I'm new with maple and I can't seem to fix my problem. I want to enter in a textbox1.text in Visual Basic, a function -cos(x) for example- and calling a maple procedure to differentiate it and print it in textbox2.text
I've tried EvalMapleStatement and tried also to convert from maple object the result of diff() function with MapleToString.
Maybe you can also tell me what sort of result returns the function diff(). VB recieves only some numbers that are different for every function I input in textbox1.text from what i've done here.
who can help me with following question?
Write a procedure MULTIPLYMATRIX to find the
multiplication product of an h x i matrix and an i x j matrix.
that is what I do. is it right?
mult := proc (A, B, C::evaln) local h, i, j; h := LinearAlgebra[rowdim](A); i := linearalgebra[coldim](A); j := linearalebra[coldim](B); A := array(1 .. h, 1 .. i); B := array(1 .. i, 1 .. j); C[h, j] := `&*`(A[h, i], B[i, j]) end proc
Is it possible to change the x_axis to an expanded scale for values less than zero, and keep the regular scaling for positive values?  In other words, display the x-axis from  -1 to 0 using all the real estate on the left side of the y-axis, and 0 to 10 on the right side.  Ratch
While looking at a Maple demonstration, it appeared to me that a intricate math expression was cut and pasted or dragged somehow into the text field, or next to a text field of a plot to become part of its documenation.  The demo went so fast.  When I try that, it does not work.  I can easily annotate the plot with text and math expressions if I type the math expressions manually, but I was hoping to bring the math expression in from somewhere outside of the plot.  Is that wishful thinking, or is it possible?  Ratch
hey everybody...i need your help
we have to define monotony interval of polynomial functions
i only managed to solve roots from the first derivative
does anyone have a clue ??
Give an example of a 3x3 matrix having only two eigenvalues, one with corresponding eigenspace of dimension one and the other with corresponding eigenspace of dimension two. I need to also justify my answer by finding a basis for each eigenspace.
I need to mark the point in which x,y,z interesect on a 3-d graph.  Can anybody offer and advice as to how this can be done?
I'm using maple12 and I have a problem with a homework:
with(DEtools);
eqn := D(y) (x) = sqrt(x^2+y(x)^2);
plot1 := phaseportrait(eqn, y(x), x = -5 .. 5, [[y(0) = 0]], y = -5 .. 5, linecolor = [blue], dirgrid = [30, 30]):
plot2 := implicitplot(x^2+y^2 = 1/4, x = -5 .. 5, y = -2 .. 2, grid = [100, 100], color = green):
plot3 := seq(implicitplot(x^2+y^2 = k^2, x = -5 .. 5, y = -5 .. 5, grid = [100, 100], color = green), k = 1 .. 5);display([plot1, plot2, plot3])
hello,
i have had many troubles with maple 12 recently, and perhaps some of you could educate me on how to do things better.  although i could use different software, i've been doing this particular project on maple and figure that it should be able to work.
Write a procedure INVERSE2by2MATRIX to find the
inverse matrix of 2 by 2 matrix.
THANKS
I want to increase the length of a slider so I can display more values .
How can this be done ?
Hi, I have written the following code in maple.. which I have to compare with the crank-nicolson scheme written in matlab.. that code is well.. but this is not working.. i need to analytically solve the heat equation PDE := diff(u(x,t),t)=1/2*diff(u(x,t),x,x) IBC := {u(x,0)=T0, u(0,t)=0, u(d,t)=0}: vals := {a=1/2, T0=0.1*sin(x), d=pi}: PDE := eval(PDE,vals); IBC := eval(IBC,vals); sol := pdsolve(PDE, IBC) i get this error Error, (in pdsolve/sys) too many arguments; some or all of the following are wrong: [{u(x, t)}, {u(0, t) = 0, u(pi, t) = 0, u(x, 0) = .1*sin(x)}]
I have this equation:
> Eq := cT*a*b*sT+cT*c+sT*d+cT*sT;
I want to substitute cT*sT by s2T. But when I try to use subs it doesn't work because (I think) in the first term it's cT*a*b*sT and not a*b*cT*sT. I can't use collect as well because not all terms have the both variables.
This is a simple example, but my equation have like 40 lines and I really want to do in a automate way, so I don't have to do this manually everytime I change the values.
Thanks in advance,
Rodrigo
I have a large variable (an array of 3*n elements, where n may end up large) containing data from a simulation in maple. I would like to further play with this data in matlab, but cant find a way save/export the array in a way which matlab can read from, thanks for any help.
First 2159 2160 2161 2162 2163 2164 2165 Last Page 2161 of 2459
