Hi, I am Er. Vishal Jain new to maple prime. I need help in developing dynamic 2D-graphs(pi-chart, conic section etc.) in .mw and respectively shade the graph.
While posting an initial question is not problematic, when editing or adding a comment thereafter, one is presented with a box in which to compose that is partially concealed by content at the right of the screen, e.g., Active forum topics and Recent comments. One can continue to type behind the veil and have it display fine in the preview, but this seems anomalous. I have noted it on two different computers. Do others have this problem? Is there a way to work around this besides truncating ones sentences with early returns?
As per instructions at the bottom of page 217 of the user manual, I wish to alter the y-axis range of a 2D plot. The instructions say to right click the plot region. Select axes and then range, however, doing so allows one to select axes, but the menu item range is nowhere to be found in the menu as described by the manual. The menu only offers the choices of normal, boxed, framed, none, properties, labels, toggle gridlines, and set gridline properties.
My old Mathcad 7 had a snap to function that allowed one to trace a given plot. Using the point probe on Maple does not seem to have an equivalent feature. If one wants to know a particular x y location, one must hover the point probe over the desired spot, but this is not ideal as it it very sensitive to movement. Is there a snap to feature for tracing plots? If so, how is is activated?
Hi All, I am new to Matlab.Could you please tell me how to translate the Matlab code to c++ code i.e to convert *.m to .cpp. If there are some explicit tool please let me know. Thanks in advance, Vinay
im new so excuse the relavie easy ness of this question. i typed >plot(1/7-5*(sin(x)),-10..10,-10..10); then Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct and an empty graph comes up i looked on the help page but i dont really understand it, i was hoping mapleprimes can help??? once again sorry for the easyness of the question!!!
I am using windows vista but with office 2003. I am also using maple 11 with the 11.01 build. On installing maple excel addin I have this error: 'VBE6EXT.OLB' could not be loaded. Clicking OK gives another error: 'Unexpected Error (50001)' Now I can't even open the VB Editor. I get the error message: 'Out of Memory' Any help? Thanks.
Hi I am trying to combine a previous, numerically obtained result in a subsequent calculation: outline: suppose i have a given function, f(x), and i wish to construct the following boundary value problem: y''(x)=f(x), y(0)=1, y(1)=2 the known function f(x) is a result of another calculation, which i have obtained numerically. (f(x)=proc(x)...end proc, or something to that affect). code: -------------------------------------------- > restart; > sys := {diff(y(x), x) = x, y(0) = 1}; / d \ { --- y(x) = x, y(0) = 1 }
How can I create the inert form of the following function: dm:=z->diff(z,t)+v[c]*d_[c](z); Note d_ is the new indicial differential operator available in physics package of Maple 11. Its inert form is %d_. What I need is that when I write, dm(rho), maple does not expand it into two terms using the above function, but displays the compact form dm(rho). I want to see the expanded form, only when needed, not at every step where dm is used. So at other steps, I just want to see dm(rho), without evaluation. Thanks, Pawan Takhar
In the example below, the plot option axesfont affects both axes in Maple 10.06, but in Maple 11.01 it affects only the vertical axis. Is this a feature, or a bug? If it’s a feature, how can I change the font of the horizontal axis tickmarks?
dates := [0 = "21/8/00", 140 = "8/1/01", 536 = "8/2/02", 885 = "23/1/03", 1267 = "9/2/04", 1628 = "4/2/05", 2004 = "15/2/06", 2200 = "30/8/06", 2479 = "5/6/07", 2531 = "27/7/07"];
xy := [[0, 2.5], [140, 2.2], [536, 2.6], [885, 2.5], [1267, 3.3], [1628, 3.1], [2004, 5.0], [2200, 3.0], [2479, 5.9], [2531, 4.3]];
plots[pointplot](xy,symbol=circle,tickmarks=[dates,default],axesfont=[TIMES,ROMAN,8]);
This question was already raised before. Does Maple 11 "fortran" command generates code which is compatible with Fortran 90 (or 95)? I have a problem in several respects, especially in the syntax of "continuation" lines. How can I generate Fortran 90 syntax. To be more specific: When long line is of code is generated 'number' sign is used to continue on the new line. In fortran 90 '&' sign is expected. i.e. fortran 77: #2*rho1(i+32 #)*rho1(i+11)-0.2037715763 instead we need in fortran 90: & 2*rho1(i+32 & &)*rho1(i+11)-0.2037715763 &
I just uploaded the file: 2510_CDR_MESH_problem.mw. I'm running Maple 10.05. The problem is more curiosity and annoyance than practical, at this point, but: If I remove the with(RealDomain) at the top of the file, everything runs fine and a nice plot is produced. Keeping the with(RealDomain) statement, results in ERROR, invalid object in MESH. Can anyone tell me what's going on? Don Ritchie
I need to put all these things together to make a scene, I would like to keep the house,and the clouds as a background plot, and have the tornado and tire move. Sort of like the tornado picks up the tire and then drops it. here is my code its to big for me to save it on here. Using like the animate code, and display codes. Packages: with(plots):with(plottools): Tornado: Actual Tornado: tubeplot([20*t*cos(t),20*t*sin(t),20*t], t=0..20*Pi, radius=-100*exp(.00001*t), tubepoints=10, numpoints=100, color=grey, frames=30): Animated Tornado: rotating around: animate(tubeplot,[[20*t*cos(t+s),20*t*sin(t+s),20*t+s],
I need to calculate derivative of a scalar function psi, which depends upon the scalar theta and tensor G[i] using the diff command and indicial notation capability of the recently included Physics package. My actual equation is longer, but here I am only including the terms needed to present my question. Please see below:
with(PDEtools):
> with(Physics):
Setup(dim=[3,`+`],spacetimeindices=lowercaselatin);
The code below is just to illustrate the issue. Is there any way to keep the chosen scaling and view when the plots are placed within an array? As the code below will show the scaling and view for a plot in an array has a mind of its own! I tried plotting a and b with both plots in them but with one in white - so it looked as if there was only one plot - but that did not work. restart; > with (plots): a:=plot(x^2/10,x=1..50,scaling=constrained,view=[0..120,0..800]): > b:=plot(-x^2+50*x,x=1..60,color=green,scaling=constrained,view=[0..120,0..800]): > display(a,b); > > g:=array(1..2):
First 2341 2342 2343 2344 2345 2346 2347 Last Page 2343 of 2458
