 How get another solutions ? f:=exp(x2*(a-x))
I would like to start using maple workbook to manage my projects but i can't figure out the paths. suppose i have a workbook named: WorkBookTest.maple
and inside this i have a folder containing Data in which i have an excel workbook DataTest.xlsx
and also i have a folder containing Documents in which i have a maple worksheet Document.mw
and also i have a folder containing Code in which i have a mathematica notebook Code.nb
Now inside the maple worksheet, to import the excel data i use the command: Import("this:///Data/DataTest.xlsx")
and it works
Now inside the mathematica workbook, to import the excel data i use the command: Import["this:///Data//DataTest.xlsx"]
and it fails
so if i have other program like mathematica notebook inside maple workbook that wants to call a file with data, how should i define the path?
Does Maple have something similar to c-means clusteirng in Matlab?
http://www.mathworks.com/help/fuzzy/fcm.html
 How would I go about doing something like this in Maple?
The docs for the package geometry say:
The command with(geometry,distance) allows the use of the abbreviated form of this command.
I am new to Maple. What is the abbreviated form of the distance command?
aa3 := Normalize(<<aa2[1,1],aa2[2,1],aa2[3,1]>,<aa2[1,2],aa2[2,2],aa2[3,2]>,<aa2[1,3],aa2[2,3],aa2[3,3]>>, Euclidean);
the result is one column
how to normalize to a matrix form?
I have a problem with finding a interval where parametr "a" is changing.
My funcion:
                 exp(x2(a-x)) for xcR.
I did this, and I don't know what's next.
g:=x->exp(x2(a-x));
dg:=diff(g(x),x);
solve(dg=0,x);
                      0,2/3a
g(0);
g(2/3a);
Hi, all. I need to built a user interface for my program. First, I create two label and two text area for both the value of x and y. After that I assign a button to random generate the value for x and y within the range with x <y. I write the code below into click action of the button.
use DocumentTools in
Do(%x=RandomTools[Generate](integer(range=1..7);
Do(%y=RandomTools[Generate](integer(range=1..7);
while %x>= %y do
end use;
This code can generate two random number and insert inside the boxes created. When the button is clicked, two random number generated but the error dialog box shown on the screen with message : Error in component button with caption "generate" cannot determine if this expression is true or false: %y=%x. What I want is only the true value of x<y will be inserted to the text boxes.
Any suggestion? Any help will be highly appreciated. Thank you.
For example,
I have original bit :=[10000000]. after encryption by using technique cryptography, I get thecipher text:=[11110011]. Then I need to measure the total flipped bit in the cipher text with the original bit. Have any method can calculate the total flipped bit? Can someone help me? Thank you.
For example, I havd matrix m:=[0 1 0 1 0 1 0], I want to convert it back to m:=[0,1,0,1,0,1,0]. Can someone help to solve? Thank you.
I have two inter-related expressions of the form,
(i) T=f(w)
(ii) E=g(w)
where the limits of w in both expressions are same. Now I need to plot a graph T Vs E
Any suggestions???
