5^2^2^2^2   I get a rediculously large number where in the middle it has [...45608 digits...] why am I unable to right click and use the explore option to view this number?  How do I explore this number?
question1:
\  Escape next character for entering "^" and "_"
I don't know what's this mean.
Is there a method to work with Reals or Complex modulo Integers (need not
to be modulo a discrete group, circle or torus is fine for me)?
Where the residue class is represented in the unit interval or square (as
the command modp does in the finite case)?
What I have in mind is to modify 'argument' to 'argument modulo 2*Pi', but
mod is for integer cases.
Hi i am trying to code the Merge sort algorithm in maple but i've reached a point where i can't progress further. Any assistance would be greatly appriciated.
This is what i have done so far
FIRST ATTEMPT:
with(ListTools):
L := rtable(1..6,random(1..50));
n:=convert(L,'list');
E:=[LengthSplit(n,nops(n)/2)];
for j from 1 to nops(E) do
F:=[LengthSplit(E[j],1)];
d:=[]:
smallest:=op(F[1]):
for i from 1 to nops(F) do
if op(F[i]) < smallest then
Dear all:
     i want to useI[pk] := 10as a variable, but the maple show the following error message: " Error, illegal use of an object as a name" .
    So can anyone tell me how to solve this problem. tks very much
Andy
I want to learn more about ImpulseResponse functions and the ImpulseResponsePlot in Maple.
Could anyone please explain how it works ? I want to start with a simple example ie
a simple transfer function which is very easy to understand.
with(DynamicSystems):
sys1 := TransferFunction(s*(s-1)/((s+2)*(s+4)*(s+6))):
ImpulseResponsePlot(sys1, 2);
Hi, I want to count how many numbers in a list have a certain property. I tried something like
add(i->if i < 2 then 1 else 0 end if, i in list)
but this doesn't work. How do I do this?
Hi I am trying to create a bit of code that fits data points to a curve
right now I have
with(statistics):
NonlinearFit((   (A/2)/((B-r)^2+(A/2)^2)+C1+C2*r+C3*r^2),WEE,dde,r);
where WEE and dde are vectors containing the X and Y values respectively.
I was wondering if there was any way to set a range of values that the parameters can lie between
for instance
0<A<1
and  -3<B<3
I was wondering how to build that into the code
Hi everybody, I would like to plot a function, e.g. f=f( x(t) ), versus t. i.e. f=f(x) and x=x(t). Please let me know how I can do it. Thank you, Hamidreza,
for which function f(x) the expression is minumum
(diff(f(x), x, x, x, x))*(diff(f(x), x, x))-(1/2)*(diff(f(x), x, x, x))^3
I have Maple 13.02 on an Acer Aspire 5532 (64 bit) and there are some severe problems with plotting curves using spacecurve, DEplot, or any plotting method that plots curves. When the option is set for anti-aliasing, I get curves like this: and when anti-aliasing is turned off, the curves look like this:
Under what if any conditions is it permissible to take the limit through/under the integral sign? For example the following maple commands
> assume(t > 0)
> limit(int(f(t)*exp(s*t),t = 0..infinity),s = infinity)
seems to imply that this really is a permssible operation.
I want to write  K^(p-1)*L^(-p+1)   as   (K/L)^(p-1)  .
How can this be done with maple command without simply typing it ?
if you google for Mandelbulb or look at this link:
http://www.skytopia.com/project/fractal/2mandelbulb.html
you find some nice render pics. To program this in Maple, the complex number z in the "usual" mandelbrot iteration z->z^2+c needs to be replaced by... a vector from R^3 ? Or do i need quaternions ? A source for an algorithm would be welcome.
Hi, I need to generate 100,000 numbers randomly (bounded by 0 and  t) and plot the distribution of the distance of two subsequent numbers. I tried it with a large array:
First 2083 2084 2085 2086 2087 2088 2089 Last Page 2085 of 2459
