A quick question, Can I add legends to 3D plots?
I am currently working in Maple, following an example on the Maplesoft site very closely. I am trying to make use of the 'Colorize' function in the Escape-Time Fractals package.
I have a Newton's basin with the standard colouring but am trying to make my image more sophisticated. I have tried following the example given for the Mandelbrot set (At the bottom of the page - http://www.maplesoft.com/support/help/Maple/view.aspx?path=Fractals/EscapeTime/Mandelbrot) as there isn't one on the Newton Fracal page but keep receiving the Kernel lost message. I do not think the issue is my firewall.
My code is as follows,
with(Fractals:-EscapeTime);
with(ImageTools);
Everything works up until I go to evaluate P. I have tried giving both Arrays datatype=float[8] and have tried getting rid of the datatype section completely as to use the default. Neither of these have helped.
Any insight as to why this may be happening would be appreciated.
I have to calculate the eigenspace of a bunch of matrices and then intersect all together. Is it possible to have a procedure for this problem that returns a basis for the intersection of all the eigenspaces?
My matrices are tensor products of matrices so I was wondering whether there is a procedure to calculate the kronecker product of more than 2 matrices.
Paraphrasing:
https://en.m.wikipedia.org/wiki/Langford_pairing
given a sequence of 2n numbers 1,1,2,2,3,3,...n,n in which the two 1's are 1 slot apart, the two 2's are 2 slots apart, the two 3's are 3 slots apart, -> generally the two n's are n slots apart.
for n=3, a possible sequence is [2,3,1,2,1,3].
There is sequences for n=4,7,8...
i havent a clue how to write a maple procedure to generate a sequence for given n, but I'm hoping an expert here can.
Good evening,
I know the plot package and use frequently, but the basics. Now I need to make a curve that looks like an " umbrella " and it appears the projection in the xy plane . I don't know if it's possible , but I'm not getting . Does anyone have any idea to help me ? Thank you!
I'm trying to write a procedure that computes Pollard's P-1 Method for a given integer n, and then outputs the prime factorisation of n.
Here is what I have so far:
Pollard := proc (n)
local i, r, g;
r[1] := `mod`(2^factorial(2), n);
for i from 2 while gcd(`mod`(r[i-1]-1, n), n) = 1 do
r[i] := `mod`(2^factorial(i+1), n) end do;
g[i] := gcd(`mod`(r[i-1]-1, n), n);
if g[i] < n then return g[i]
else return n
end if
But my procedure doesn't seem to work for a lot of large values for n.
And also I can't figure out how to make it actually output the factorisation.
Maybe this is trivial but could somebody tell me how to get bounds of interval returned by shake? For instance,
shake(sqrt(2)) gives INTERVAL(1.41421356167 .. 1.41421356308), and I would like to store the upper and lower bounds as rational numbers in two variables.
I would like to ask you for your help
I receive this message when trying to export matrix to excel file:
> restart; with(ExcelTools); with(LinearAlgebra);
> C := Import("C:/SourceFile.xlsx", "Overview", "AK51:CB94");
> C := convert(C, Matrix);
> B := Import("C:/SourceFile.xlsx", "Overview", "G3:G46");
> B := convert(B, Matrix);
> IM := IdentityMatrix(44, 44);
> NP := 1/(C-IM).(-B);
> NP[6, 1];  //check if there is value. Yes, it works.
> Export(NP, "C:/ResultFile.xlsx", "Sheet1", "A1");
Thank you for any help.
I have posted long time ago a patch for Shadebetween and you have transformed it into a hot fix:
http://www.mapleprimes.com/questions/205956-Error-In-Shadebetween
In the last Maple 2015 update, the problem was not fixed.
Just curious: is it fixed in Maple 2016? Because I feel that the Maplesoft team is not "impressed" by such patches.
Edit. This was a comment related to acer's patch for NLPSolve, but it was transformed (I don't know why) into a separate question.
@Carl Love
i guess that it is this.
actually my goal is
drawing
 tangent vector field on even-dimensional n-spheres
can vector field plot do this too?
if start from draw vector field on a sphere
i find that intersectplot under plot,
is it possible for fieldplot has this
such as the graph in wiki
https://en.wikipedia.org/wiki/Hairy_ball_theorem
how draw a line x+y = 1 on a sphere x^2+y^2+z^2 = 1 in maple
Hi guys, I'm currently having a lot of trouble with Maple and can't seem to get stuff to work. I have the task of solving and modelling the Klien Gordon equation, with a chosen potential. The equation I'm trying to solve is:
> KGE := diff(psi(x, t), x, x)-(diff(psi(x, t), t, t))-12*psi(x, t)^5+10*psi(x, t)^4+6*psi(x, t)^3-3*psi(x, t)^2-psi(x, t) = 0
I'm doing this by changing the pde into an ode via a transformation
>tr := {t = tau, x = c*tau+z, psi(x, t) = U(z)}
>ode1 := dchange(tr, KGE, [z, tau, U(z)])
 >ode1 := collect(ode1, diff(U(z), z, z))
>c := 1/4
>ode2 := subs({U(z) = U, diff(U(z), z, z) = V(U)*(diff(V(U), U))}, ode1)
>sol := dsolve({ode2, V(0) = 0}, V(U))
>sol1:= sol[2]
>z := -c*t+x = int(1/rhs(sol2), U)
>solwave := psi(x, t) = solve(z, U)
I then checked if my solution, solwave actually solved the pde via pdetest(solwave,KGE) and it did. Hence this is what I took as one of the kinks. Although the kink solution looks hideous and I have no idea how to try and take the limit as x goes to infinity, as to show it tends to a vacuum of the potential. I've tried taking the limit but all Maple does is replace all the x with infinity signs...
