what can I do I stuck in it,
f:=c1*a+c2*b:
where c1 and c2 is constant of three terms
a,b are variables in x
I have a great problem with maple (cause I'm a beginner)  My problem is When i write the following
for i from 1 to M do x[i]=evalf(a* cos(t[i])) end do;
I get a numbers for x[i], like t[1]=0, then x[1]=3.
until now no problem.
But when i calling x[1] in another place in the same file. i get x[1]=0.
Could any one help me.
Amr
did someone know the program of crout matrix decomposition?!
thank you in advance :)
Hello everybody,
I have a numerical list of points' coordonées defined as :
{P1,P2,P3, ...}
where P1 is defined by [r,theta,phi] radius, azimut, elevation.
Can I plot this in a cartesian coords whitout calculing X=r*cos()*sin() .... ?
Thank's
Dear friends,
A simplified version of my problem now is the following. I need to represent the contourplot in the plan (x,y)  of a conditional double sum:
contourplot( sum(  sum(   (i+j)!/k! * (101-j-k)!/(100-k)!    , j=0..1), k= 0..100), x=0..0.5, y=0..0.5)
where the sum runs under the condition that (j,k) satisfies  (  x+j*y+(1-x-y)/100*k >= 0.5  and  j*y+(1-x-y...
I want one of a sequence of questions to not show it answer. The other questions need to show their answers, but this one
cannot. I could make a separate assignment for this question but that seems rather painful. I use latex => .qu so the
solutions that don't require touching the editor is a plus.
This is probably a simple question for most, but I am not very familiar with programming in maple.  I need to create a program that will find the position of a given value in a list.
Example: L= { 1,3,5,6,7,8,9,11,12}
a)When x = 7
b) When x = 12
etc.
Any help would be appreciated!
Hi;
I need your help:
1- How to improve the implementation of the functions or procedures.? As displayed, is the result of the Matlab function "FromMFile"
2- how to plot the  standard basis vectors in which the cylinder is initially represented.
hi , can anyone tell me what's wrong witht his! please!!
  thank you in advance!
> choleski:=proc(S::array,n::integer)
> local L,i,j,k,t:
> L:=matrix(n,n,0); # matrice nulle d’ordre n
> for j to n do # calcul de L, colonne par colonne
Here a simplified version of my problem.  I want to evaluate the double sum
sum(  sum( k+j, k=0..5), j=1..8);
But I would like to compute the sum only when  the condition    15  >=  k^2  +  j  >= 3  holds.
How can I include that restriction?
Thanks for your help,
Jean-Jacques
Hi All,
Given the partial differential equation of a plate on an elastic foundation, how do I solve the analytical solution for the deflection given the boundary conditions.
This is what I have:
partial differential equation of a plate on an elastic foundation:
> pde := E*(diff(w(r, phi), r, r, r, r)+2*(diff(w(r, phi), r, r, phi, phi))+diff(w(r, phi), phi, phi, phi, phi))+k*w(r, phi) = 0
The solution for w(r, phi) of this is:
Hello dear friends
I have two realted questions
1. How may I generate   a table  n x 4, where in each rows appears
[    n   |   n^2  |   n!  |  n^2 -n!    ]  for n= 1..5 ?
2. How may I export to the previous table/matrix/arrange  to LATEX?
Thanks a lot for the help,
Jean-Jacques.
Having a few problems in working out system transfer functions using the SystemConnect command.
1. I think that there are errors in the description of the function within the HELP file. In the Description there are five bullet points. It is the third bullet point I think has an error. yi maps the global inputs to the global outputs, OK - however the text describes this as 'the number of rows in the yi matrix is determined...
I do not understand why different results are displayed. I would like the solution to be the smallest positive value (ie:4) but cannot seem to do this.
Hi I attempted to plot this but failed... my instructor gave us a list of functions according to our name and when I put them together into an equation to plot I kept getting an error. I included the function list at the bottom. I am using DEtools:
Loading Student:-Calculus1
with(DEtools):
#tangent field for dy/dx = AB + CD where A -first letter of my name, B - second letter of my first name, C - first letter of my surname, D- second letter of my surname, which in my case (Tran Lam...
First 1959 1960 1961 1962 1963 1964 1965 Last Page 1961 of 2463