interface(displayprecision = 4)
-1
Vert_Coef := Matrix(10, 5, {(1, 1) = 0.332e-1, (1, 2) = 0.187e-1, (1, 3) = 0.104e-1, (1, 4) = 0.52e-2, (1, 5) = 0.21e-2, (2, 1) = 0.509e-1, (2, 2) = 0.301e-1, (2, 3) = 0.166e-1, (2, 4) = 0.83e-2, (2, 5) = 0.31e-2, (3, 1) = 0.571e-1, (3, 2) = 0.364e-1, (3, 3) = 0.218e-1, (3, 4) = 0.104e-1, (3, 5) = 0.42e-2, (4, 1) = 0.582e-1, (4, 2) = 0.405e-1, (4, 3) = 0.260e-1, (4, 4) = 0.125e-1, (4, 5) = 0.42e-2, (5, 1) = 0.582e-1, (5, 2) = 0.416e-1, (5, 3) = 0.270e-1, (5, 4) = 0.135e-1, (5, 5) = 0.52e-2, (6, 1) = 0.582e-1, (6, 2) = 0.416e-1, (6, 3) = 0.281e-1, (6, 4) = 0.145e-1, (6, 5) = 0.52e-2, (7, 1) = 0.582e-1, (7, 2) = 0.416e-1, (7, 3) = 0.291e-1, (7, 4) = 0.166e-1, (7, 5) = 0.62e-2, (8, 1) = 0.582e-1, (8, 2) = 0.416e-1, (8, 3) = 0.301e-1, (8, 4) = 0.177e-1, (8, 5) = 0.62e-2, (9, 1) = 0.582e-1, (9, 2) = 0.416e-1, (9, 3) = 0.301e-1, (9, 4) = 0.187e-1, (9, 5) = 0.73e-2, (10, 1) = 0.582e-1, (10, 2) = 0.416e-1, (10, 3) = 0.301e-1, (10, 4) = 0.197e-1, (10, 5) = 0.83e-2})
whattype(Vert_Coef)
Matrix
SR := Vector([10.8696, 21.7391, 32.6087, 43.4783, 46.7391, 54.3478, 65.2174, 76.0870, 86.9565, 100.0000], datatype = float)
Vector(10, {(1) = 10.8696, (2) = 21.7391, (3) = 32.6087, (4) = 43.4783, (5) = 46.7391, (6) = 54.3478, (7) = 65.2174, (8) = 76.0870, (9) = 86.9565, (10) = 100.0000})
E_G := Vector([250, 500, 1000, 2500, 10000], datatype = float)
Vector(5, {(1) = 250.0000, (2) = 500.0000, (3) = 1000.0000, (4) = 2500.0000, (5) = 10000.0000})
``NULL
B_interp := proc (SR, E_G) options operator, arrow; CurveFitting:-ArrayInterpolation([SR, E_G], Vert_Coef, Array(1 .. 1, 1 .. 1, 1 .. 2, [[[SR, E_G]]]), method = linear) end proc
f[18*_1] := B_interp(25.0, 1500.0)
Error, (in CurveFitting:-ArrayInterpolation) invalid input: dimensions of independent data do not match the dimensions of dependent data
Download Matrix_Interpolation.mw
Hello Mapleprime Community,
Would you be kind to help me with the attached Maple worksheet. My goal is to do a 2D interpolation given the value of SR (slenderness ratio) and E_G (Young's modulus / Shear modulus ratio) in the Matrix table Vert_Coeff with header as vector E_G and the other as vector SR. I’m confused as to how to do the interpolation. Please help.
Moses
So, I have the following inputted into Maple 2015, but the plots are not displaying.  I've double checked the syntax, but I don't see anything wrong.  Any thoughts?  Thank you!
plot3d(cos(theta)^2, phi = 0 .. 2*Pi, theta = 0 .. Pi, axes = BOX, style = line, grid = [50, 50], view = [-1 .. 1, -1 .. 1, -1 .. 1], coords = spherical);
Trying to plot that here actually displays the plot, but it isn't showing up in my Maple worksheet.
hi
how pdsolve 2D couple  non linear differential equations which attached below?
