Hi all, I'm new to Maple T.A. 5.0 (I have about a weeks experience with it) and I'm wondering how to utilize the Keyword search function. When I go to Question Repository there seem to be 4 categories that I can search from; Groups, Type, Keyword, and Information Field. I understand how to use all these search options, save Keyword. Is there a way to assign a keyword to a question or a group so I can search by it? And if so, can someone please tell me how to do it?
Hello.
At first, sorry for my poor english.
I am seeking, since a long time, a way to intersect a straight line, horizontal or vertical, and a sequence of plots, which describe a closed figure.In order to calculate the area.
In one way, i want to seek points describe by:
the taylor series of a function
g(x) = f(x + a * f(x)) around a point x = x0 is given as (hoping i am correct)
g(x) = f(x0) + f'(x0) * (x+a*f(x) -x0) + f''(x0)/2 * (x+a*f(x)-x0) + .... ------------(********)
but using the command
taylor(f(x+a*f(x)),x=x0,4)
gievs
f(x0+a*f(x0)) + f'(x0+a*f(x0)) * ....
 something which is different ...
how to get (***********)
I am working on the system model of an impulse radar.  My primer aim is to simulate the received signal. I use signal components and some simple elctrical circuits in the Maplesim model. First version of the system works fine, but I'd like to develop it.
I have the following problems:
- I don't find a way to put a time-delay in the system (in time-domain or in s-domain in the form of' *exp(-s*T)' )
- It seems to me that there is no direct way to add noise to the system (like Gaussian...)
Given a list of values L:=[a,b,c...] how do i order the list from highest value to lowest?
Relatively new to Maple - just been playing about with basic trig. But when I try to plot a straightforward tan(a) I get something that's clearly not tan(a). sin and cos(a) behave as you'd expect. What am I doing wrong? It makes me worry about other plots I've suspected were wrong...
Dan
I am using plot3d for the first time. It is cutting off the z-axis under certain rotations (both the axis label and the top of the plot). I am using Maple 11.01
Has anyone else experienced this problem, and how do I fix it?
thanks.
Can anyone tell me how to delete a set of questions? Yes it is clear how to delete one question. In earlier versions, there was a two step process in importing a question bank; one could import the question bank and then logout without  'saving' it if one did not want to keep the questions. When I import an existing question bank into v5, it seems to automatically save the questions. I now have a couple of hundred questions i want to delete!! The user guide on page...
The function I am attempting to plot is:
z(x) = z0 −(v1/g)*ln(cosh(g*x*60/v1))
where z0 is an initial value of 2000 at t=0, g=9.81, v1= 14.9165
my code is then
zx := 2000 - (14.9165/9.81)*ln(cosh(60*9.81*x/14.981))
plot(zx, x = 0..38)
However it seems to stop plotting values after x=19, even though putting values above 19 into zx will return you a numerical answer. Any help on this would be greatly appreciated.
restart; assume(x > 0); solve(x^2 = 4, x); fsolve(x^2 = 4, x)
I use this order, and want to get x=2, but the result is
suppose we want to find a curve
a * x * y + y + b * x + c = 0
given the following conditions:
y(x) = f(x)  and y'(x) = f'(x) and y(m)= f(m)
how to find a , b and c in terms of f, f'...
x := `<,>`(`<|>`(x[1]), `<|>`(x[2]), `<|>`(x[3]))
x := `<,>`(`<|>`(x1), `<|>`(x2), `<|>`(x3))
when input a matrix like this,the subscript seems be not embodied in the results
with this tool you can draw shapes and plots by ascii characters www.jave.de/
I interested to know is there any technique in maple for doing similar jobs like this ...
First 2080 2081 2082 2083 2084 2085 2086 Last Page 2082 of 2459
