I want Maple to execute the following code over and over again (exepct for with(combinat) of course)
with(combinat):
unassign(anames(user)):
How do I answer this question using maple?
For the curve of intersection of the surfaces
5xzy + xyz + 10e -98 =0
tan(xyz-2) + ln(3x + y + z -7) =0
find at the point (2,1,1)
a) T (unit tangent vector)
b) dT/ds
c) k (curvature)
d) N ( unit normal vector)
e) B (binormal vector)
f) dT/ds
g) t (torsion)
How to get from the differential equation:
diff(x(t), t, t)+c*(diff(x(t), t))+k*sin(x(t)) = 0;
print(`output redirected...`);               / d  / d      \\     / d      \
              |--- |--- x(t)|| + c |--- x(t)| + k sin(x(t)) = 0
Hi, how can I generate (and plot) an array of points that are defined by a recursive formula, for example the points specified by
Hello colleagues,
Here I have for you two questions:
 How to learn to see the indexed variables, whether they are literal or standard? Without the need whattype:
whattype(x[2]);
                                   indexed
whattype(`#msub(mi("z"),mn("1"))`);
Hi all, Is there a feature in Maple to collaborate? I mean: is it possible to work at the same maple file from 2 different computers simultaneously and join the results? It would be great if there's the possibility to work in real-time together, but comparing the files after editing and combining the changes to both documents in one Maple file is already satisfying. Thanks in advance for your advice. Giel
I am looking to plot3d a triple integral, and i seem to be having difficulty. I am using Maple 12 and the cod as follows.
EX:
plot3d(int(int(int(y,z=0..5),y=0..5),x=0..9));
Is there a way to use maple to plot the vector field for the differential equation: (x,y)' = ( sin(pi*x) , xy - 1 ) ? Note (x,y)' is a vector, that would normally be written in column form. I'd really appreciate any help you can give, thank you.
I've run into a problem with Maple. When I solve a trigonometric equation, for instance sin(x)=0, it responds with only one solution, even though there are countless. So what I mean is, when I type: solve(sin(x)=0,x) -> x=0 x = 0 is of course correct, but I would really like it to give the general form of the solution for such an equation. My TI CAS calculator responds with this general solution set: x=c*3*pi , where c is a random integer, Z, (any whole number). Is there any way to make Maple give such a respond as well?
View 10874_ode.mw on MapleNet or Download 10874_ode.mw
View file details
I have an ODE that has to be solved over a range of x .....but i have difficulties in formulating the boundary conditions since i have certain constraints on them.
My B.C 1 is t(x) = c + (c-1)*erf(x)
B.C 2 is t ' (x) = (c-1)*(2/sqrt(pi))*e^-x2
I want to tell to Maple how much centimers should be the windows of the plot output (or, even better,  of the grid, without considering the labels and title)
So that if I write for ex
I want to print A with 2 seconds interval from the moment I call x:=true until the moment I call x:=false.
How can this be done in Maple ?
Hi all.
Ok, I'm trying to save to a file a set of a complex number, a float number and an integer. According to Maple Help this can be done with:
writedata[append]('terminal',[-0.123456-0.123456*I, 0.1334423423*10^(-15),3], float, proc(f,x) fprintf(f,`%a`,x) end proc);
And it works (the numbers are just an example of what I'm trying to do).
The problem is that I want to change the precision of the second number (or to all of them) to say 5 digits. But when I try as the help suggests:
How can I plot two boxes with gnuplot in 3 Dimensions, one small box inside one big box?
I know that it is possible with
plot3d(Polygon([[x11, y11], ...[xln, yln]], [[x21, y21], ...[x2n, y2n]], ...[[xm1, ym1], ...[xmn, ymn]])
but how can I do with mathematical equations?
How do I use print command to display command such as simplify(..,symbolic)?
I have tried
interface(verboseproc=2):
print(simplify);
but this only display simplify command, not  simplify(..,symbolic).
First 2093 2094 2095 2096 2097 2098 2099 Last Page 2095 of 2459
