Hi all
I have this integration , HOW can I solve
the problem is in recent  file named  argent pdf
please help me to solve it
and give results please.......
I have the following ODE
sorry , i forget the term so the question is :
int ( q  * exp((1-b)^2* qz^2 / lambda[1] ) * exp((1-b)^2* q^2 / lambda[2])   /  ((1+b^2*q^2+b^2*qz^2)*(q^2+qz^2)) , qz= -infinity..infinity)  then w.r.t     q  from (0......infinity)
after integration we want to minimize the results , the range is as (b=0..1), ( lambda[1])  =1....100000) ,   (lambda[2])  =1....100000)
I need some help to figure out how to get maple to use distributive property and rules of exponents.
>A:=R/(1+exp(-2(h-s))
>a:=A/(exp(h-s))
I would like to get the answer back in the form
R/(exp(h-s)+exp(-(h-s))
suggestions?
Is it possible to add block comments in maple. Like, for example, /* ...*/ in java. Thank you.
I have this line in maple 11:
polygonplot([[0,0],[1,1],[1,0],[0,0]],legend="stuff");
and the legend doesn't appear, is there a way to force maple to produce the legend (other than horribly right clicking and manually writing the legend in every time - I'm trying to make lots of polygon plots...)
Steve
I'm trying to solve a largeish matrix equation of the form A*X + Transpose(A*X) = B for X, where A and B are known matrices.  I know there must be some clever way to get Maple to automatically unpack this equation into the equations for the components and then solve them symbolically, but I haven't had much success.  Could someone more skilled point the way?
Using Maple, I integrated and expression and got ln(e) in the answer.  How can I eliminate this?
i have this integration:
int(q*exp((1-b)^2* qz^2/lambda )/((1+b^2*q^2+b^2*qz^2)*(q^2+qz^2)),qz=-infinity..infinity) then w.r.t      q  from (0......infinity)
I want to take two numbers, for example 37665432 and 59374696 (later extrapolate to 3 or 4 etc... sets of numbers) and take each individual number alternately and put them into a list.
Here's what I have
a:=37665432;
b:=59374696;
c:=convert(a,base,10);
d:=convert(b,base,10);
e:=ListTools:-Reverse(c);
f:=ListTools:-Reverse(d);
So now I have the numbers all in a list and I want to select each one alternately into another list.
g:=seq(e[i],f[i],i=1..8);
I am going to simplify the following formula:
sqrt(a^2*p*(1-p)*(N-n)/(n^2*(N-1)))
I wrote simplify(sqrt(a^2*p*(1-p)*(N-n)/(n^2*(N-1))),symbolic), the output was:
I have a series solution to a differential equation. The recurrence relation is such that knowing the first four coefficients is sufficient to determine all the other coefficients. Now I want to represent this solution in terms of f(x)*c0+g(x)*c1+h(x)*c2+k(x)*c3 where f,g,h,k are all polynomials in x. I tried searching for commands related to simplify, but I was unable to solve my problem.
p.s : i am not aware if this has already been discussed so please bear with me
I am having trouble with posing an integration for the following function, wrt z.
u:= sin (theta)  * ((s^2 + z^2)/2 +h*z)
I want to be able to change the values of h, s, and theta.
I would like to integrate u, wrt z, from s to h.
I have tried the basics, such as....
int(u, z)   and
int(u, z=s..h)
I get the integrand symbol and a general setup but I am not posing it clearly enough to get Maple to perform the integration.
Thanks for any help you can offer.
Based on some older Math group thread my problem is the following (0 < t):
F:= (x,t) -> Int(exp(-t*eta^2+x*eta)/(1+exp(eta)),eta = -infinity .. infinity);
satisfies 0 = 'diff(F(x,t),t) + diff(F(x,t),x$2)' and for that PDE Maple gives
  pdsolve(PDE, f(x,t),build): combine(%):
  subs(_c[1]=c,_C1=c1,_C2=c2,_C3=c3,%): rhs(%);
  S:=unapply(%, x,t);
    S := (x, t) -> c3*c1*exp(c^(1/2)*x-c*t)+c3*c2*exp(-c^(1/2)*x-c*t)
by separation of variables.
I am interested in t=1/2 ( to get (F(x,1/2) ) and for that define
I have a procedure that I use frequently. I tried to include this procedure in other Maple sessions so that I can reuse that procudure. I tried the command $include but received the following error message:
$include "c:/myworks/myplot.wm"
Error, unexpected string
where myplot.wm is a file that contains a procedure which I want use repeatedly.  What is wrong there?
First 2244 2245 2246 2247 2248 2249 2250 Last Page 2246 of 2458
