I attempt to draw a 3d plot using plot3d.  The function contains a weighted combination of absolute values.  To simplify the problem statement, suppose drawing -abs(x-y) for x=-1..1, y=-1..1.  It was found that near the zero plane, the plot become sawtooth like, which is an unexpected result.  How can I remove this effect?
How does one do the indeterminate vector product with and Dyadic calculus operations with Maple 12?
I just upgraded to Maple 12 because of its ability to perform abstract index calculations. However, I'm having trouble getting started with it. My first problem is with the Simplify command: if I define a completely symmetric tensor using the command
Define(T,symmetric);
and an antisymmetric tensor using the command
Define(w,antisymmetric);
then
Simplify(T[mu,nu,rho]*w[mu,nu]);
correctly returns 0. However, if I define T to be symmetric in only its first two indices,
Define(T[mu,nu,rho],symmetric={mu,nu});
I just found Advisor by Robert Israel.  I followed the instructions, but it won't work
Here's what I did.
I unzipped the 3 files (maple.hdb, maple.ind and maple.lib) in the zipped folder to an advisor named directory in the Maple folder
I created Maple.ini and put   libname:= `c:/Program Files/Maple 11/Tools/Advisor`, libname:   as the sole line in the file as it says.  I put the Maple.ini in the main Maple 11 folder and also tried it in it's bin.win folder.  No luck.
I have the expression
p(x,a) w''(x) + q(x,a) w'(x) + r(x,a) w(x)
How could I obtain p(x,a), etc.?
              Sandor
*Find the cubic ax^3+bx^2+cx+d that has a local minimum at (‐1, ‐2) and a local maximum at (4, 4). Plot it.
How do i approach this problem?
Hi, I'm rather new to Maple but I have to find a composite number n which has the property that all her coprimes a fulfill the expression "a^(n-1) - 1 mod n = 0". I already found out that such numbers are called Carmichael numbers. But of course I need to use Maple and the information I was given by our professor. My problem is that I have no idea how to check if "a^(n-1) - 1 mod n = 0" is true for all coprimes of a given n. How do I? ;) btw. I don't know if I used the correct vocabulary here, so please forgive me if I expressed something wrong.
I have this problem
I have to solve something like this
for i to 17 do
solucion[i] := solve({item3[i], item4[i]}, {x, y})
end do
and I obtain in the answer for example
solucion[1] =             {x=2,y=3}
solucion[2] =             {x=3,y=4}
and I would like to create a vector containing all the values for x and all the values for y like x[1]=2  x[2]=3 and so on
The position of a particle in space at any time t>=0 (in seconds) is given by x(t)=t^(3/2), y(t)=2t^(5/2), z(t)=t^2 (in meters). Use the connamds diff and fsolve to find the time t when the particle fisrt reach the speed of 300 m/s.
thank you!
If I have an expression which represents the following:
Not sure how to compute my question into maples. Tried various ways and nothing has worked yet. Need help, I am new with Maples. Here is the problem that I am trying to enter into maples:
find arc length of space curve:
r(t)= 2e i + ecos(t) j + esin(t) k, where t is > or = 0 and < or = to ln(3). r(t), i, j, and k all have vector arrows above them.
Can anyone give me a hint on how to enter this into maple?
Im solving the following equation: V=I(t) * Z (V)
I substitute I and Z with the corresponding equations and I solve for V :
V:=solve(V=(1.027*exp(-t/0.282)+0.051*exp(1/t+(1.766*10^90))))*(2.433*10^3*exp(-0.008*V)+780),V):
and maple solves nicely  it using LambertW and i can plot V for a range of t.
I want to do the same but instead of the equations of I=f(t) and Z=f(V) to use straight the values from tables like:
I have a matrix,  T:=[cos(x)  -sin(x); sin(x)  cos(x)].
Maple11 can calculate the eigenvalues symbolically. Nice property. However
(v,e):=Eigenvectors(T)
gives
Error, (in LinearAlgebra:-LA_Main:-Eigenvectors) expecting either Matrices of rationals, rational functions, radical functions, algebraic numbers, or algebraic functions, or Matrices of complex(numeric) values.
Is there any possibility to calculate the eigenvectors symbolically?
Hi everyone,
i want to find the solution(s) to the following equation numerically:
f:=1+x^2+1/100*abs(ln(3-4*x))=0;
But fsolve refuses to work, it just gives the input back. Setting Digits to a stellar value didn't help, i also tried different initial points.
Thomas
First 2211 2212 2213 2214 2215 2216 2217 Last Page 2213 of 2458
