I have a set of simultaneous equations that can be solved using odeplots in Maple.
The problem I have is that i need to understand the chaotic dynamics of this system and to do this i must increase an angle by a tiny amount which boils down to subtracting 1 odeplot from another, how do i do it?
many thanks
f(z):=x^(n)+I y^(n);
diff(f(z), x)=
x^n*n/x
simplify(x^n*n/x)=x^(n-1)*n
plot(e^x*tan(x), x = 0 .. 1)
plot(evalf(e^x*tan(x)), x = 0 .. 1)
question2:
sin(0)=0, why this is not sin(0)?
sin(1)=sin(1)?
I need to use the D Operator for the following:
I need to formally partial-differentiate a given arbitrary function G(z,w) with respect to two other variables z=z(s,t) w=w(s,t) and then to express the p-th-total-order partial derivatives of z with respect to s and t as a polynomial in the partial derivatives of G with respect to z and w and the partial derivatives of w with respect to s and t, divided by the partial derivative of G with respect to z raised to the power 2p+1.   The eliminate function allows me to eliminate all partial derivatives of z w.r.t. s and t of total order lower than p.
Suppose we have:-
x = a * e  + (2*b - 3*a^2) * e^2
Now let us find functions:
F(x) = 1 + a * e + (2 * b - a^2) * e^2 + ......
we are just interested in the first three terms.
Now two such functions can be:
F1(x) =  1 + x + 2 * x^2
F2(x) = (1-x)/(1-2*x)
How can we find all such functions F(x)?
I have a 3-dimensional dynamic system of ODEs characterized by zero eigenvalues at the origin. I would like to know if it's possible to find one trajectory converging towards the origin.
My system is derived from a control problem and has consequently control-like and state-like variables -- while the neighborhood is typically unstable I need to know if an appropriate choice of initial values can steer the system towards the origin;  I expect at most one such trajectory.
Is there a way to set a default header for every new maple document?
hi everyone. i am a complete beginner to maple, have used it for about 1 hour in total.  could you take me through step by step how to solve coupled equations please. for example:
3x+5y+7x=25, 4x-2y-3z=15, x+y+z=0
to obtain solutions for x, y and z
any help is very appreciated. thank you
What's the difference between VerticalBar and VerticalLine?
we have:
x = c[2]*e/c[1]+(2*c[3]*c[1]-3*c[2]^2)*e^2/c[1]^2+(3*c[4]*c[1]^2-10*c[2]*c[3]*c[1]+8*c[2]^3)*e^3/c[1]^3
how can we find a function "F(x)" the first three terms of whose power series around "e=0"  is given as:
1+c[2]*e/c[1]+(2*c[3]*c[1]-c[2]^2)*e^2/c[1]^2
I'm try to access some external Fortran routines within maple. I have a Fortran datatype of
  character*255 hf(20)
This is an input parameter, and I believe this will map into a maple Array object, but I'm not sure of the datatype. The help says that the datatype can only be "hardware datatypes" so I take to mean it would have to be of type integer[4]...when I do this I get the error below.
I am interested in computing the image of a constructible set in Maple.  I am using Maple 12 on a remote machine.  I am able to load the ConstructibleSetTools, ChainTools, and RegularChains libraries.  This paper indicates that the authors were using Maple 12 and have defined the RationalMap command.
Just a question about presentation.
If I have  a program like this:
for i to N do
for j to N do
i+j
od;
od;
How to show it like this?
for i to N do
   for j to N do
        i+j
    od;
od;
I have tryed some compositions with the keyboard but "everything doen't work".
Many thanks,
Ternox
First 2094 2095 2096 2097 2098 2099 2100 Last Page 2096 of 2459
