I am new to using maple and I have an equation (z:= 7*x[1]+11*x[3]-10*x[4]+26*x[6]) which i would like to turn into a sequence of coefficient of x's i.e (7,0,11,-10,0,26). How would I go about doing this?
Hi everybody;
I have question about my calculation. my questions maybe looks like very simple.
>restart:
>lambda:=-1; alpha:=0.5;  N:=1;  m:=ceil(alpha);
                             lambda := -1
restart; with(Physics); Setup(mathematicalnotation = true):
am := Annihilation(N); ap := Creation(N)
Setup(op = {b[1], b[2], b[3]})
alg := seq(%Commutator(ap, b[i]) = 0, i = 1 .. 3), seq(%Commutator(am, b[i]) = 0, i = 1 .. 3), %Commutator(b[1], b[2]) = b[3], %Commutator(b[1], b[3]) = -Physics[`*`](2, b[1]), %Commutator(b[2], b[3]) = Physics[`*`](2, b[2])
q := %Commutator(Physics[`.`](ap+am, b[2]), b[1])
p := expand(q)
ans := sort(p, [a, b])
Hey folks I have a question about how to use solutions from fsolve in future calculations without copying and pasting.
Here is the code...
Order := 13:
f := x -> -x + x^2 - x^3 + add(a[i]*x^i,i=4..11):
A := n -> coeff(series(f(f(x)), x), x^n):
fsolve({seq(A(k) = 0, k=5..12)}, {seq(a[j], j=4..11)});
Now this gives values of a[k] from a[4] to a[11] but then if I were to type a[5] in the...
I am trying to write my own procedure for the revised simplex method. I have defined my matrix and vectors and obviously my objective function I am trying to optimise. However I am having trouble with programming my entering and leaving variables.
For example I have the sequence 0, -20, 12. I need the smallest positive number i.e. 12 but how do I say this corresponds to the variable x[8] and thus in the simplex method the vector P[8] enters?
If you need any...
I got the range result as limit
ki:= t -> (sum(alpha1(S[j])*(exp(2*I*k*delta*t)-exp(S[j]*t))/((2*I*k*delta-S[j])*Q1(S[j])),j=1..3));limit(ki(t),t=infinity);
where : k,delta are constant and sum(alpha1([sj]),j=1..3) is number
the output is:
-.1294653014455612741589137389024249282843455188351695736221586639528345838460087707530271384645825938-0.8233085340292186435280681029574142108148445032573172243750416705060582056155292536631305980808392462e-1*I...
Hi, I am new to using maple and am having problems.
I have 3 values called R[1], R[2], and R[3] which correspond to 0, -20, 12 respectively. I would like to be able to find and output the smallest positive integer. Is there a maple function to do this?
if i define
r[1]=4
r[2]=-7
r[3]=2
r[4]=-1
how can I find the number r that is the minimum, and define it as x?
so in this case, the minimum is -7 (r[2]), so i would want to define x as 2.
p := (g+Delta*g*Zeta/omega-g*Zeta)*a[1]*b[2]+(g+Delta*g*Zeta/omega-g*Zeta)*a[2]*b[1]+(-Delta*g*Zeta/omega+g-g*Zeta)*a[2]*b[2]+(-Delta*g*Zeta/omega+g-g*Zeta)*a[1]*b[1]
q := factor(add(op(i, p), i = 1 .. 2))
q := g*(omega+Delta*Zeta-Zeta*omega)*(a[1]*b[2]+a[2]*b[1])/omega
here,throuth factor ,simplify the expression .yet,if i want the expression like this:
(g+Delta*g*Zeta/omega-g*Zeta))*(a[1]*b[2]+a[2]*b[1])
how do i?
Hello Maple experts,
I have some problems.  I can show a plot of f1, after assuming  n= 200 [Here x and y are positives and less than 1]
> f1 :=  (x, y,n) -> add(add(  `if` (.5 <= x+j*y+(1/n-(1/n)*x-(1/n)*y)*k and j*y+(1/n-(1/n)*x-(1/n)*y)*k < .5 , (1/(n+1)*(n+2))* factorial(k+j) *  factorial(n+1-j-k)/(factorial(k)*factorial(n-k)), 0), k = 0 .. n), j = 0 .. 1) :
> with(plots);
> listcontplot(...
How would I go about plotting four individual points in three dimensions, all on the same set of axes?  I'm trying to create a visual of a tetrahedron.  Thank you.
Hello. I am trying to do a project for school. But the following code is causing Windows 7(x64) to error. First, I get a message from mserver.exe saying: mserver has stopped working.
I click "Close the program" and I get "Kernel connection has been lost."
This is happening whenever I run the for loop in the attached code. I must get this fixed, people are counting on my code, but I do not know how to fix Maple. I am using Maple 14, build 479326 in Worksheet mode.
Hi. I'm new to Maple. I like the idea, but am rally confused by the interface. Can someone answer a few questions please?
How come this works, but displays wrong (the quotes display):
printf("%5a  %12a  %12a   %12a  %12a  %12a  %12a\\n", "-", "--", "--", "--", "--", "--", "--");
But this doesn't work (replaced quotes with apostrophe):
printf("%5a  %12a...
The following works:
  u+v*w;
  patmatch(%,a::name*b::name +c::name,'p');
  p;
                        [a = v, b = w, c = u]
hi , can anyone tell me what's wrong with this!! please!
thank you in advance!
> crout := proc (A::array, n::integer)
local L, U, j;
L := matrix(n, n, 0);
U := matrix(n, n, 0);
L[1, 1] := A[1, 1];
L[2, 1] := A[2, 1];
U[1, 2] := A[1, 2]/L[1.1];
for j from 2 to n-1 do
First 1958 1959 1960 1961 1962 1963 1964 Last Page 1960 of 2463
