Another question:
I want to write the values of function g(x,t) as scientific notation.  I mean I want to write 1.95*10^(-3)  instead of 0.001953125 etc.
Yes, by clicking right-click and clicking the numeric formatting, I can transform all columns of Array A, but I want to transform just the last column g(x,t) in Array A.
  f:=(x,t)->x*t;
  g:=(x,t)->x^2*t;interface(rtablesize=20):
  A:=Array( [ [`x`,`t`,`f(x,t)`, `g(x,t)`],
              seq
              ( seq
                ( [i, j, f(i,j), g(i,j)],
                  j=0.125..0.875, 0.25
                i=0.125..0.875, 0.25
lambda:=0.1:N:=5:M:=sqrt(N(N+1)):omegap:=10:phi:=0:
var:={n(t),u(t)}:
dsys:={diff(n(t),t)=-2*(n(t)-N)+(u(t)-abs(M)*exp(I*phi))*exp(-2*I*omegap*t/lambda)+conjugate((u(t)-abs(M)*exp(I*phi))*exp(-2*I*omegap*t/lambda)),diff(u(t),t)=-2*(1-I*delta)*u(t)+2*(n(t)-N)*exp(-2*I*omegap*t/lambda)+2*abs(M)*exp(I*phi)}:
res1:=dsolve(dsys union {n(0)=0,u(0)=0},numeric,output=listprocedure):
# (this command need to be changed) P1:=plots[odeplot3](res1,[[t,(n(t))]],0..10,axes=boxed,tickmarks = [3, 2], color = black, thickness = 4, linestyle = solid, titlefont = [Helvetica, roman, 18], labeldirections = [horizontal, vertical], labelfont = [Helvetica, roman, 24]);
The member command allows testing, if a value is in a table.
But is it possible to check if the index is used, not the value?
L["hello"] := "funny"
"funny"
member("hello", L)
member("funny", L)
Download list.mw
I am trying to plot generator reactive output (Q) over a range of generator power output (P) with field current (Ifldc) and terminal voltage (Et) constant using “solve”. The system of equations includes an interpolating fiction Ifld(el).
I’m looking for some help as to how to configure a solution. Attached are a few of my failed attempts.
The upload of my file deleats the "solve" fo my first try it is:
MvaGen := 1354; PfGen := .935; KvGen := 24
           Xd__u := 1.89 - Synchronous reactance of d-axis, Unsatuarted
              Xq__u := 1.80 - Synchronous reactance of q-axis, Unsatuarted
              X__l := .26   - leakage reactance d or q-axis``
            Ifld__base := 3114
Open Ckt Sat Curve DS807-1a
     First col=Ifld amps
     Second col= el voltage behind leakage reactance
OC_SatDat := Matrix(16, 2, {(1, 1) = 0, (1, 2) = 0., (2, 1) = 655.6456, (2, 2) = .3422578, (3, 1) = 1009.961, (3, 2) = .5331404, (4, 1) = 1253.12, (4, 2) = .6492209, (5, 1) = 1562.724, (5, 2) = .8014143, (6, 1) = 1893.545, (6, 2) = .9329786, (7, 1) = 2201.68, (7, 2) = 1.033593, (8, 1) = 2487.276, (8, 2) = 1.108416, (9, 1) = 2793.943, (9, 2) = 1.157452, (10, 1) = 3122.338, (10, 2) = 1.203911, (11, 1) = 3690.959, (11, 2) = 1.263294, (12, 1) = 4259.141, (12, 2) = 1.307202, (13, 1) = 4827.028, (13, 2) = 1.340795, (14, 1) = 5351.085, (14, 2) = 1.366646, (15, 1) = 5787.775, (15, 2) = 1.387329, (16, 1) = 6224.391, (16, 2) = 1.405433})
  ido := It*sin(theta+delta)
Plot OC saturation with field current in pu
with(LinearAlgebra)
with(ArrayTools)
with(plots)
      OC_Sat_Ifld_pu := Column(OC_SatDat, [1])/Ifld__base
