x := `<,>`(`<|>`(x[1]), `<|>`(x[2]), `<|>`(x[3]))
x := `<,>`(`<|>`(x1), `<|>`(x2), `<|>`(x3))
when input a matrix like this,the subscript seems be not embodied in the results
with this tool you can draw shapes and plots by ascii characters www.jave.de/
I interested to know is there any technique in maple for doing similar jobs like this ...
I want to solve the problem as follows,
What's the deal here? When I load Tools>Load Package>Units I get those brackets on the left side of the document along with a red >. I never got them before and now they show up on every new document. Not a big deal, I suppose, but when I hit the !!! the brackets and red >s start to proliferate. A couple more clicks of !!! and my worksheet is covered in them. I can't help but suspect, also, that this is related to the error message I get at the end of this worksheet.
Hi I will appreciate some help
I am trying to find the algebraic solution of the equation and want to express z in terms of c
z1 := 819*z^6+(-396+396*c)*z^4+306*z^3*c+(63*c^2-126*c+63)*z^2+(90*c^2-90*c)*z+6*c^3-9*c^2+18*c-6;
i use solve(z1=0,z) but i got
[z=RootOf(273 _Z^6+(-132+132 c) _Z^4+102 _Z^3 c+(-42 c+21+21 c^2) _Z^2+(-30 c+30 c^2) _Z-2+2 c^3-3 c^2+6 c).
Can anyone help?
can anyone help me with code to convert a matrix that is not diagonally dominant to the one that is diagonally dominant
check out this deq:
y=2*x*y''
Maple says it's an Emden/Fowler deq with the following form:
Emden_Fowler_ode := x^p*p*(diff(y(x), x))/x+x^p*(diff(y(x), x, x))+x^sigma*y(x)^n = 0;
I tried to change the parameters p,n,sigma so that it describes my deq, but it does not completely fit.
I use n=1,p=0,sigma=-1 and i get
y=x*y''
How do i get in the missing constant 2 ?
Maple solves it correctly by the way.
Hi all I see it is very easy to define a simple function in Maple using -> But what if more than a single expression is needed and if local variables are needed ? Is there a way to put several statements and use local variables in a function definition ? For example to define a function that takes a list as it's argument and returns the arithmetic mean or the simple sum. Must such things be done with a procedure ? Thanks !
after differentiating a function that contains a product and summation using a counter i=1,2,...,n and j=1,2,...m    i got a result that contains things like these :-
sum from i1~=1  to  i-1    and  i1~=i+1  to  n
and i had in the function a variable z[i][j]  and in the result it became  z[i1~][j]
what does 1~ means ?
thankx in advance
I have a lie algebra, e.g. sl2 or sl3. Elements of these algebra may look like  Qs, where x indicates a Generator of the lie algebra and 's' is a further index. On this latter index there are conditions, for example:
For all x and s with s>1: Qs = 0.
In addition, under the lie algebra commutation relations, 's' behaves for example as:
[ Qs, Qr] = Qs+r.
So I followed the exact example as in the Maple help for "Matlab[evalM]" which is reproduced below (with my result, which is nearly identical to that in the help example)
Consider the identity 4*cos(theta)^3-3*cos(theta) = cos(3*theta). Does maple know about it, or how to prove the identity, which is true by deMoivre's formula, with maple? The trig option for simplify seems not enough. Thanks.
How can I assign all diagonal elements to 1 for a matrix ?
Hi all I have > tst:=-(1-cos(p))/p^2+1/2*cos(1/4*p)^2*cos(1/8*p)^2*cos(1/16*p)^2: >plot(tst); which seems to work OK. However, this generates an error plot(tst,Pi..2*Pi); Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct Plotting error, empty plot ...as does any other range I have tried. I guess it's something very simple, but if someone can point me in the right direction I would appreciate it !
I want to find a way that which results in that all variables in a procedure becomes local
ie  X:=proc() local All
I find it tedious having to specify all the local variables individually
ie  X:=proc() local A,B,C,w,e,r,t,y,u,ui,io,w,,u,i,o.....eternity
First 2081 2082 2083 2084 2085 2086 2087 Last Page 2083 of 2459
