How do I enter this problem in Maple 12? I have a few like this and need to knwo how to input the equations.
1.)  Find the slope of the tangent line to the curve y=x^3+3x-8 at (2,6)
2.) The tangent line to the circle y=x^3 -6x^2 -34x -9 has slope 2 at two points on the curve. Find the two points.
3.)Find the slope of the curve y=x^5 at x= -2
i have Maple 12 Student edition. when i do a 5th intergration, and eval at Pi, i get a complex answer. how would i get it to display a rational answer ? h := t-> (1+t^3*cos(t))^(1/5); ((D@@5)(h))(Pi); evalf(%); simplify(%); -.1245723200-0.905070854e-1*I D1 := D(h); D2 := D(D1); D3 := D(D2); D4 := D(D3); D5 := D(D4):fsolve(D5(Pi)); -.1245723200-0.9050708540e-1*I thanks
I'm trying to eventually make some 3d plots of some finite fields and different operations on them. Unfortunately I need some way to restrict the input to integers since apparently floor-ing them isnt enough. Heres parts of my worksheet, if it helps: G := GF(2, 8, x^8+x^4+x^3+x+1) `&*` := proc () options operator, arrow; G:-output(G:-`*`(map(G:-input, [args])[])) end proc f[1] := proc (a, b) options operator, arrow; `&*`(floor(a), floor(b)) end proc > plot3d(f[1](a, b), a = 0 .. 255, b = 0 .. 255); %;
How do I create a button that performs multiple actions? For example, I might want to create a button that both differentiates and integrates a function with one click. So far, everything I have tried has resulted in evaluating the last action in the list.
Cloyd
Hello I'm working with some finite fields(2^8) and sometimes instead of viewing/working with a polynomial its easier to work with a number. Its easy to convert from polynomial to number by just letting x=2, but is there a easy and built in way to go the other way? Thanks
I am using Maple 11 and trying to solve numerically the following easy system of 1st order, linear PDEs:
I have a set for which I want to multiply each value by a sequence.
The only way I know how to do this is to convert set->list, apply the sequence, Flatten and convert list->set.
The problem is that Flatten stops working when the list becomes large. Suggestions?
         I need help with this problem !!!!!!!!   My brain is turning to mashed patato's  Thank-You
  In a study on infants, one of the characteristics measured was head circumfrence. The mean head circumference of 15 infants was 34.6 centimeters (cm).
The data in the table represents the ages of the winners of an award for the past five years. Use the data to answer questions (D) and  (E)
39     40
48     48
42
A problem instructed me to construct a Taylor/Maclaurin series for cot(x) by dividing cos(x) by sin(x).
I did this quotient by putting both summations over each other then cancelling common terms.
I've always had some difficulties with summation, or the rules of the summation symbol and would like to know if that operation was legal.
In this case both summations began from the same starting point for the dummy variable, n.
Whenever this is the case is it correct to say that the quotient of two sums is the sum of the quotient?
very respectfully,
I've been trying to vreate a script which will provide the roots of the Bessel function of the first kind, and it's derivative.
The root of the Bessel itself is fairly straight forward, simply BesselJZero(m,n); however, I can't do the same for the derivative diff(BesselJ(m,n),n).
Any help would be appreicated.
A population has a mean of 75 and a standard deviation equal to 21. Find the mean and standard deviation of a sampling distribution of a sample means with a sample size of 49.
I am using dsolve to integrate a system of equations, and I am using stop_cond to stop the integration when certain conditions are met.
The problem is, I want the integration to stop when condition 1 AND condition 2 are met, but when I use, for example
stop_cond=[y(t)-2,t-4]
it stops as soon as ONE of these conditions are met, not both. I want it to stop when y(t) is equal to 2 AFTER t=4, not before.
Any suggestions would be greatly appreciated!
Hi, i just want to write this equation im Maple,  how do i do it ?
I'm trying to find all solutions to a system of polynomial equations. I've tried using Isolate from the RootFinding package and for some choice of parameters this works well. However changing the parameters (i.e changing some of the coeffients of the polynomials), I get the error message.
Error, (in RootFinding:-Isolate) decreasing address previous=1e0f0020 new=10010020!
Any ideas on what this means?  possible ways around it? or other functions in maple that would give me all solutions?
Thanks, Steve.
First 2248 2249 2250 2251 2252 2253 2254 Last Page 2250 of 2458