         OC_Sat := Concatenate(2, Column(OC_SatDat, [2]), OC_Sat_Ifld_pu)
iterpolate values of field current vs el from OC sat curve
                                    pts_el := Column(OC_Sat, [1]); pts_Ifldpu := Column(OC_Sat, [2])
                         Ifield as a function of el  ->  Ifld := LinearInterpolation(pts_el, pts_Ifldpu)
Solve for Q with
P = .935; Iflc := 1.88; Et := 1.0
TRY1
 Eq1 := Ir = P/Et; Eq2 := Ix = Q/Et    Eq3 := It*sqrt(Ir^2+Ix^2)     Eq4:=theta = arctan(Q, P)
    Eq5 := el = abs(Et+X__l*(Ix+I*Ir))      Eq6 := `ΨAG__d` = Xad__u*Ifld(el)   Eq7:=K__ds = el/`ΨAG__d`
NULL Eq8 := Xd__s = K__ds*Xad__u+X__l   Eq9 := `ΨAG__q` = Xaq__u*Ifld(el)    Eq10 := K__qs = el/`ΨAG__q`
   Eq11 := Xq__s = X__l+K__qs(el)*Xaq__u      Eq12 := Eq = Et+Xq__s(el)*(Q/Et+I*P/Et)
NULLNULL
Eq13 := delta = argument(Eq)        Eq14 := eqo = Et*cos(delta)    Eq15 := ido = It*sin(theta+delta)
Eq16 := EI = Xd__s*Iflec; Eq17 := EI = Ido*Xd__s+eqo
syst := {E15, Eq1, Eq10, Eq11, Eq12, Eq13, Eq14, Eq16, Eq17, Eq2, Eq3, Eq4, Eq5, Eq6, Eq7, Eq8, Eq9}
solve(sys, {Eq, Ir, It, Ix, K__ds, K__qs, Q, Xd__s, Xq__s, el, eqo, ido, theta, `ΨAG__d`, `ΨAG__q`})
TRY 2
`` Ix := proc (Q) options operator, arrow; Q/Et end proc   It := proc (Q) options operator, arrow; sqrt(Ir^2+Ix^2) end proc     theta := proc (Q) options operator, arrow; arctan(Q, P) end proc
 el := proc (Q) options operator, arrow; abs(Et+X__l*(Ix(Q)+I*Ir)) end proc      `ΨAG__d` := proc (Q) options operator, arrow; Xad__u*Ifld(el(Q)) end proc   K__ds := proc (Q) options operator, arrow; el(Q)/`ΨAG__d`(el(Q)) end proc``
NULL Xd__s := proc (Q) options operator, arrow; X__l+K__ds(el(Q))*Xad__u end proc   `ΨAG__q` := proc (Q) options operator, arrow; Xaq__u*Ifld(el(Q)) end proc    K__qs := proc (Q) options operator, arrow; el(Q)/`ΨAG__q`(el(Q)) end proc
Xq__s := proc (Q) options operator, arrow; X__l+K__qs(Q)*Xaq__u end proc      Eq := proc (Q) options operator, arrow; Et+Xq__s(Q)*(Q/Et+I*P/Et) end proc
delta := proc (Q) options operator, arrow; argument(Eq(Q)) end proc        eqo := proc (Q) options operator, arrow; Et*cos(delta(Q)) end proc    ido := proc (Q) options operator, arrow; It*sin(theta(Q)+delta(Q)) end proc``
EI := proc (Q) options operator, arrow; Xd__s(Q)*Iflec end proc    EI := proc (Q) options operator, arrow; eqo(Q)+Xd__s(Q)*Ido(Q) end proc
solve(EI(Q) = eqo(Q)+Xd__s(Q)*Ido(Q), {Eq, Ir, It, Ix, K__ds, K__qs, Q, Xd__s, Xq__s, el, eqo, ido, theta, `ΨAG__d`, `ΨAG__q`})
{Eq = Eq, Ir = Ir, It = It, Ix = Ix, K__ds = K__ds, K__qs = K__qs, Q = Q, Xd__s = Xd__s, Xq__s = Xq__s, el = el, eqo = eqo, ido = ido, theta = theta, `ΨAG__d` = `ΨAG__d`, `ΨAG__q` = `ΨAG__q`}
TRY3
     "Eq20:=Ir=P/(Et):     Eq21:=Ix=Q->Q/(Et):"
Error, invalid operator parameter name
"Eq20:=Ir=P/Et: Eq21:=Ix=Q->Q/Et:"
Download Qcalc1.mw
I have two functions, f(x) and g(x).
Based the plot, I can see that they intersect around x equals 0, 1, around 4.5 and 10.
So I tried to find the numerical solution by solving f(x) -  g(x) for x assuming x is real.
I'm stuck here because the aswer involves RootOf and _Z and I don't know what to do next.
