Any chance this is possible? I dont like having to 'browse' every time and my matrices arnt even that big. Thanks
Hi, i want to find the roots of a polynomial and replace pepetitive (long) expressions in it by using alias.
solve(x^3+2*x+1=0,x);
-1/6*(108+12*177^(1/2))^(1/3)+4/(108+12*177^(1/2))^(1/3), 1/12*(108+12*177^(1/2))^(1/3)-2/(108+12*177^(1/2))^(1/3)+1/2*I*3^(1/2)*(-1/6*(108+12*177^(1/2))^(1/3)-4/(108+12*177^(1/2))^(1/3)), 1/12*(108+12*177^(1/2))^(1/3)-2/(108+12*177^(1/2))^(1/3)-1/2*I*3^(1/2)*(-1/6*(108+12*177^(1/2))^(1/3)-4/(108+12*177^(1/2))^(1/3))
This looks nasty, so i want to replace (108+12*177^(1/2))^(1/3)
alias(alpha=(108+12*177^(1/2))^(1/3));
I've written a simple LPSolve test program. But it seems to fail to give me the correct answer that satisfy the constraints. Here is the code:
with(Optimization):
cnsts := {x1 + x2 + x3 + x4 + x5 >= 1, x1+x2+x3+x11+x6 >= 1, x7+x9+x10+x4+x5 >=1, x7+x9+x10+x4+x5 >= 1, x7+x9+x10+x11+x6 >=1, x8 + x9 + x10+x4+x5 >=1, x8+x9+x10+x11+x6 >=1};
obj := x1+x2+x3+x4+x5+x6+x7+x8+x9+x10+x11;
LPSolve(obj,cnsts,assume = {nonnegative});
Given a cubic, x^3 - c*x +16=0, I need to find values of c so that the real parts of the complex roots are negative.  Any suggestions?
Hi, This is my 1st try with Antiderivatiives using Maple 12 Student Edition. These statements work fine and the answers are the same as the book. int(15*x^4-cos(x)+5, x); int(8*x^3+Pi*cos(Pi*x), x); but the below doesn't work. Maple just repeats it with the Integral symbol before it and 'dx' after it. by hand the answer is 3x^(5/3)+x^(3/5)+C. int(5*(x^2)^(1/3)+3/(5*(x^2)^(1/5)), x); thanks
Hi. I have to create a procedure Approx with the procedure call Approx(f, a, b, N). I don't really understand how to write procedures so I'm confused.  The point of the procedure is to return the floating point value of the right Reimann sum SN  which approximates the area under the curve y = f(x) over the interval [a, b]. I don't know where to go from here. Here is what I have so far:
I have difficulty in taking fourier transform of a function f(t).
The function f(t) is not integrable. Through analytical analysis, f(t)
behaves asymptotically the same as a*log(t)/t
for t-> +infinity; and f(t) behaves asymptotically the same as b*log(-
t)/t
for t-> -infinity; where "a" and "b" are some constants.
Is there a way to work around this difficulty and get some sort of
fourier transform of this function f(t), possibly
Hi Everybody,
Suppose I have this procedure assign to p:
>p:=MyProc(args1,args2,args3,h) statement end proc:
where h is the step size.
args1 = {ode,ic} , args2 = x(t) et args3 = t=a..b.  The output of MyProc is a list of list
I would like to do what dsolve do when you write:
p:=dsolve( {ode,ic},x(t),x(t),numeric)
and then evaluate p(2) for example.
Hello I'm trying to plot a piecewise function, only I think the plot I get is wrong. It looks like a linear function when it should be a bit more 'scattered' looking. It also goes past 900 when its max should be 63. Did I mess up the function? Plot arguements? Thanks > pLayer := proc (x) options operator, arrow; piecewise(1
I'm having a little trouble getting Maple to return a correct solution.  It's a simple equation, really, involving the relation of the period of an object around the sun and it's semi-major axis.  Specifically this involves Halleys comet.
Given that halleys comet takes 76 years to complete an orbit.
I set
eq1:=P^2=(4*Pi*a^3)/(G*M);
and convert P to seconds
P:=convert(76,units,year,second);
G:=6.672e-11;
M:=1.99e30;
solve(eq1,a);
I am using Maple 12.
I often try to simply expressions, but I found that very often I must manually guide the simplification procedure.  For example a result from inverse laplace trasformation is:
Ssi(t)+pi/2
But this, by definition, equals Si(t).
However, the function simplify doesn't work for such a purpose.  Also in many other cases the function 'simplify' don't work without human guide.
when i calculate the equation as:
solve({g*(w-c)+(1/4)*(a-g*w+g*r)^2/(b*(p-k))-(a-g*w+2*g*r)(a-g*w+g*r)/(2*b*(p-k)) = 0}, {r})
i got the message "Warning, solutions may have been lost" without any feedback,
does the equ too complex to calculate in Maple? or i make some mistakes?
how should i do to solve this equation~
ths
Hello Odd question, I have a vector and I'm wondering if theres a easy way to get bit level access (to specific bits) on the elements. I guess I could have a vectors inside of vectors but it seems wasteful since I also have other operations that arnt at the bit level. Thanks
hi, if i run the below statements, the last 2 cause Maple 12 Student Edition to chug along for a minute then generate a very long answer, like a page worth. it's like it can't figure out the answer and dumps a bunch of garbage. all i am trying to do is a 2nd derivative. restart; dist := t-> sqrt((-27-(60+23*sin(t))*t/sqrt(2))^2+(-11*t+(60+23*sin(t))*t/sqrt(2))^2); 'dist(t)' = dist(t); Ddist := D(dist); 'Ddist(23/60)' = evalf(Ddist(23/60)); tmax := fsolve((D(Ddist))(t), t = 0 .. 1); 'Ddist(tmax)' = evalf(Ddist(tmax));
After updating my PC to Windows XP SP3 Maple no longer runs. A box with the message: "
Invalid or missing license file
License server does not support this feature
Feature: Maple 11
License path: c:\Program Files\Maple 11\License\license.dat
FLEXlm error:-18,147
appears and Maple does not start. Maple worked fine before SP3 update.
Does anybody have the same problem? Any idea about how to fix this?.
First 2246 2247 2248 2249 2250 2251 2252 Last Page 2248 of 2458
