I made a model in MapleSim(Fig 1).
Here is the custom element named 'FcF' among the model. Its equation is defined as Fig 2.
I analyses
the model in Maple, the part related with the equation of FcF is shown
as Fig 3.
 I want to solve  matr.mw  for matrix A and B. Although it has 7 equations and 7 unknown parameters, but  doesnt have any result
Reza2961
I made a model in MapleSim 4, and an error occurred after I pushed the
button of 'simulate the model'.Maplesim froze at the step named
'CreateDataRecord: using dsolve method=rosenbrock_dae'. But it was Ok
when this file was simulated in Maplesim 3.
Is here anybody met the same problem?
question.mwWhen I sloving an exercise in my textbook using maple,I had a difficult.
First,I write the differential equation, deq:=[...];then using command,sys1:=DiffEquation(...);I want to get the system transfer function,so I use command tf:=TransferFunction(sys1),but it returns an error[Error, (in DynamicSystems:-TransferFunction) cannot handle input with frequency variable, s].
Then,since TransferFunction...
I always change text color, and I want the color in math mode to be the same as the text mode.  Is there a way to do this automatically?  The math mode always comes up in black, even if the previous text was red etc...
My problem that i just simlply can`t start Maple 12 under Windows 7 x64 in classic worksheet mode.
I like that much and i tried the suggested maplew.exe -cw but i got the same fancy window what i get starting just maplew.exe.
I need help and thank you.
hi, i have an equation and i cant simplify it. i claculate with hand and i know the answer but with maple i cant give answer.
       aa:= sin(theta + tao s) cos(d s) + p d cos(theta + tao s) sin(d s)
        bb:=  sin(theta + tao s) sin(ds) - p d cos(theta + tao s) cos(d s)
                 cc:=         ...
I am not very familiar with maple but have a problem that is probably very easy for an expert. I have the coordinates of three variables, but no specific function of it. I want to create a 3d graph with these coordinates but do not know how. I have done it before with a specific function, but do not know how to do it with solely the coordinates, I work with Maple 12. Could somebody please help me, it is very important for me! thanks in advance,
Hi! I am trying to solve this system:
 but I have a problem.
Y was trying to plot this fuction f(x)=3x^2-2x when x= 0.1,.09,...,-.1 but i can't i'm a new user.
Augh, this is hurting my brain.  This homework assignment (still the same one as before) is my first experience with Maple.  I'm trying to learn the semantics of the language as I go, and that's been going well for the most part, but there's this one thing that has been bugging me to absolutely NO END:  Logical operators.
Here's what I understand after a lot of internet searching and Help browsing:
-There's two sets of very similar operators. ...
I was trying to solve 3 equation with 3 unknown. After solving the problem by Maple, I put the answers in the primary equations and I expected  the result for each equation be zero. I did it just for testing the correctness of answers.  But unfortunatly one of the answer is not zero. What is the problem? I attached my worksheet to this post. Improved_GU.mw
With the bests
Vahid
Got the script below, was trying to plot data from excel in maple and get a curve fitting. i was trying to get the residual meansquare for the curve fitted (last line script), but the script did not return anything. see attached. please let me know what was wrong.
hello
This is what I have written out in Maple, and I have been trying to plot into a graph, but am having no luck at all.  Do you have any advice for what my next step should be. I'm using a simplified version of Brain and Cousens model.
> restart;
> with(plots);
> with(Statistics);
y := (x) -> (d+fx)/(1+h*x^b) , x > 0
b := 2; d := 1; h := 1;
This is the question: Let b = 2, d = 1 and h = 1
The attached document is my Mat assignment. When I open the file, it says that "There were problems during the loading process. Your worksheet may be incomplete." And it only shows a blank worksheet. The worksheet has been created in Maple 13 and modified in Maple 14. The problem occurred then I made the last part of the assignment! Is there any way to retrieve the file?
I hope you can help me...
First 1984 1985 1986 1987 1988 1989 1990 Last Page 1986 of 2463