This is what I've tried so far:
"f(x):=18*log10(x)"
proc (x) options operator, arrow; 18*log10(x) end proc
"g(x):=1/(2) x^(3)-8*x^(2)+(69/(2))^()*x-27"
proc (x) options operator, arrow; (1/2)*x^3-8*x^2+(69/2)*x-27 end proc
plot([f(x), g(x)], x = -1 .. 11)
`assuming`([solve(f(x)-g(x), x)], [x::real])
exp(RootOf(-(exp(_Z))^3*ln(10)+16*(exp(_Z))^2*ln(10)-69*exp(_Z)*ln(10)+54*ln(10)+36*_Z))
allvalues(exp(RootOf(-(exp(_Z))^3*ln(10)+16*(exp(_Z))^2*ln(10)-69*exp(_Z)*ln(10)+54*ln(10)+36*_Z)))
exp(RootOf(-(exp(_Z))^3*ln(10)+16*(exp(_Z))^2*ln(10)-69*exp(_Z)*ln(10)+54*ln(10)+36*_Z, 1.505446443)), exp(RootOf(-(exp(_Z))^3*ln(10)+16*(exp(_Z))^2*ln(10)-69*exp(_Z)*ln(10)+54*ln(10)+36*_Z, -3.291052648)), exp(RootOf(-(exp(_Z))^3*ln(10)+16*(exp(_Z))^2*ln(10)-69*exp(_Z)*ln(10)+54*ln(10)+36*_Z, 2.302585093)), 1
Download intersect_curve.mw
I know there's an answer to this because I can get the expected answer from Wolfram Alpha (see here).
How can I accomplish this in Maple?
I would like to know if it is possible to directly enter LateX expressions into the plot command. My goal is to be able to create a plot where the font style (in for example the title) can switch between LateX math and LateX regular. See the following example.
The LateX input used for the tilte was <Verl{\"a}ufe von $e(t)$ und $\dot{\varepsilon}_\mathrm{p}(t)$>
In Matlab one can use the command <"interpreter","Latex"> which allows direct LateX input. I am basically looking for an equvialent Maple command.
If no such command exists, I would be grateful for any idea on how to create a title like the one above with other methods.
Thanks to everyone in advance.
What is your choice for creating a good table?
For example;
f:=(x,t)->x*t;
g:=(x,t)->x^2*t;
How to create a table as follows? (Appearance similar to the following is not required. I am open to all options)
Hi, I am doing a project about three body problem. I am solving a DE system with 12 DEs and plotting it with phase portrait. It is all good if I am only using vars in scene. like this:
pp1 := phaseportrait([eq1(t), eq2(t), eq3(t), eq4(t), eq5(t), eq6(t), eq7(t), eq8(t), eq9(t), eq10(t), eq11(t), eq12(t)], [x1(t), y1(t), vx1(t), vy1(t), x2(t), y2(t), vx2(t), vy2(t), x3(t), y3(t), vx3(t), vy3(t)], t = 0 .. 8.75*10^7, [[x1(0) = X1, y1(0) = Y1, vx1(0) = VX1, vy1(0) = VY1, x2(0) = X2, y2(0) = Y2, vx2(0) = VX2, vy2(0) = VY2, x3(0) = X3, y3(0) = Y3, vx3(0) = VX3, vy3(0) = VY3]], scene = [x1(t), y1(t)], stepsize = 1000, x1 = 0 .. 10^6, y1 = 0 .. 6*10^6, color = [red], scaling = constrained):
But I cannot plot any combinations of my variables. I have orthogonalized all the velocity, and I can plot [t,vx(t)] or [t, vy(t)]. But I cannot plot [t, (vx(t)^2+vy(t)^2)^1/2]:
vel1 := phaseportrait([eq1(t), eq2(t), eq3(t), eq4(t), eq5(t), eq6(t), eq7(t), eq8(t), eq9(t), eq10(t), eq11(t), eq12(t)], [x1(t), y1(t), vx1(t), vy1(t), x2(t), y2(t), vx2(t), vy2(t), x3(t), y3(t), vx3(t), vy3(t)], t = 0 .. 3.5*10^7, [[x1(0) = X1, y1(0) = Y1, vx1(0) = VX1, vy1(0) = VY1, x2(0) = X2, y2(0) = Y2, vx2(0) = VX2, vy2(0) = VY2, x3(0) = X3, y3(0) = Y3, vx3(0) = VX3, vy3(0) = VY3]], scene = [t, (vx3(t)^2 + vy3(t)^2)^(1/2)], stepsize = 1000, linecolor = [purple], scaling = constrained);
Error, (in DEtools/phaseportrait) Invalid scene; must be list of vars: scene = [t, (vx3(t)^2+vy3(t)^2)^(1/2)]
Is there a way to let me plot the v(t) ?
why setting interface(warnlevel=0); makes dsolve change the form of the final solution to an ODE?
Is this to be expected? Help on warnlevel 0 says to just suppress all warnings.
