I would like to create a model of a sinngle pendulum with Maple 13
I began but I cannot manage to animate it
Here is what i have already written:
pendulum:=proc(l,initialAngle,initialSpeed)
local eq,sol,angledata,x,y,plotseq
eq:=diff(θ(t),t,t) + 9.81/l sin(θ(t)) = 0;
sol:=dsolve({eq,θ(0)=initialAngle,D(θ)(0)=initialSpeed},θ(t),numeric);
I am trying to get the equation of a line. I have a buch of points and need the equation of a line going through those points. I am making computer program that can finde the y value of any point on the line with the equation I'm trying to get and an X value.
So, I have some points,..
I can get the graph,..but not the equation for that graph...
Is this posable,...?? I can't seem to find out how...
(I put in the points Im using just as are ference)
I don't find an easy way to do what follows.
I've a list of names, with assumptions on them, eg:
assume(a,real);
assume(b,real):
parameters:=[a,b]
then I try do to something like
i:=0;
for what in parameters do
temp:=i;
assign(cat('crlb_', what), temp);
i:=i+1;
end do
because I want to create variables which keep a trace of the parameters they describe in the last part of their name.
ifplease how can i factorise in powers of (x-xn), the expression  y(t):=(1/3h2)[(-x+xn+h)(-x+xn+3h)]yn+(1/3h2)[(-xn+x)(-x+xn+4h)]yn+1 -(1/3h)[(-xn+x)(-x+xn+3h)]fn+2?
i was trying to familiarize with maple 13 but encountered this. pls how may i go out from here?
> with(Student[NumericalAnalysis]);
> DE1 := d*y(t)/dt = y(t)-t^2+1;
                           d y(t)           2
I need to differentiate a postion vector with respect to time and extract the theta dots in the following http://img543.imageshack.us/img543/3079/positionvector.jpg
Many Thanks
How I can, with the help of maple, perform the following demonstration using rsolve?
From Equation : Y(t)=1 +A t + B t2 + D t3
recursively determine t, by equation:
How can I plot this piecewise function:
for j from n-1 by -1 to 0 do
... does some processing that's not really relevant to the question:
s[j] := evalf(a[j]+b[j]*(t-x[j])+c[j]*(t-x[j])^2+d[j]*(t-x[j])^3)
S := t-> piecewise(
x[0] <= t and t <= x[1], s[0],
x[1] <= t and t <= x[2], s[1],
x[2] <= t and t <= x[3], s[2]);
My friends all...
Hi I would like to know how to traverse all terms in a polynomial. I've constructed formal polynomials out of abstract objects. They are all linear, without any cross terms. So I could have something like this:
f = 2a + 3b - c +8z
Ultimately I want to construct a table with the frequency of each element showing up in a random set of polynomials.
I Have a proc that creates some very long lists.
I would like to be able to store each of these lists with the same name in different indexed files.
What I would like to do looks something like...
fd:=["file1.m", "file2.m", ..., "filen.m"]
for i from 1 to n
do
proc(user defined variables)
save variable1,vaiable2, ...,variablem, fd[i]
This however doesn't work.
I would then like to be able then to run proceedures on these variables from each file.
hi everybody!
I have a question. Why my first loop works but the second one doesn't work?
first:
for m from 1 by 1 to 4 do
alpha := m+n:
od;
second:
for n from 1 by 1 to 4 do
alpha := m+n
od;
od;
what is my mistake?
I'm writting a simple program to obtain chi-squared for my model. I've written it for a costant value of "n" and it correctly works and results chi-squared, but when I want to write a loop for "n" then the program doesn't work at all.
I don't recieve any error message. can you help me?
I am trying to solve the the differential equation. for this I have written the following program. But it is showing the error.
with(plots)
eq := diff(x(t), `$`(t, 2))+326.1*(diff(x(t), `$`(t, 1)))+3190*(diff(x(t), `$`(t, 1)))^2-37500*sqrt(x(t)*(0.165e-2-x(t)))+2.825
BCs := [x(0), x(0.2e-1)-0.15e-2]
sol := dsolve({BCs, eq}, {x(t)}, type = numeric)
Maple is saying:
Error, (in dsolve/numeric/process_input) system...
I'm sure there is a simple solution to my problem, but because I'm fairly new to using Maple, I can't figure out why my graph won't work. All I'm trying to do is graph a function along with its first and second derivatives within the same graph. The original function is f(x)= (2+sinx)^x2/(x2+1).
I defined the function as f and then found the first derivative by using df:=D(f...
EulerSystem:=proc(f,g,n,h,tinit,xinit,yinit,t,s,y);
local i;
t[0]:=tinit;x[0]:=xinit; y[0]:=yinit;
for i from 1 to n do
t[i]:= evalf(tinit+h);
x[i]:= evalf(xinit+h*f(tinit,xinit,yinit));
y[i]:=evalf(yinit+h*g(tinit,xinit,yinit));  od;  end;
When i tried to execute maple dispayed "unable to parse" but i can't find out where the syntax error is.  "local" was the word with the red dotted line box around...
First 1970 1971 1972 1973 1974 1975 1976 Last Page 1972 of 2463
