How do i code into maple to check if a matrix is diagonally dominant?
s:=Matrix([[2,1,2],[-5/4,-5,5/4],[21/5,-14/5,7]]):
s[1,1];
s[1,2] + s[1,3];
this is what av done so far but i dont think its correct
for i from 1 to 3 do
for j from 1 to 3 do
s[i,i] <= s[i,j] + s[i,j+1]
od:od:
hello everybody,
Just a little question about lists.
I have a result like this
Result := {alpha[2] = -1.536774530, alpha[3] = -2.345615736};
How to select -1.536774530 and -2.345615736 ???
If I do Result[1];     it return alpha[2] = -1.536774530.
Many thanks !!!
Ternox
How do I label something without having to have maple evaluate it first?
For instance I would like something like this
to be labeled on the right side, when i try it just retuns false.
I defined five functions f[i] and three functions u[j].
Afterwards I integrated f[1]*u[1] for x=-infinity..infinity and defined it as E[11].
Then I defined an equation eqn[11] := E[11] = u[1]
Last but not least I solved eqn[11] to x. So far my doing was none of a problem and produced the expected result.
Then I wanted to let maple do this procedure with all combinations of f[i] and u[j].
So I wrote the following nested for loops:
Maple is plotting the first plot, but at the second, it tells me
and plots nothing. What did I do wrong?
rect := proc (t) options operator, arrow; Heaviside(t+1/2)-Heaviside(t-1/2) end proc
plot(limit(rect(t/T-1/2)*cos(t), T = 5.5), t = 0 .. 7)
I want to integrate a function which includes a proc. For example
P:=proc(t,w::list)
local v;
v:=choose an element from the list w, according to the value of t
return v
end proc
and my integrand is like this:
F:=(a,b,c,d)->a*b*c*P(d)
I'm trying to get a plot of f(x)=x^1/3 that shows the plot line (i.e. f(x) values) for x<0.  I can get the graph to show the entire four quadrants, but not plot the values for x<0.  Any help would be greatly appreciated, as I just purchased the student edition.
I have a problem i am trying to see how long it takes for my program to give a solution but the time keeps on changeing everytime i press enter. I can't seem to understand why?
I am going to export formulas from maple to plain texts like this sample ! Download 11273_plain.txt
View file details but , i confused about this simple job , please someone disabuse me , how can i do it ?
I'd like Maple to simulate airflow over a specified vehicle shape, and get it to display something similar to this.  ...
arghh.  Can't get pictures to paste, sorry.  So far I've never been able to insert a picture, haven't had the need and so haven't worried about it and now when I want to insert a picture, it's not just a straight forward thing.  Any help with that would be apprecited.
Hello all,
Am a very new Maple user (installed today), so please bear with me! I need urgent help with the following:
I am trying to simulate polymerization of PMMA and have the following problem:
(1) I have Temperature-time data, measured experimentally.
(2) I want to fit my model which gives me a relationship between the rate of change of temperature (dT/dt) and the temperature in terms of a number of parameters:
dT/dt = Q*[Z*{exp(-E/R*T)}*{a^m}*{(1-a)^n}*{1-a}]
where,
a = P/Q + a0
Here,
Hi all first time posting on mapleprime so be nice ;) I can't seem to increase the font size of the numbers at the axis. If this is possible how do i do that? - moL
> restart; with(DEtools); with(plots); > eq := diff(y(x), x) = x^2+y^2; > S := solve(eq, diff(y(x), x)); > P1 := DEplot(diff(y(x), x) = S, y(x), x = -1 .. 1, y = -1 .. 1, colour = red); > display(P1); That is what I have so far, but now I need just the slope field corresponding to the initial condition y(0)=1. Any help you can give would be very much appreciated.
How to achieve that Maple, decompose the equation:
Diff(x,t,t)+3*Diff(x,t)^2+5*x=1;
                        / 2  \            2
I am helping a friend on this. We would like to evaluate the
convolution of
f(x)=exp(3 * x) / (1 + exp(x) ^ 5).
However, in Maple and Mathematica, using symbolic calculations, after computing the integral in closed-form, the
convolution results in numerical oscillation (lots of spikeness). We
don't know why. We just couldn't get rid of the spikeness.
First 2095 2096 2097 2098 2099 2100 2101 Last Page 2097 of 2459