In this example, both solutions are equivalent. One is just simpler than the other.
But now I am worried if this setting could affect dsolve in other ways not yet anticipated.
`Standard Worksheet Interface, Maple 2020.2, Windows 10, November 11 2020 Build ID 1502365`
`The "Physics Updates" version in the MapleCloud is 884 and is the same as the version installed in this computer, created 2020, November 25, 16:49 hours Pacific Time.`
ic:=y(0)=3:
ode := diff(y(x),x)*y(x)/(1+1/2*sqrt(1+diff(y(x),x)^2))=-x:
sol_1:=dsolve([ode,ic],y(x),singsol=all);
y(x) = -3+(1/3)*(-9*x^2+324)^(1/2), y(x) = 1+(1/3)*(-9*x^2+36)^(1/2)
ic:=y(0)=3:
sol_2:=dsolve([ode,ic],y(x),singsol=all);
y(x) = -3+(-x^2+36)^(1/2), y(x) = 1+(-x^2+4)^(1/2)
Download warnlevel_difference.mw
btw, the same thing happens with warnlevel 2. i.e. answers look different.
But with warnlevel 3 and 4, now dsolve gives the same answer.
SInce it seems default is warnlevel 3, it seems internally, dsolve takes different path depending on warnlevel setting?
Edit
Here is a movie. I am using windows 10.
Edit: Here is another video. Tried now with fresh start of Maple. i.e. closed Maple and started it again.  Using worksheet. No other worksheet was open. This is what I found. Initially it gives the longer solution. After couple of tries, it then changed to the simpler one
Please I have an issue with the attached plot code. Can you kindly help to correct it?
interface(rtablesize=infinity):
B:=<<0,0.05,0.1,0.15,0.2,0.25,0.3,0.35,0.4,0.45,0.49,"0","0.05","0.1","0.15","0.2","0.25","0.3","0.35","0.4","0.45","0.49">|
	<14.73,14.4,14,13.4,12.67,11.67,10.4,8.67,6,3,0,"14.73","14.4","14","13.4","12.67","11.67","10.4","8.67","6","3","0">|
     <-0.007072,0.013309,0.033707,0.054125,0.074571,0.095056,0.115597,0.136218,0.156956,0.177867,0.199036,0.22059,0.242719,0.265702,0.289932,0.31592,0.344214,0.375124,0.408175,0.441761,0.473484,0.501857>|
	<1.34E+01,1.33E+01,1.33E+01,1.32E+01,1.31E+01,1.31E+01,1.30E+01,1.29E+01,1.28E+01,1.26E+01,1.25E+01,1.22E+01,1.19E+01,1.14E+01,1.08E+01,9.86E+00,8.58E+00,6.90E+00,4.90E+00,2.81E+00,1.00E+00,-2.86E-01>>:
B:
 plot([B[..,[1, 2]],B[1..1,[1, 2]], B[.., [3, 4]],B[1..1,[3, 4]], B[..,[5, 6]],B[1..1,[5, 6]],B[.., [7, 8]],B[1..1,[7, 8]],
 	  B[..,[9, 10]],B[1..1,[9, 10]], B[.., [11, 12]],B[1..1,[11, 12]],B[..,[13, 14]],B[1..1,[13, 14]],B[.., [15, 16]],B[1..1,[15, 16]],
 	  B[..,[17, 18]],B[1..1,[17, 18]], B[.., [19, 20]],B[1..1,[19, 20]],B[..,[21, 22]],B[1..1,[21, 22]]],
 	  legend = ["","Experimental","","Simulation"],
 	  style = ["line","line","line","line","line","line","line","line","line","line","line","line","line","line","line","line",
 	 		"line","line","line","line","line","line"],
 	  color=[blue,red], labels=[`V (V)`, `Jsc (mA/cm^2)`]);
Download Graph_Example.mw
Hello community!
Given an equation
R := 1/N*S
where
S:=sum(exp(I*k*(i-1)*varepsilon), i = 1 .. n)
and can be interpreted as geometric series, so if we apply 'simplify' we get
(exp(I*k*n*varepsilon)-1)/(exp(I*k*varepsilon)-1)
The problem is in next steps, i want to obtain the final form using Maple
RR := sin((1/2)*k*n*varepsilon)/(n*sin((1/2)*k*varepsilon))
As known
(exp(I*k*n*varepsilon)-1)/(exp(I*k*varepsilon)-1) = e^(-(1/2)*j*k*n*varepsilon)*sin((1/2)*k*n*varepsilon)/(e^(-(1/2)*j*k*varepsilon)*sin((1/2)*k*varepsilon))
Hey there,
I'm trying to evaluate some parameter of a function when x and y are 0.
