how to read a jpg picture and draw mesh on it?
mesh generator in maple
how to get all points and lines from this mesh on jpeg picture?
How can i answer iv on Maple?
The problem I am trying to solve requires a significant amount of computation time. I am unaware if a solution to the problem exists. If a solution does exist, I only need one solution, not the set of every possible solution. Is there a way to restrict the solve function such that when (if) one solution is found, the computation halts and the solution is outputted?
I can't seem to plot the second derivative graph for f'' versus y. Is it possible to use the fdiff command twice in a line?
Open to all opinions. Any help would be greatly appreciated :)
fyp3.mw
I have a set of differential equations which I have solved for a specific value, and would like to use the second answer (F__A(V)) in my next calculations
What command can I use to retrieve that value?
sol(0.1e-4);
     [V = 0.00001, F__A(V) = HFloat(3.498873118476744e-6),
       F__B(V) = HFloat(1.9101126881523255e-5),
       F__C(V) = HFloat(9.550563440761627e-6)]
how to define VertexWeight in Graph Theory package
I have tried to do it by the following command "File/Modelica/Import Modelica Library" in MapleSim GUI. An error appears saying "Modelica is a reserved name".
I think you can also reproduce it by downloading the Modelica library from the following web site: "https://www.modelica.org/libraries". And then importing it in the usual way by openning the package.mo file at the root directory.
I think I am missing something here, so any advise/information/minimal commentary would be greatly appreciated.
Cheers, Ovle
I am working in a simulation, which requires me to create a checkerboard of values which I paint afterwards according to its value. The idea is to create a sequence of images (which I could export for every iteration and create into a gif/timelapse afterwards). The problem I am encountering is that when I try to plot it, I only obtain a difuse coloring scheme, without having a specific color for every pixel.
if you search for the color command in plots (http://www.maplesoft.com/support/help/Maple/view.aspx?path=plot/color) one of the examples is more or less the result I want, but I would like to have it without the gridlines and being able to control the color according to the value of the matrix in said position.
My current attempt, and the one closest to the solution is:
R:=Matrix(1..N,1..N, datatype=integer); for x from 1 to N do for y from 1 to N do R[x,y]:=P[x,y,2]*18+P[x,y,3]: od: od:R;
#P is the matrix where I do the calculations and R is the matrix I want to plot after every step of the calculation.
surfdata(Matrix(R), 1..N, 1..N, style=surface,
         dimension=2, labels=["x", "y"],
         gridsize=[100,100],
         colorscheme=["zgradient",
                      ["Indigo","Blue","Cyan","Green","Yellow","Orange","Red"]]);
#the surfdata I resqued from another proyect I had. I know it is not thought for this tipe of grafs, but it was the closest I could come by.
I do not know if it is a better idea to use an Array or a Matrix to plot this. While the P array isn''t touched, I do not mind modifying in any way the R matrix
Thank you,
Enrique
after solve a set of equations, i got a set of solutions, [A,B,C], if i remove one of solution [C]
is it possible to find this removed solution from solutions set [A,B]
how to check the dependency of groebner basis or a set of polynomials?
emal := proc(zipeq,abc1param,abc2param,abc3param,abc4param,abc5param)
source1 := Prefix(zipeq);
print(source1);
source2 := subs(s=abc5param,subs(v=abc4param,subs(u=abc3param,subs(t=abc2param,subs(a=abc1param,source1))))):
print(source2);
zipplus := proc(mm, pp)
 return zip((x,y) -> x+y, mm, pp)
zipstar := proc(mm, pp)
 return zip((x,y) -> x*y, mm, pp)
return eval(source2);
would like to do the Prefix first and then eval the prefix later but do not expect do define zipstar and zippplus in global
just want to eval this Prefix which is formula of zipstar and zipplus function
above result same as print(source2), but eval in return , it have not evaluate, why?
A family of curves has polar equation r=cos^n (theta/n), 0<=theta,n*pi, where n is a positive even integer.
Previously Using t = theta as the parameter and finding  a parametric form of the equation of the family of curves it was shown that
dy/dx = (sin(t)sin(t/n)-cos(t)cos(t/n)) /( sin(t)cos(t/n)+cos(t)sin(t/n)).
Is it possible to show on Maple with a program that there are n+1 points where the tangent to the curve is paralell to the y axis?
eqn := (A/(1+a*exp(-b*(((atan(h/R))*(180/Pi))-a)))) +10*log10(h^2+R^2)+20*log10(f)+20*log10(4*Pi/c)+nNLOS = 110;
R and h are my unknown variables in the equation
The rest of variables, A,c,f,a,b,NLOS are known.
I need to find solution such that derivate of R w.r.t h = 0, I want to maximize R.
But this equation is implicit, R cannot be separated on one side of the equation. I tried:
> implicitdiff(eq, R, h);
But I get the error:
Using t = theta as the parameter, find a parametric form of the equation of the family of curves and show that
on maple i tried
x:=((cos(t/n))^n)*cos(t):
y:=((cos(t/n))^n)*sin(t):
w:=diff(x,t)
z:=diff(y,t)
z/w
and i never got the above answer so i did
simplify(z/w)
and still never got the answer instead i got
(cos(t/n)*sin(t/n)-sin(t)*cos(t))/(cos(t/n)^2-cos(t)^2)
I am exporting Maple 3d graphics to eps file with Maple 17 and Maple 2015 under Mac OS. For instance, the result of plot3d(x*y,x=0..1,y=0..1); I cannot open the resulting eps file neither with Adobe software or Apple's First View. On the contrary, I can open the eps files with Maple 18. I hope you can help me.
Best wishes
Leonardo
First 1043 1044 1045 1046 1047 1048 1049 Last Page 1045 of 2462
