Hi everyone,
I'm quite sure that this question has already been answered but I couldn't find any satisfactory explanation (my bad).
I'm wondering why the following expression
 sum(0^k, k = 0 .. 0);
yields 0 as result while
0^0;
returns 1
sum(1, k = 0 .. 0);
also return 1.
I understand that 0^0;
is an indeterminate form so that its evaluation is a matter of convention but Maple's approach...
I want to get the general solution of the Laplace equation with boundary conditions below:
sys[1] := [diff(A(r, theta), r, r)+(diff(A(r, theta), r))/r+(diff(A(r, theta), theta, theta))/r^2 =0, D[2](A)(r, theta0) = 0, D[2](A)(r, theta0+beta) = 0, D[1](A)(R1, theta) = 0, A(R2,theta)=f(theta)];
pdsolve(sys[1]); do not give me the solution
Thank you to help to obtain the general solution and how (the method) to obtain this solution with Maple
the integral int(1/(1-2*r*cos(x)+r^2)^p,x=0..Pi/4), where 0<r<1 and p>1/2, or to find its asymptotics in r as r->1-?
I was trying out piecewise functions as we have a question on them on our assignment. When I did this question in Maple 10 (our uni has this version), I got the answer, but when I type the same thing on Maple14(I use this version), I got the following:
u(x,0) := piecewise(x < -h, 0, -h <x and x <h, 1, h<x, 0);
Error, invalid left hand side in assignment
I know it is something to do with u(x,0...
I made various types of plots with the Plot Builder in Maple 14 and then I continued in the Document editor. When I evaluate the document containing the new plot statements, the Plot Builder dialog pops up repeatedly, seemingly once for every plot I previously constructed in it. This continues even after closing and reopening the document. How can I fix the document so this no longer occurs?
Mac w OS X, 10.4.6, 3.06 GHz Intel Duo with 4GB RAM, Maple14 Student
How can I solve the following differential equation?
with plots
Eq[1]:=diff(f(eta),eta$3)+g(eta);
Eq[2] := (diff(g(eta), `$`(eta, 2)))/Pr+f(eta)*(diff(g(eta), eta));
BCs := [f(0), (D(f))(0), (diff(f(eta), `$`(eta, 2)))(2), g(0)-1, g(2)]
pars := {Pr = 1}
for i to 2 do eq[i] := subs(pars, Eq[i]) end do
eqs := eq[1], eq[2]
vars := f(eta), g(eta)
bcs := op(subs(pars, BCs))
sol := dsolve({bcs, eqs}, {vars}, type = numeric, output = array...
Can I solve the following two coupled differential equations instead of the previous one in Maple 13?
 with plots
Eq[1]:=3*f(eta)*(diff(f(eta), `$`(eta, 2)))-2*(diff(f(eta), eta))^2+3*g(eta)
Eq[2]:=(diff(g(eta), `$`(eta, 2)))/Pr+f(eta)*(diff(g(eta), eta))
BCs := [f(0), (D(f))(0), g(0)-1, g(25)]
pars := {Pr = 1}
eqs := eq[1], eq[2]
No that way I could have chosen infinity at 10 or lower values also. f ' will go from 0 to 0 through positive values only. But how can I claim then that my solution is infinity independent. Because if I change the value of infinity whole solution changes.
Moreover at 15.6 the value of f ' is sufficiently close to 0 but value of g (0) is about 0.15 which is far greater than 0. g (0) goes to zero at about eta=25.
So  can I get rid of the problem?
Is it possible to use Maple 13 to illustrate synthetic division?
I'm currently solving three equations in three unknowns. I was wondering if it's possible to let Maple using the solutions by assigning the values of the parameters. For example:
solve([eq1(x,y,z) , eq2 (x,y,z) , eq3(x,y,z)] , [x , y , z]);
let's say we get: x=2 , y=5 , z=8.
Is there any way I can get Maple to assign values x:=2; y:=5; z:=8; automatically?
Christian
I'm currently attempting to solve a non-linear programming problem. I get the message "Warning, limiting number of major iterations has been reached". Is there any way in which I can increase the number of iterations? Thanks, Christian.
I tried to solve two coupled non-linear ordinary differential equations that arises in case of natural convection from an isothermal vertical flat plate. The problem is a boundary value one. The boundary conditions for the problem are at eta=0, f '(0)=0, f(0)=0, g(0)=1 and at eta=infinity f '(eta)=0, g(eta)=0. f ' should go from zero to zero through positive values but after a certain value of eta f ' is going to negative values until the value of eta =infinity at which it...
fc := exp(btp*s*cos(2*Pi*x/a))*exp(-(I*2)*Pi*n*x/a)
int(fc, x = 0 .. a)  assuming a > 0, s> 0, btp > 0, n::integer;
Is there any way with "pdsolve" or 'dsolve' to get the general solution of Laplace equation in polar coordinates with boundary onditions as :
restart:sys[1] := [diff(A(r, theta), r, r)+(diff(A(r, theta), r))/r+(diff(A(r, theta), theta, theta))/r^2 =0, D[2](A)(r, theta0) = 0, D[2](A)(r, theta0+beta) = 0, D[1](A)(R1, theta) = 0, A(R2,theta)=f(theta)];
pdsolve(sys[1]);
How do i use Maple to find all the pairs of consecutive primes between 2 and 500, that is, all the pairs (n, m) such that abs(n-m)
First 1980 1981 1982 1983 1984 1985 1986 Last Page 1982 of 2463
