limit(y(x), x = -infinity) = signum(-8*ln(2)+_C1)*infinity
that was my ouput. I'm just trying to take the limit as x goes to -inf, as you can see.
Does it just mean that my graph is diverging as x goes to negative inf?
thanks!
How would I plot the following complex function?
f(z) = z2 , Domain = {z = x + iy | x < 0 and y > 0}
Im trying to plot the piecewise function that looks like this:
(1-x^2)/((x-1)(x-3)) for x<1 and x>3
x for x=1..3
I have entered the function like this:
f:=x-> piecewise(x < 1, ((1-x^2)/(x-1)(x-3)), x = 1 .. 3, x, 3 < x, (1-x^2)/(x-1)(x-3));plot(f);
And plotting it with:
plot(f);
And then i get this result:
Hello, I'm new to Maple and I'm having some difficulty using the program.
So I'm asked to "Find the numerical (decimal) value of the function h'(x) for x = square root of 2."
I tried typing in: D(h)(sqrt(2.0)); however it returns: D(h)(√2)
I think I may have typed in my prior coding incorrectly.
> h := G(f(x));
> h := unapply(h(x), x);
> dh := D(h);
I tried to run a fairly simple list of commands:
weight := k -> if(k = 2, 1/2, 1)
sum(weight(m+2), m = 0 .. 0)
the expected result should be 1/2 - which is weight(2). But Maple returns 1 for some reason.
Is this a bug in Maple or did a make a mistake in my expressions?
Many thanks in advance
 I was told to "Make a plot of the function h(t) which shows all the intercepts, vertical asymptotes, and extrema that you have determined above." And how might I go about doing this?
I'm using Maple for a math project.  FYI, this is my first time ever using Maple, so I'm a complete newbie.  I'm lucky I even got as far as I did, because had I not stumbled upon the ? function, I'd still be stuck trying to figure out step 1.  Anyways, I entered this into a Maple document:
with(combinat, setpartition) :
P := {1, 2, 3, 4, 5, 6, 7, 8, 9, 10} :
setpartition(P, 1);
setpartition(P, 2);
setpartition(P, 3);
setpartition(P, 4);
I can't find a solution on the internet for this question.
I want to rotate a curve around the x-axis. That means a 3D plot.
Does anyone know how?
I worked a problem in my textbook using maple.I define two differential equations sys1:=[dy/dt=...,dx/dt=...] and its linearize point lin_point:=[...],then using linearize command,I obtained a state space description of the system.Now,I want to using state space description to get transfer function of the system,how can I do it directly without retype the state matrices a,b,c,and d manually?
My computer has 6 GB RAM and works with Windows Seven 7 (64 bits). When I am running my MAPLE program(Version 12), the MAPLE software needs the large amount of memory. But when the consumed memory exceeds over 2 GB, the CPU and computation  stop. Even if I used the Command {kernelopts(datalimit)}, the software did not allow me to use the memory more than 2097100 KB.
Okay I don't know why, but at some point my document went crazy somehow, so I closed it and when I opened it again it was like this ... the whole document, all what I had made, it was in one single line... =/
Just like this:
http://img827.imageshack.us/f/bugallmathinonelinewtf.png/
Can anyone help? Please... if I copy paste it to like word, I get it all shown, so it IS there..
I am trying to get the output listed into a vector or list, but I am unsuccessful. I get the error code "improper sequence". but the expression works:
N:=24
while N>1 do if evalb(type(N,even)=true) then N:=N/2;print(N);else N:=3*N+1;print(N);end if;end do;
The output generated is:
12
6
10
5
16
8
4
I would like to have the output as a list or a vector with two numbers,...
I would like to create a 3D plot using plot3d, however the function I'd like to plot is only defined on the integers and the arguments to plot3D define a range of real numbers.
I woul d appreciate any ideas on how to create this plot.
David
I am trying to solve this set of equations ,but i have spent a lot of time rewriting the equations and changing the signs..but i cant get rid of this erroe and solve it for the unknowns.....could anyone tell me what am i doing wrong ?
I made a model in MapleSim, and I want to analysis it in Maple.
But there was an error when I used the 'get equations' buttom.
and my piecewise equation is
Is there any problem to this equation?
I really didn't know how to solve it.
First 1985 1986 1987 1988 1989 1990 1991 Last Page 1987 of 2463
