https://www.mapleprimes.com/questions/219048-Help-File-Edit-After-Storing-In-A-Database
I found a previous post which contained a worksheet script for creating help, but this example is likely out-of-date. Can anyone provide a similar example for post-2018 help files to save me considerable trial and error.
I want to open an external *.XML file and put this information in a list (every part is a row). Later, i will change a specific row with other text. Finally, I want to copy all this changes in the same file (rewrite the file).
Someone to help me?
> den := -(-(conjugate(chi)-conjugate(phi))*(chi+phi)*conjugate(lambda)+lambda*(conjugate(chi)+conjugate(phi))*(chi-phi))*(-(conjugate(chi)+conjugate(phi))*(chi-phi)*conjugate(lambda)+lambda*(conjugate(chi)-conjugate(phi))*(chi+phi));
> phi:=exp(I*lambda*(x-t/(4*lambda^2)-w^2)):chi:=exp(-I*lambda*(x-t/(4*lambda^2)-w^2)):
> den1:=simplify(dsubs({phi,chi},den));
> dsubs({exp((1/4*I)*(4*lambda^2*w^2-4*lambda^2*x+t)/lambda), exp(-(1/4*I)*(4*lambda^2*w^2-4*lambda^2*x+t)/lambda)}, 4*conjugate(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2-4*conjugate(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+8*abs(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2+8*abs(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+4*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda^2-4*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda^2-16*abs(lambda)^2)
Since "cos(...)" appears in every term in last equation (except a last one), how to common it?
The  galois routine returns the group of  polynomials within quotation marks, e.g.  "6T1".
How to convert  things like  "6T1"  into just   6T1, i.e. how to get rid of the quotation symbols?
with(PDEtools):
alias(f=f(x,t),g=g(x,t));
f, g
eq1:=diff(f,x)=-I*eta*f +I*exp(-I*t)*g;
diff(f, x) = -I*eta*f+I*exp(-I*t)*g
eq2:=diff(g,x)=-I*eta*g +I*exp(I*t)*f;
diff(g, x) = -I*eta*g+I*exp(I*t)*f
eq3:=diff(f,t)=(I*eta^2-I/2)*f +I*eta*exp(-I*t)*g;
diff(f, t) = (I*eta^2-(1/2)*I)*f+I*eta*exp(-I*t)*g
eq4:=diff(g,t)=(-I*eta^2+I/2)*g +I*eta*exp(I*t)*f;
diff(g, t) = (-I*eta^2+(1/2)*I)*g+I*eta*exp(I*t)*f
#### The solution of (2)-(5) is
eq5:=f=I*(c1*exp(A)-c2*exp(-A))*exp(-i*t/2);
f = I*(exp(A)*c1-c2*exp(-A))*exp(-(1/2)*i*t)
eq6:=g=(c2*exp(A)-c1*exp(-A))*exp(i*t/2);
g = (c2*exp(A)-c1*exp(-A))*exp((1/2)*i*t)
#### where
c1=sqrt(h-sqrt(h^2-1))/sqrt(h^2-1);c2=sqrt(h+sqrt(h^2-1))/sqrt(h^2-1);A=sqrt(h^2-1)*(x+I*h*t);
c1 = (h-(h^2-1)^(1/2))^(1/2)/(h^2-1)^(1/2)
c2 = (h+(h^2-1)^(1/2))^(1/2)/(h^2-1)^(1/2)
A = (h^2-1)^(1/2)*(x+I*h*t)
#### How to verify (6) and (7) is the solution of (2)-(5)?
Download verification.mw
I'm trying to document some generator calculations that use terms line Xd'. In Maple that turns into a derivative. I converted several 'ed variables into atomic variables. They have made my work sheet unusable. They appear to randomly loose connecin to their assigned values and prevent numeric solutions by showing  up in symbolic form. Once this happens, I have to check each instance where the variable isuse to find where the loss/lossses occured. (copy and past each instance of the variable and check its value).