I then tried animating it to see if it worked, but it just looks wrong, there are breaks within the curve and also very random spikes which I cannot explain at all..
I tried this code exactly for the Sine Gordon equation and it works perfectly, it just all goes wrong when I try to change the potential.
Here is a picture of the frame:
as you can see it has spikes.. and breaks in the curve as well
Another issue I had was with dealing with the potential on it's own, every time I try inputting
>1/2(u^2)(1-u)^2(1+2u)^2
into maple it changes the expression into something completely different and wrong, it somehow comes out with an exponential of 8.. This is what I get:
(1/2)*(u(1-u))(1+2*u)^8
I also have a problem integrating, I try and plug in a value, i.e.
>int(1/(x(1-x))(1+2*x), x)
but all this does is show me what I inputted but with a integral sign...
I'm very very new to Maple and have spent over a week doing this, but it just isn't working out at all :( Please help!!
I have studied most posts about plot quality, still confused.
When I export 2d graphs and import the to microsoft word, the quality is horrible. How can I presents my results in a reseanably good way?
what command should I add to my code that the quality increase notoceably?
Any suggestion about 3d plots?
If I export as an eps file, how can I import that in microsoft word? I did, but I guess they are not compatibble.
thank you
Hello, I have a somewhat math and Maple question I'm hoping some can help with.
I have this curve,
curve:=alpha^2*beta^10-alpha^2*beta^9+4*alpha*beta^7-2*alpha*beta^6-2*alpha*beta^5-alpha*beta^4+alpha*beta^3-2*beta+1;
and if I solve this system (numerically);
sol:= solve([curve=0,diff(curve,beta)=0],[alpha,beta]);
I get 6 special points (8 actually but two are critical). So I'll refer to them by subscript "i".
If I then do a coordinate transformation by;
alpha=exp(u)
beta=exp(v)
and convert the 6 coordinates and curve, I'll get everything in terms of (u,v) coordinates.
curve2:=subs([alpha=exp(u),beta=exp(v)],curve);
soluv:=map(ln,sol);  (this is just pseudo - I don't know how to do it this way)
So now the 6 points are referred to by (u_i,v_i).
Next, I want to expand this curve locally around these six points, using the following (where "z" is the local coordinate);
u -> u_i + z^2
v -> v_i + sum(a_j*z^j,j=1..n)
where n is reasonable, though around 15.
curve3(i):=subs(u=z^2 + cat(Ubp,i),curve2);
curve4(i,n):=subs(v=cat(Vbp,i)+sum(a[i,j]*z^j,j=1..n),curve3(i));
Here, I'm not sure of the pros/cons of cat() vs a[i,j]....
Anyway, I'll then have an equation in terms of only the local coordinate "z". If I then solve each coefficient of "z", at each order, I should then be able to determine the power series v(z). I reason that since the curve is initially equal to zero, that every non-zero power of z will have a coefficient/equation (in terms of unknowns a[i,j]) that should be equal to zero.
This is analagous to solving differential equations with power series...
However, I'm a little lost in implementing this,
I am currently trying, for instance,
l1:= series(curve4(1,10),z,0,9);
e1:= seq(coeff(l1,z,i),i=1..4):
s1:=seq(a[1,j],j=1..4):
sol:=solve(e1,s1);
I believe I am doing something wrong though bcause every odd power is zero.
Thank you a lot for any suggestions and/or help,
sbh
PS>
Ubp and Vbp are those 6 points - I just kept them as symbols initially because I was still getting odd-powered coefficients as zero, regardless of their actual values. Hence a little bit of the "math" side of the problem...
Hi;
To compute higher-order lie derivatives we need to pass a vector field to LieDerivative(..) function. What follows is the result of LieDerivative(..) command:
To compute 2nd-order lie derivative we should first create a vector field as follows:
L1fh := ((1/2)*(x+u)*(-2*y+2*x)/sqrt((y-x)^2+L^2))*D_x + ((1/2)*(y+v)*(2*y-2*x)/sqrt((y-x)^2+L^2))*D_y + (L^2/sqrt((y-x)^2+L^2))*D_L;
Is there a function to extraxt components of an expression which is the result of the LieDerivative(..)? For example how we can extract the first term. i.e. :
sample code:
with(DifferentialGeometry):
DGsetup([x, y, L], R3);
h := sqrt((y-x)^2 + L^2);
f := evalDG((x+u)*D_x + (y+v)*D_y + L*D_L);
L1fh := LieDerivative(f, h);
simplify(L1fh);
L2fh := LieDerivative(L1fh, h);
simplify(L2fh);
First 1177 1178 1179 1180 1181 1182 1183 Last Page 1179 of 2463
