Is it possible to dislay two functions in different scales in the same diagram? E.g. one function taking values in the range 1..10 and another taking values in the range 0.01..0.1. The reason I want to do this, is to display functions (on different scales) which interact in the same diagram so they can be easily compared. I can, of course blow one function up, but I find that slightly dissatisfying, as the numbers loose their meaning, and understanding the plot becomes more difficult. If this is not possible, is there a way I can effectively export the ploted 'data' and redraw the graphs in another more suitable program? Any tips or help appreciated.
Hi! I'm searching for a useful guide of the MapletBuilder (for Maple 11). I know how to create Boxes 'n' Stuff. Now I want to assign commands to the buttons,which should be executed by pushing them but I don't know how to do that. By that I mean where to put them and what kind of commands exist or do I have to use. I need a guide with some examples. It would be great if anyone could help me. Thanks paience
Dear All, I seem to be having trouble with 0^n in maple, can someone help? Essentially, I have a complex function that simplifies under certain conditions to
f:=1.*0.^n/factorial(n);
but
sum(f,n=0...0);
gives 0. Whereas,
evalf(subs(n=0,f));
gives 1. Any ideas? Thanks Colin
Can Maple be used to test infinite series for convergence ? Are the many tests for convergence already built-in Maple ? Thanks, v/r,
Please Help, Show that Sum(1/((2*n-1)*(2*n+1)), n = 1..infinity) = 1/2) Hint. (Show by mathematical induction that s[m] = m/(2*m+1) Thanks, v/r,
Does anyone know how to write a procedure for simpsons rule using the trapezium rule. I wrote a procedure for the trapezium rule but it wont let me put it in the simpsons rule. Maple keeps saying that local is wrong. Please help!
i WANT TO DEVELOP A MICROCONTROLLER BASED PID TEMPERATURE CONTROLLER.THE USER WILL SET THE DESIRED TEMPERATURE THROUGH KEYBOARD.I WILL BE USING A TEMPERATURE SENSOR(IC LM35DZ) WHICH WILL BE INPUT TO MICROCONTROLLER 8051 WHICH WILL IMPLEMENT PID ALGORITHM TO CONTROL A RELAY AND HENCE EITHER TURN ON A HEATER OR A COOLER.AN LCD WILL ALSO BE INTERFACED TO DIPLAY THE SET TEMPERATURE AND ACTUAL TEMPERATURE. I DO NOT KNOW THE C CODE FOR THIS.IF ANYONE HAS WORKED ON SUCH KIND OF SYSTEM ,THEN PLEASE SEND ME THE CODE.I WILL BE REALLY VERY GREATFUL
When I execute a proc of Maple, Can I make the process sleep for several seconds? Just like other programming languages sleep function. Thanks.
I have an equation lets say f(x). I derivate it then I need to find the equation of the tangent that touches f(x) at two different places.
Hello. Im courius if there is any (easy) way in Maple to do a Chebyshev curve fitting. I havent been using Maple mutch and I cant say that I really understand how the chebyshev approximation works, but i want to do a comparison between the Least Square Criterion (with the funktion: a*x + b) and Polynomial Interpolation and the Chebyshev Approximation (with the exp: a*x + b). The Least Square and the Polynomial are both options in the Curve Fitting Assistant (in Maple 11), but not the Chebyshev (is it becouse its somehow inferior to the least square?). And by the way, please note if I write anything wrong (spelling, grammar, etc etc..). English is not my native language.
I just got this problem and I don't know how to plot it. Plot the first 300 terms of the sequence a(1) = 0.8, a(n+1) = 4a(n)(1-a(n)). I can tell maple to calculate the first 300 terms, but I don't know how to graph it. this is the command i used for calculating those terms. for n from 1 to 300 do a(n+1):=4*a(n)*(1-a(n));od;
Hello, I have a problem with this implicit equation: > eq:=(x^2+4*y)^2+(x+y^2)^2=65 I can find the tangent line for a point on the curve, e.g. (-2,1). This is the slope on the point. > a:=subs(y=1,x=-2,implicitdiff(eq,y,x)); It will give this tangent line. > tanline:=a*(x+2)+1; Here's a plot: Image and video hosting by TinyPic But now I want to find the locations of its extreme values. That's where I got stuck. The tangent line must be horizontal so dy/dx = 0. So I have to the implicit equation for the condition dy/dx=0. For explicit functions it's not that hard, e.g.:
> p:=x->log[b](x); p := x -> log[b](x) > o:=x->b^x; x o := x -> b > fsolve( p(x) = o(x) , {x,b} ); Error, (in fsolve) number of equations, 1, does not match number of variables, 2 I need to find the location (x,y) where they touch each other, thanks for the help.
What do I have to change in the settings to get numerical results from simple expressions using symbols? In other words, when I enter something like 2 x pi or e, I want the numerical answer, or rather something that reads 6.28... As it is, it just returns 2 x pi again.
There are lots of posts on MaplePrimes with Wei Xi Fan telling us that "this issue has been tracked". I'm always happy to hear that, but I think a subtle alternative would be better: I would write in red at the bottom of the original report "Note: this issue has been reported to Maplesoft's internal bug tracking database." Make it sound kind of ominous, as if the offending bug will surely be crushed. Also, I think a message in red on the original post is better than a reply which appears somewhere down the page. Of course for this to work, it would have to be easy (one click?) for company
First 2317 2318 2319 2320 2321 2322 2323 Last Page 2319 of 2458
