been struggling on this question for ages:
the questions is as follows is to be solved using maple:
http://www.villagephotos.com/utils/image.aspx?u=2006-11\1228676\piece.jpg
where alpha,beta , sigma are constants . investigate whether it is possible to choose alpha,beta and sigma as to ensure that f is real- valued, continuous and with first and second derivatives at x=0. Plot a graph of any resulthing continous functions f and it's derivatives, over ranger -1<=x <= 1....
Hi, this is what I did and got an error.
with (plots):
col := ["Red", "Green", "Blue", "Orange", "Teal", "Azure", "BlueViolet", "Yellow", "DarkOliveGreen", "DarkRed"]
for i from 1 to 10 do z [i]:=implicitplot (x^((1/(3)))* (y(x)^(2)+ 5* y(x)) + 3 *(x^(2)+y(x)^(2))*sin(xy(x)),  i^(),x = -10...10,  y= -20...20, color = col[i], numpoints = 2000) od:
Error, illegal use of an object as a name    ...
hello ,
I have figured out how to solve for corresponding values but when i try to solve the set of equations by using for example,
a :=[10 values]
b:=[10 values]
w:= [10 values]
##here i want to solve the set of equations for  [a1 b1 w1] ,[a2 b2 w1] , [a3 b3 w1]....like i want to solve the equations for all correponding values of a,b @ each w ##
set of equations (function of a,b,c)
i cant make it work...
I am trying to assign a new value to variable. ie: replace the value of the matrix A by the matrix B.
However, when I try to use the 'new' Matrix A, it doesn't seem to be the value that I expect...
I have two vectors ( A=(1,2,3,4,5,6,7,8), B=(2,7,8) ) and I would like to compare them to see if the elements in B are also in A, and then if they are I would like to remove them from A so I would be left with the following A=(1,3,4,5,6). Is this possible and if so how?
Any help is much appreciated
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/ad_plot_for_derivati.mw .
Download ad_plot_for_derivati.mw
I was asked to derive the corresponding first order equation by differentiating this equation but I have no idea how to. Can someone help me thanks.
The equation I have to work with is x^(1/3)*(y(x)^2+5y(x)) + 3*(x^2+y(x)^2)*sin* (xy(x)) = k
I cannot get Maple 9 Student Edistion to run in Windows 7. I've tried running it in compatibility mode, but it still doesn't work. Are there any software updates or patches available? Is there another Solution?
Hi. Why can't I print landscape from Maple?
I am trying to print my homework, which has some wide tables. The printer I'm sending to has landscape mode, and documents from other programs print landscape. But when I print from Maple, and select landscape, it comes out in portrait.
I am printing from Maple 13. The worksheet was created in Maple 14. I can print to PDF from Maple 14, but that comes out portrait also.
-Jeff
Your answer makes sense if Maple evaluates from innermost to outermost, so the substitution in T2c takes place AFTER Test is evaluated with a symbolic value of "n".
 But it doesn't explain why the "assuming" examples work - or don't work. If "Test" is evaluated first, then none of the examples should work; if the assumption is passed through "simultaneously" (whatever that means), then the wording of the error message doesn't make sense...
Hi there, I'm trying to write an Algoritm to solve a Stable Marriage Problem and have written what I think should work but it doesn't.  Any hints or tips on how to fix it would be greatly appreciated!
stableMatching:= proc(M,W)
 local n,i,j,k,c,d,g,Mm,Ww,s:
    g:=0:
    c:=0:
 with(ArrayTools):
    n:=max(Size(M)):
       Mm := Array(1..n): #stores...
The attached file demonstrates that a substitution into a piecewise function appears (sometimes) to execute the wrong half of the function.
If I use "assuming" instead of substitution, the assumption appears to get through to the piecewise function, but only sometimes.
I don't understand why this happens. Can anyone clarify what is going on? See below.
______________________________________________________________
Dear friends,
I can compute,  with Maple 14, summe1:
> summe1= sum( sum( (`if`(1 < x , 1, 0))*   x*j, x=0..2), j=0..2);
However, when I modify  summe1 to summe2, I get an error message:
> summe2= sum( sum( (`if`(1 < x+j , 1, 0))*  (x*j), x=0..2), j=0..2);
> Error, (in eval/if) cannot determine if this expression is true or false: 1 < j
A simple question.
In Mathematica there is a function Boole:
Boole[expr]
yields 1 if expr is True and 0 if it is
I want to mix nicely formatted text and code, with the ability to hide the code and variable scoping
Something like
Some blah blah
{ First part of code snippet with scope 1
More blah blah
Second part of code snippet with scope 1}
Yet more blah blah
{ Second code snippet with scope 2 }
In Mathematica I would use the "Module" keyword, but there does not seem to be an equivalent in Maple, and I am not sufficiently...
First 1957 1958 1959 1960 1961 1962 1963 Last Page 1959 of 2463
