Please, how do I generate a list of ones in maple?
Dear friends,
I found a file in the Maplesoft Application Center to evaluate the minimum of a function in two variables.
I tried to extend the code to find a minimum for a function in 4 variables.
But the code does not work. Any Help, I will be appreciated.
Amr
Gradient_Search_Program_Code-22-9-2022.mw
How to linearize eq (6) by neglecting all higher order terms i.e., epsilon[1]^2, epsilon[2]^2, epsilon[1]*epsilon[2]... etc? How to do it in maple?
Calculation.mw
Please help me create a variation table of the function in maple like the above figure.
restartNULL
NULL``
Can I disable maple's use of the ' function? (aka prime/derivative function)
For example, if
f := x^2+1
x^2+1
it's derivative is obtained as
Diff(f(x), x) = diff(f(x), x)
Diff(x^2+1, x) = 2*x
We used the prime operator on the f to obtain f' on the right-hand-side.
The problem is, I use prime notation as a naming convention like in defining an integral equation such as:
"psi(t)=∫G(t,t')*psi(t') ⅆt' ."
This is common practice in many texts.
Is there a way that I can disable the operator function of ' so I can use it as a naming scheme? I have tried using the Alias( ) command which works on one evaluation but if an equation is passed to another function the Alias( ) command is extinguished by the previous evaluation and it takes the derivative again which is undesired.
how_do_i_disable_prime_operation.mw
I haven't managed to round values with units, and get the trailing zeroes cut away, so I'd like to use the MapleTA:-Builtin:-numfmt function to do the job.
The problem is, that this function doesn't accept values with units.
I have managed to write a rounding function to do the rounding, but the problem here is that it will write the values with trailing zeroes, which isn't what I want.
Any ideas how to fix that?
How to find values of w for which determinant of A is zero?
determinant.mw
I have a proc that takes a function. This function is called  when the proc needs it to. Normally it will simply do a computation. The return is generally ignored(since the proc is a bit non-deterministic). I would like, though, to store values computed within the function in a global variable. I can't seem to use assign since it forces the variable to be local.
I can print the result of the function and it shows up but what is the proper way to assign variables within a function:
e.g.,
plot(store(x),x=1..2);
Then store would somehow store the values passed to the function(and in this case probably returning x). The example is not my use case and may not actually work properly.I cannot use global in the function passed as an argument to create a global variable.
F := proc(f)
    blah blah f(3)
    blah blah f(4)
R := []:
F(x->store(R, x));
R = [3,4]
The function
f := sin(x)/sqrt(2+sin(2*x));
has a simple elementary antiderivative but int(f,x) is huge and not elementary. What method would you suggest to find it?
with(geometry):
_EnvHorizontalName := x:
_EnvVerticalName := y:
R := 11:
r := 7:
a := sqrt(R*r):
b := 2:
circle(C1, [point(P1, [0, 0]), R]):
circle(C2, [point(P2, [R + 2*b + r, 0]), r]):
ellipse(p, (x - R - b)^2/b^2 + y^2/a^2 = 1):
draw([C1(color = yellow, filled = true),
C2(color = red, filled = true), p(color = blue, filled = true),
C1(color = black), C2(color = black), p(color = black)],
axes = none, view = [-15 .. 35, -15 .. 15], scaling = constrained):
alpha := arctan((R - r)/(R + 2*b + r));
long := cos(alpha)*(R + 2*b + r);
evalf(%);
circle(C2, [point(P2, [long, r - R]), r]);
rotation(p1, p, alpha, 'clockwise');
detail(p1);
point(A, 0, -R);
point(B, long, -R);
line(L1, [A, B]);
point(cen, [(143*sqrt(5))/25, -(26*sqrt(5))/25]);
reflection(L2, L1, cen);
detail(L2);
Error, (in geometry:-reflection) unable to compute coeff
Error, (in geometry:-detail) unknown object:  L2
draw([C1(color = yellow, filled = true), C2(color = red, filled = true), p1(color = blue, filled = true), C1(color = black), C2(color = black), p1(color = black), L1(color = black)], axes = none, view = [-15 .. 35, -15 .. 15], scaling = constrained);
A Bug in reflection ? Why these error messages. Thank you.
Given
expr:=c[2]*sin(sqrt(3)*x/2) + c[3]*cos(sqrt(3)*x/2);
expr:=convert(expr,tan);
How to change the second result above (with the tan) back the the original form it was in?
I tried all different convert and simplification commands, and non managed to get back the original form.
convert(expr,sincos);
simplify(expr,size);
#etc...
Maple 2022.1 on windows 10
From an equation list originating from code optimization, a set of parameters and intermediate variables `tx` (where x is an integer) can be extracted.
{la, ra, rb, t, t10, t11, t12, t13, t15, t17, t18, t19, t21, t23, t24, t25, t26, t27, t28, t31, t32, t33, t34, t35, t36, t37, t39, t41, t42, t43, t44, t45, t46, t48, t49, t5, t50, t52, t53, t54, t55, t56, t57, t58, t59, t61, t62, t63, t64, t65, t67, t68, t69, t7, t70, t9, xa, za}
To extract from this list the intermediate variables for further processing I do
with(StringTools); intermediates := NULL; for i in {la, ra, rb, t, t10, t11, t12, t13, t15, t17, t18, t19, t21, t23, t24, t25, t26, t27, t28, t31, t32, t33, t34, t35, t36, t37, t39, t41, t42, t43, t44, t45, t46, t48, t49, t5, t50, t52, t53, t54, t55, t56, t57, t58, t59, t61, t62, t63, t64, t65, t67, t68, t69, t7, t70, t9, xa, za} do if `and`(is(FirstFromLeft(convert(i, string), t) = 1), type(parse(convert(i, string)[2]), integer)) then intermediates := intermediates, i end if end do
{intermediates}
{t10, t11, t12, t13, t15, t17, t18, t19, t21, t23, t24, t25, t26, t27, t28, t31, t32, t33, t34, t35, t36, t37, t39, t41, t42, t43, t44, t45, t46, t48, t49, t5, t50, t52, t53, t54, t55, t56, t57, t58, t59, t61, t62, t63, t64, t65, t67, t68, t69, t7, t70, t9}
Quite some code for a little task. Can this be done more efficiently?
Download extract_tx.mw
I want to change the colors of a contour such that the region above zero is represented by a different color instead of yellow color,  and that the colors for conts <0 are one set of colors (maybe yellow to red), and the area for which conts >0 is one color which is very different from the others (so maybe white).
Case4Contour.mw
I am doing some vector calculations with maple 2022, and I would like to gain a better understanding of how spherical derivatives of spherical vectors are calculated.  How can I ask maple to show the solution for this calculation?
spherical_derivatives.mw
Thanks in advance!
I want to use union, intersection and minus to find. Help me
First 308 309 310 311 312 313 314 Last Page 310 of 2458