Once found I can't find a consistant way to re-associate them with the assigned value.
Any suggestions. See botton of attaced work sheet.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/WS_Gen_I_and_E_for_fauls_on_HS_of_GSU_-_Time_Response_&_51V_Trip_Times_-R5a.mw .
Download WS_Gen_I_and_E_for_fauls_on_HS_of_GSU_-_Time_Response_&_51V_Trip_Times_-R5a.mw
How to define 4 functions from the dsolve solution of a system of 4 differential equations?
restart: with(plots): with(DEtools):with(LinearAlgebra):with(Statistics):with(CurveFitting):with(Optimization):
ddesys := {diff(S(t),t) = -beta*S(t)*Ix(t)/N,
diff(Ex(t),t) = beta*S(t)*Ix(t)/N - sigma*Ex(t-tau__1),
diff(Ix(t), t) = sigma*Ex(t - tau__1)- gamma*Ix(t-tau__2),
diff(R(t),t) = gamma*Ix(t-tau__2),
diff(Dx(t),t) = delta*Ix(t),
S(0) = 80900, Ex(0) = 1, Ix(0) = 1, R(0) = 0, Dx(0) = 0 }:
dsn := dsolve(eval(ddesys, {beta = 4, gamma = 0.0478, sigma = 0.10, delta = 0.0005, N=80900, tau__1 = 1.1,tau__2 = 8.7,tau__3 = 0}), numeric):
Please can you give me a hand with numerical solving and visualising the partial differential wave equation with stochastic term eta(t), using methods of stochastic calculus?
diff(u(x, t), t $ 2) - (1+eta(t))*diff(u(x, t), x $ 2) = 0
I had a look at the "stochastic" package by Sasha Cyganowski, but couldn't find an example for stochastic pde.
Look forward to your help.
Dmitrii
Here is a known probability riddle:
A and B are two lists of 100 binary numbers:
A:=[0,1,0,1,0,1,1,0,1,1,1,0,0,1,1,1,1,0,1,0,1,0,1,0,1,0,1,1,0,1,0,1,0,0,0,1,0,1,0,1,0,1,1,1,1,1,0,0,1,0,1,0,1,0,1,0,1,1,1,0,1,0,1,0,0,0,1,1,1,1,0,0,0,1,0,1,0,0,0,0,0,1,1,1,0,1,0,1,0,1,0,1,0,0,0,1,1,0,1,0]:
B:=[0,1,1,0,1,1,0,1,1,1,0,1,0,0,1,1,0,0,0,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,1,1,1,0,1,0,0,0,1,0,1,0,1,1,0,1,1,0,0,0,0,0,0,1,0,1,1,1,0,0,0,1,0,1,0,0,0,0,1,0,0,0,0,1,0,1,1,1,1,1,1,0,0,0,1,1,1,1,1,1,1,0,0,1,0]:
One was obtained by tossing a coin (1 for a head, 0 for a tail), and the other by a human, who was asked to simulate tossing a coin.
Question: which one comes from a human brain?
The standard answer: B was produced using a coin, because (among other things) the probabilty of obtaining a "000000" or "111111" is about 80%, but a humain brain tends to avoid such "simulations".
My Question: what (if any) statistical test can be used in Maple for an answer?
(I have tried ChiSquareSuitableModelTest but both lists were accepted).
# I solved the differential equation using a fourier series decomposting method. I found with the help of "Dsolve" the different expressions of the fourier constants and now I will apply the boundary conditions to find the expressions of its constants.
#this my boundary conditions
#this my system of equations
Recently Maple started freezing on me for a few minutes; after that it continues to work and then freezes again and so on (it does not so much freezes as it pauses).  I do not know what changed on my system (which is Windows 10) for this to happen.  I had been using Maple 2019 when this started and then upgraded to Maple 2020 but that did not solve my problem.
It does not seem to have to do with the type of computations I am doing.