Here's the code:
> Y1 := proc (x) options operator, arrow; int(`Y1"`(x), x)+C1 end proc;
> solve({Y1(0) = 0}, {C1});
But unfortunately I get the following error:
Error, (in int) integration range or variable must be specified in the second argument, got 0
I know that the value of C1 is gonna be 0, but I want the program to say me this...
Please, some help.
i have a nonlinear equation,W, which have two unknowns: x and b
i want to solve W for b, and the x domain is : -4e-6<x<4e-6. can anyone help? tnx in advance
restart; with(DirectSearch)
E := (-7.29511346879067*10^9*b-12693.49752)*((D@@2)(phi))(x)+(5.36829162574305*b+0.3487242314e-3)*((D@@4)(phi))(x)+(2.02316788462733*10^17*b+4.107030812*10^12)*phi(x)+1.74615339888993*10^17*b
(-7295113469.*b-12693.49752)*((D@@2)(phi))(x)+(5.36829162574305*b+0.3487242314e-3)*((D@@4)(phi))(x)+(0.2023167885e18*b+0.4107030812e13)*phi(x)+0.1746153399e18*b
dsolve(E, phi(x))
ivp := {E, phi(-0.406e-3) = 1, phi(0.406e-3) = 1, (D(phi))(-0.406e-3) = 0, (D(phi))(0.406e-3) = 0}
{(-7295113469.*b-12693.49752)*((D@@2)(phi))(x)+(5.36829162574305*b+0.3487242314e-3)*((D@@4)(phi))(x)+(0.2023167885e18*b+0.4107030812e13)*phi(x)+0.1746153399e18*b, phi(-0.406e-3) = 1, phi(0.406e-3) = 1, (D(phi))(-0.406e-3) = 0, (D(phi))(0.406e-3) = 0}
N := dsolve(ivp, phi(x))
A := simplify(rhs(dsolve(ivp, phi(x))))
W := evalf(subs(phi(x) = simplify(rhs(dsolve(ivp, phi(x)))), (2.74505742817409*10^8+3.18054074382591*10^8*phi(x))^2-(1.63833629390402*(2.74505742817409*10^8+3.18054074382591*10^8*phi(x)))*(diff(phi(x), x, x))+3*(6.98727355657655*10^7+32282.4885498329*(diff(phi(x), x)))^2+2.68414581287153*(diff(phi(x), x, x))^2 = 0.9e17))
Download MZ2.mw
I found a condition for p, q that N=pq can be factored in plynominal time using Maple 2020.
Is fllowing Hypothesis and Proof is right?
Hypothesis
       N=pq  p and q are large prime respectively.
         R=q/p  q > p  R is very close to an small integer or a simple rational number.
        N=pq can be factorized in time polynomial
Proof
        point[p, q] is on y=N/x
        y=N/x  and y=Rx cross at point[p, q]
        N is n digit
        upper  2 digits N2  round off the 3rd digit
        upper  3 digits N3  round off the 4th digit
        upper  4 digits N4  round off the 5th digit
        y=N2/x and y=Rx cross at point[p2,q2]
        y=N3/x and y=Rx cross at point[p3,q3]
        y=N4/x and y=Rx cross at point[p4, p4]
        But we only know N.
        Let line up candidates point[p2,q2] , point[p3,q3] and point[p4, p4]
       N2 < 99  i=1..10 j=1..10
       R2=i/j
       f2=N2/R2 - j^2
       dn2=abs(N2-R2*j^2)
      N4 < 9999  i=1..99 j=1.. sqrt(N4)
      R4=i/j
      f4=N4/R4 - j^2
      dn4=abs(N4-R4*j^2)
     Point[j, i] that have  small f2 and dn2 can be nominated as candidate for point[p2, q2]
     Point[j, i] that have  small f3 and dn3 can be nominated as candidate for point[p3, q3]
     Point[j, i] that have  small f4 and dn4 can be nominated as candidate for point[p4, q4]
    Find cross point[px, qx] of y=R2x and y=N/x , y=R3x, y=N/x and y=R4x, y=N/x
    Find the nearest prime pn for px and the nearest prime qn for qx
   pn*qn=N  bingo!
   Number of candidates are finit.
   You can factorized N=pq in time polynomial.
        Q.E.D. ?
In addition, using "https://www.mapleprimes.com/questions/228532-Strange-Factorization"
Rang from p - half digits of p to p + half degits of p and /or range q - half digits of q to q + half degits of q  N=pq can be factored in plynominal time.
First 512 513 514 515 516 517 518 Last Page 514 of 2469
