Why does the equality fail to hold in case of a positive geometric density (with the location parameter v=1,2,... if in general)? What's wrong: symbolical result or numerical evaluation? Thanks.
with(Statistics):
X := RandomVariable(Geometric(p))+1; M := Mean(X); A := simplify((X-M)/M, size);
Mean(1-A+A^2/(1+A))/M = (Mean(1)-Mean(A)+Mean(A^2/(1+A)))/M; is(%); subs(p = 1/3, `%%`); simplify(%, size); evalf(%)
I would like to pass a string array to an external FORTRAN function, can this be done without generating wrapper code...I don't have a FORTRAN compiler...
The Fortran datatype is
  character*255 hf(20)
In FORTRAN I would pass say "hf(1)='nitrogen.fld'", but I'm not sure what datatype to use in the maple define_external function or how to pass the data in?
Here are four differential equations that I need to plot with respect to time. Our teacher wants us to use Euler's method in maple 13 to do this but we have no prior experience and I have no idea where to begin. Any help would be appreciated. The step needs to be relativley small. Below are the numerical values for the constants, the four equations and the intial values for the equations.
I have a system of PDE's - 14 equations.  I am trying to solve for 9 functions in terms of other functions.  I thought I was doing this correctly.  I have:
This is a follow up to my previous post. I have a set of equations I need to solve namely: x1''(t) - 3/85 * sin(wt) = -2k1 + k2 x2''(t) = 12/85 * sin(wt)*(k1 - 2k2 + k3) x3''(t) = 12/85 * sin(wt)*(k2 - 2k3 + k4) x4''(t) =12/85 * sin(wt)* (k3 - 2k4 + k5) x5''(t) =12/85 * sin(wt)* (k4 - k5) I tried using the code: eq1 := diff(x1(t), t, t)-(3/85)*sin(w*t) = -2*k1+k2; eq2 := diff(x2(t), t, t) = (12/85)*sin(w*t)*(k1-2*k2+k3); eq3 := diff(x3(t), t, t) = (12/85)*sin(w*t)*(k2-2*k3+k4); eq4 := diff(x4(t), t, t) = (12/85)*sin(w*t)*(k3-2*k4+k5);
How can I persuade Maple to move a constant factor outside the summation so that
sum(k*x[i], i = 1 .. n)
simplifies to:
k*(sum(x[i], i = 1 .. n))
And how do I persuade Maple to reorder the summation from this:
sum(x[i]+y[i], i = k .. n)
to this:
sum(x[i], i = k .. n)+sum(y[i], i = k .. n)
The reason I am asking is that I am trying to use Maple to show that:
I need help solving a set of linear equations in terms of the variables. I have:
x2''(t) = k1 - 2k2 + k3
x3''(t) = k2 - 2k3 + k4
x4''(t) = k3 - 2k4 + k5
x5''(t) = k4 - k5
I want to solve this system for k1..k5 in terms of x''(t) and sin(wt). How do I do this? I am so lost!
sys1:={diff(x1(t),t)=(3+5*I)*x1(t)-sqrt(2)*(cos(3)+I*sin(3))*y1(t)-2*I*z1(t),diff(y1(t),t)=conjugate(x1(t)),diff(z1(t),t)=0.25-0.3*z1(t)-2*I*(x1(t)-y1(t))}:
sys2:={diff(x(t),t)=(3+5*I)*x(t)-sqrt(2)*(cos(3)+I*sin(3))*y(t)-2*I*z(t)-2*I*(cos(5*t)-1)*z1(t),diff(y(t),t)=conjugate(x(t)),diff(z(t),t)=0.25-0.3*z(t)-2*I*(x(t)-y(t))-2*I*(cos(5*t)-1)*(x1(t)-y1(t))}:
I got I variable in Maple defined as   e := ((w-b)/b)^lambda;
I know that     prof := f(e)-w*L;     where f(e) is some unknown function   and that    isolate(diff(prof, w) = 0, w) = -b/(lambda-1);
How can I find the expression for f(e) ?
i am a biggener in maple and have a homework to be solved and i do need help if possible.
well i would like to fit a given function to a set of given points.
By mistake I managed to delete a group with several questions in it. How can I get access to the questions?
I have two graphs but can't work out how to put them together. Anyone have any idea? Below is my program
C1(u):=u*FresnelC(u)-((1/Pi)*sin((1/2)*Pi*u^2));
S1(u):=u*FresnelS(u)+((1/Pi)*cos((1/2)*Pi*u^2))-(1/Pi);
S1:=unapply(u*FresnelS(u)+((1/Pi)*cos((1/2)*Pi*u^2))-(1/Pi),u);
C1:=unapply(u*FresnelC(u)-((1/Pi)*sin((1/2)*Pi*u^2)),u);
R0:=0.7;
R1:=1.5;
evalf((R0+R1)*(((Pi*C1(1))^2+(Pi*S1(1)+1)^2))^(1/2));
T:=1.8;
A:=fsolve(T=(R0+R1)*(((Pi*C1(B))^2+(Pi*S1(B)+1)^2))^(1/2),B,0..1);
a0:=evalf(Pi*R0*A);
I have a dataset.  For example
with(Statistics):
a := [0, 7, 0, 7, 20, 18, 34, 34, 35, 35,1, 7, 10, 6, 7, 5, 4, 7, 7, 2, 6, 2, 22, 2, 3, 12, 12, 14, 10];
Histogram(a,frequencyscale=absolute);
How do I create a smooth line curve through the points.  Also it doesn't seem to bar graph properly, the 0's and 1's are combined and the 35's and 34's are combined.  Not sure why that is.
I'm trying to launch Maple via batch from another program...but results are negative. My operative sistem is Windows XP 32 bit.
I create a file nome.mpl that read an input.txt, makes some manipulation, and write results on output.txt. If I double-click on nome.mpl icon from the folder where all file are stored, all it's OK: MS-DOS shell open and after few second output come created with exact result.
But I need to launch this little program from another software for once, twice, any numer of time I need.
I have a vector field F = (x-y) i + xy j. I need to evaluate the line integral of this vector field on a curve C1 given by y = 5/2 - 13/12* x - 3/4 * x^2 + 1/3 * x^3 on -2
First 2091 2092 2093 2094 2095 2096 2097 Last Page 2093 of 2459