2D.mw
PD1 := 12.6000000000000*(diff(U(x, theta), x, x, x, x))-7500*(diff(U(x, theta), x, x))+10.2112755389544*(diff(U(x, theta), x, x, theta, theta))+7.22165554279476*(diff(V(x, theta), x, x, x, theta))-3730.19397871630*(diff(V(x, theta), x, theta))+4.57316679658261*(diff(V(x, theta), x, theta, theta, theta))+36.0000000000000*(diff(W(x, theta), x, x, x))-9375.00*(diff(W(x, theta), x))-15.6731205946742*(diff(W(x, theta), x, theta, theta))-1947.26649812618*(diff(U(x, theta), theta, theta))+1.41357763467822*(diff(U(x, theta), theta, theta, theta, theta)):
PD2 := 3.52500000000000*(diff(V(x, theta), x, x, x, x))-3150.00*(diff(V(x, theta), x, x))+5.05278814097746*(diff(V(x, theta), theta, theta, theta, theta))-4972.65371594662*(diff(V(x, theta), theta, theta))+10.2112755389544*(diff(V(x, theta), x, x, theta, theta))+7.22165554279476*(diff(U(x, theta), x, x, x, theta))+4.57316679658261*(diff(U(x, theta), x, theta, theta, theta))-2536.53190552708*(diff(U(x, theta), x, theta))+97.2834589649212*(diff(W(x, theta), x, x, theta))+30.9917088694028*(diff(W(x, theta), theta, theta, theta))-31273.9463175575*(diff(W(x, theta), theta)):
PD3 := -0.168000000000000e-2*(diff(W(x, theta), x, x, x, x, x, x))+16.9000000000000*(diff(W(x, theta), x, x, x, x))-0.319161728473364e-2*(diff(W(x, theta), x, x, x, x, theta, theta))-37.5000000000000*(diff(W(x, theta), x, x))+796.276013656496*(diff(W(x, theta), x, x, theta, theta))-0.202111525639098e-2*(diff(W(x, theta), x, x, theta, theta, theta, theta))-36.0000000000000*(diff(U(x, theta), x, x, x))+9375.00*(diff(U(x, theta), x))+15.6731205946742*(diff(U(x, theta), x, theta, theta))-97.2834589649212*(diff(V(x, theta), x, x, theta))+31273.9463175575*(diff(V(x, theta), theta))-30.9917088694028*(diff(V(x, theta), theta, theta, theta))+2.06625000000000*10^5*W(x, theta)+313.462411893484*(diff(W(x, theta), theta, theta))+6.77715234781900*(diff(W(x, theta), theta, theta, theta, theta))-0.426628729281504e-3*(diff(W(x, theta), theta, theta, theta, theta, theta, theta))-400/((1-h3*f3(x))*ln(10-10*h3*f3(x))^2)-500/(1-h3*f3(x))^4:
BC := {D[1](U)*(0, theta) = 0, D[1](U)*(1, theta) = 0, D[1](U)*(x, 0) = 0, D[1](U)*(x, 1) = 0, D[1](V)*(0, theta) = 0, D[1](V)*(1, theta) = 0, D[1](V)*(x, 0) = 0, D[1](V)*(x, 1) = 0, D[1](W)*(0, theta) = 0, D[1](W)*(1, theta) = 0, D[1](W)*(x, 0) = 0, D[1](W)*(x, 1) = 0, D[2](W)*(0, theta) = 0, D[2](W)*(1, theta) = 0, D[2](W)*(x, 0) = 0, D[2](W)*(x, 1) = 0, U(0, theta) = 0, U(1, theta) = 0, U(x, 0) = 0, U(x, 1) = 0, V(0, theta) = 0, V(1, theta) = 0, V(x, 0) = 0, V(x, 1) = 0, W(0, theta) = 0, W(1, theta) = 0, W(x, 0) = 0, W(x, 1) = 0}
Download 2D.mw
I need to receive a plot of the next equation:
E:=0.001;
eq := E*(diff(y(x), `$`(x, 2)))+(x^2+1)*(diff(y(x), x))-x*(x-1/2)^2 = -x^2+2.7^x ;
/*(x=0..1, y(0)=-1, y(1)=0)*/
I try to use DEplot in such way DEplot(eq, y(x), x = 0 .. 1, y = -1 .. 0); but i always get a bug like
Error, (in DEtools/DEplot) cannot produce plot, non-autonomous DE(s) require initial conditions.
Is it possible to do the ab-initio method for differentiation in maple?
First 1172 1173 1174 1175 1176 1177 1178 Last Page 1174 of 2463