I have problem with usage of solve for the solution of the system of six and eight symbolic equations. I need to get expressions for variables: R__xl, R__xs, R__xsi, R__zl, R__zs, R__zsi, dbeta__l(t), dbeta__s(t). I tried to find solution for 8 equations, but I got the message: Warning, solutions may have been lost. I thought that the system is non-linear and tried to solve it for six variables (R__xl, R__xs, R__zl, R__zs, R__zsi, R__xsi), in this case equations are linear, but Maple ignored the solve command and did not give a solution or error. Could someone help me with this problem?
Quasi-static.mw
I am not sure how to choose between Threads:-Seq and Grid:-Seq.
The problem:  a procedure, proc1, that calls two other procedures, proc2 and proc3, verifies if a set of parameters fulfills a certain condition. Proc1, proc2 and proc3 are not part of Maple available functions.
Right now I am using Grid:-Seq to return the result of applying proc1 to chunks of a thousand parameters.  I wonder whether I could use Thread:-Seq instead.   What are the advantages of using one instead of the other?  And when do I choose one over the other?
I would appreciate if you could provide simple examples to explain the differences.
Many thanks.
Ed
PS.  There is a problem with Grid:-Seq as reported in one of my previous questions.
Maple 2017.3 has these problems which hamper my work with it. I shown three examples.
Example 1: Maple cannot recognize automatically that two complex numbers are equal:
[>eq1:=9*exp((1/9)*(5*I)*Pi)-9*exp((1/9)*(2*I)*Pi) = -8*exp((1/9)*(2*I)*Pi)+7*exp((1/9)*(5*I)*Pi)+exp((1/18)*(13*I)*Pi)*sqrt(3);
Here, lhs(eq1) and rhs(eq1) are in fact equal. Yes, evela(simplify(lhs(eq1)-rhs(eq1)) reduces to zero but not when solving equations (see Example 2).
Example 2:
[>sys1:=[_xx[1]+lhs(eq1),_xx[1]+rhs(eq1)];
[>solve(sys1,[_xx[1],_xx[2]]);
yields no answer.
Example 3:
[>alias(omega=RootOf(_Z^2+_Z+1));
[>rt:=(-1+I*sqrt(3))/2;
Maple fails to substitute the alias and recognize that rt=omega.
Any suggestion on a work-around problems 2 and 3 would be helpful.
Rafal Ablamowicz
www.math.tntech.edu/rafal/
I have load the new Physics-Version 678, but it is not active. How can I do this?
Here the output:
                           version()
 User Interface: 1455132
         Kernel: 1455132
        Library: 1455132
       MapleIDE: 928330
                            1455132
                      interface(version)
Standard Worksheet Interface, Maple 2020.0, Windows 10, March 4
   2020 Build ID 1455132
                      kernelopts(version)
   Maple 2020.0, X86 64 WINDOWS, Mar 4 2020, Build ID 1455132
                       Physics:-Version()
The "Physics Updates" version in the MapleCloud is 678 and is
   the same as the version installed in this computer, created
   2020, May 20, 10:21 hours, found in the directory
   C:\Users\wgellien\maple\toolbox\Physics Updates\lib\
                     Physics:-Version(678)
Warning, this package updates content shipped in a standard Maple install.  Use the 'restart' command to clear your session before using these commands.
Kernel(The "Physics Updates" version "678" is installed but is
   not active. The active version of Physics is within the
   library C:\Users\wgellien\maple\toolbox/Physics Updates/lib\P\
  hysics Updates.maple, created 2020, May 20, 14:46 hours),
  [The "Physics Updates" version "678" is installed but is not
   active. The active version of Physics is within the library
   C:\Users\wgellien\maple\toolbox/Physics Updates/lib\Physics
   Updates.maple, created 2020, May 20, 14:46 hours]
With kind regards
Wolfgang Gellien
First 584 585 586 587 588 589 590 Last Page 586 of 2459
