I want to find (-8sqrt(2)-8sqrt(2)i)^(1/4),
I solve it and I got this answers in polar form. (4,5PI/16) (4,13Pi/16) (4,21Pi/16) and (4,29Pi/16)
I tried this in maple, but it didn´t work. z:=((-8*sqrt(2)-8*sqrt(2)*I))^(1/4) ; ec:=convert(z,'RootOf'); allvalues(ec);
(i^1)*(i^2)*(i^3)....*(i^2010)=
I have some problems with pointplot3d command. This text worked in Maple 12 but it doesn't work now...
I have got this "Error, (in plots/tolist) points are not in the correct format".
My text:
with(student):
file := fopen(`C:\\Users\\Kate\\Documents\\ChSU\\New Project Mobile\\Inverted-L antenna\\ILA 900 MHz Analysis\\ILA 900 MHz.txt`,READ):
Data := readdata(file,7):
Data :=convert(Data,array):
N := 30603/3:
How to find all root of this equation with plot function in maple software? h*BesselJ(0,x)=x*BesselJ(1,x) ; h=constant , x=variable
Is there a way to insert a table of content with the headers of the sections at the beginning of the document? (like in MS Word)
If I click on the link, maple should jump to the section.
It should be updated, if I create a new section or change the header.
This is the continuation of the question . We have a convex polygon with 9 (a natural number n>3)  vertixes  such that every its point, which is not a vertex, does not belong to three diagonals of that polygon. The question is:
how to count  the number of the sets of the polygon partition by its diagonals?
I have in mind a Maple procedure, not the formula. The answer is 154.
I just purchased maple 14 for school. I am hoping it will help me understand how to do some calculus problems. My question is, how do I get it to work out all the steps in a problem???
I can enter an antiderivative problem and it will give me an answer to the problem, but not all the steps to answer the problem.
how to use delta operators OR basic  finite difference methods in Maple?
Please guide me
Δ2 f(x) where f(x) = x, h=1
I am a student brand new to Maple.
How can I add a newline in a Maple Input block in Document mode?
Whenever I hit Enter, the code I've typed up to that point - which may be incomplete - is executed. Or, I may need to add a line to some code given to me, but pressing ENTER tries to execute it. (And where in the help system could I find something like that? I looked, but couldn't find it).
This is my beginnig with maple. This program seems to me very cool, and handy in my study. But I have problem. I want to create a document of project where are simple things but I don't how force maple to show counting.
In maple I do:
x:=5
y:=8
x + y = 13
But I want to show how it was counting I want sth likde that:
x + y = 5 + 8=13
I was looking how to do it but I can't find anywhere.
Please could anybody help?
In the chemical and oil & gas industries it is quite common to describe a gas flow in units of standard volume (e.g. normal cubic meters aka NM3 or standard cubic feed aka SCF).
This is really equivalent to a molar flow rather than a volume flow since the volumes are calculated based on the ideal gas law assuming the flow is at standard conditions (1 atm and 0C for NM3 and 1 atm and 60F for SCF).
I would like to add NM3 and SCF to the SI and FPS unit systems.
There is a difference between a variable with an index and a variable name with an index in "2D Math"-Mode.
The variables look similar.
Here an example, what I type and what I get.
a (SHIFT + _) 1:=2
a (SHIFT + CTRL _) 2:=3
a (SHIFT + _) 1 * a (SHIFT + _) 2
a (SHIFT + CTRL _) 1 * a (SHIFT + CTRL _) 2
a (SHIFT + _) 1 * a (SHIFT + CTRL _) 2
And this is, what I get.
I want to determine the domain of definition for an expression using a command,
but i can't find it in the help,
can someone help me,
thanks in advance.
I enclosed solution of 1D heat transfer problem which was solved by MAPLE and MATHCAD 15.
I assume exacly the same data, IC and BC.
Results are different:
Maple - wrong!
Mathcad - right!
I confirmed solution with FEA system.
Could you advice me!
Mathcad_-_PDE_rozwia.pdf
First 1982 1983 1984 1985 1986 1987 1988 Last Page 1984 of 2463
