. Why?
TNB_anomalies.mw
Please tell me if the above link doesn't work.
I have a function which calculates a number for [x,y] inside a matrix, which depends on the values surrounding said initial cell (from [x-1,y-1] yo [x+1,y+1]). However, for the values on the border, the idea is to go around to the opposite side, creating a Torus of the sort.
The solution I seemed to have found was to create 4 indices: 2 controled with 'for' and 2 which were modified accordingly to be used as imputs for the function:
x:=x0;y:=y0;
for r from x-1 to x+1 do
    print("r",r);
    for t from y-1 to y+1 do
        print("t",t);
        if r=0 then i:=N; else i:=r; fi;
        if t=0 then j:=N; else j:=t; fi;
        if r=N+1 then i:=1; else i:=r; fi;
        if t=N+1 then j:=1; else j:=t; fi;
        print("i",i);print("j",j);
        function(i,j);
od; od;
(the print commands are for the tests I have been running so see where the potential error lied).
If you run this script, you can clearly see for x0,y0<>1 that it works perfectly, even for x0,y0=N where it succesfully goes around and changes to 1. However, for x0,y0=1 it isn't able to detect that r&t=0 and so it doesn't change it to N; creating an error where it tries to find the value 0 of an Array.
Thanks in advance,
Enrique
how to read a jpg picture and draw mesh on it?
mesh generator in maple
how to get all points and lines from this mesh on jpeg picture?
First 1042 1043 1044 1045 1046 1047 1048 Last Page 1044 of 2462
