Good morning everyone
I'm sorry if I'm asking a simple question, but I would like to create a maplet from a maple code I written.
My first problem is I would like to now how to create a table like in excel, to be fill up by the user of the maplet.
Basically, the maplet will consist of enter two parameters who define the number of colums and row needed for the table,
Then fill up this table, which gonna be plot, and then a button to fit this curve using an equation. And the starting value in order to fit the curve will also be set up by the user.
Thanks you in advance if you can help me to set up this table in the maplet.
cheers!
in Maple 2017 (could not try 2018) the following is a bug;
with(LinearAlgebra);
U:= Matrix(4,4, shape=triangular[upper, unit], symbol =u);
-U;
It returns the wrong matrix, with +1 on the diagonal and -u_{ij} on the upper part. That is, it changes the sign only of the entries in the upper part. The bug is for any size, and also for lower triangular.
I have been trying to use fsolve to iteratively solve a free convection heat transfer problem for a heated vertical plate using units and the ThermoPhysicalData library.  I have received some help and have managed to get rid of the eror messages but I still can't seem to get it to solve.
Here is the code
with(Units:-Standard); with(ThermophysicalData);
conv_VerticalPlate_proc := proc (T__side, T__amb, Area, L, varepsilon, q__i)
  local sigma, g, T__s, `T__∞`, T__f, k, rho, Cp, Pr, mu, nu, alpha, beta, Ra__L, Nus__L, h, q__h, q__r, q__total;
  g := 9.81*Unit('m'/'s'^2); sigma := 5.6703*Unit('W'/('m'^2*'K'^4))/10^8;
  if type(T__side, with_unit) then
    T__s := convert(T__side, temperature, kelvin)
  elif T__side = 0 then
    T__s := 273.15*Unit('K')
    T__s := T__side*Unit('K')
  if type(T__amb, with_unit) then
    'T__∞` := convert(T__amb, temperature, kelvin)
  elif T__amb = 0 then
    'T__∞` := 273.15*Unit('K')
    `T__∞` := T__amb*Unit('K')
  T__f := (1/2)*T__s+(1/2)*`T__∞`;
  k := Property(thermal_conductivity, temperature = T__f, pressure = Unit('atm'), air);
  rho := Property(density, temperature = T__f, pressure = Unit('atm'), air);
  Cp := Property(Cpmass, temperature = T__f, pressure = Unit('atm'), air);
  Pr := Property(prandtl, temperature = T__f, pressure = Unit('atm'), air);
  mu := Property(viscosity, temperature = T__f, pressure = Unit('atm'), air);
  if type(k, with_unit) and type(rho, with_unit) and type(Cp, with_unit) and type(mu, has_unit) then
    nu := mu/rho;
    alpha := k/(rho*Cp);
    beta := 1.0/T__f;
    Ra__L := g*beta*abs(T__s-`T__∞`)*L^3/(alpha*nu);
    Nus__L := (.825+.387*(Ra__L^(1/6))/(((1+(.492/Pr)^(9/16))^(8/27))))^2;
    h := Nus__L*k/L; q__h := h*(T__s-`T__∞`)*Area;
    q__r := varepsilon*sigma*(T__s^4-`T__∞`^4)*Area;
    q__total := q__h+q__r
    0.1e-6*Unit('W')
  end if
conv_VerticalPlate_proc(31.5*Unit('degC'), 20*Unit('degC'), Unit('m'^2), Unit('m'), .9);
                      100.8567010 Unit(W)
conv_VerticalPlate_proc(x*Unit('degC'), 20*Unit('degC'), Unit('m'^2), Unit('m'), .9);
                         0.001 Unit(W)
fsolve(100*Unit('W')-conv_VerticalPlate_proc(x, 20*Unit('degC'), Unit('m'^2), Unit('m'), .9), x = Unit('degC') .. 100*Unit('degC'));
I would appreciate help wih this.
For example if a:=[3,3,1,5,7,8,5,4,4,4,4,3,9]
What is the simplest way, or alternate ways, to remove only one 4 for example from the dataset.
model.mw
after loop how to pick equations automatically solve system of equations???
I've just upgraded from v2017.3 to 2018. It worked OK until I installed latest service pack 2018.2.1 (server license provided by my University). Ever since I cannot use Maple. Anything I type I get Typesetting:-mparsed(...) error and the text/command I typed.
I’ve contacted our software tech support and they told me to change the typesetting level from advanced to standard and it did fix the problem.
But why does it happen in the first place? I’m running Windows 8.1 64bit. Out tech support told me to has something to do with 3D display issue on my machine and told me to bring my laptop on Monday to see if they can resolve the issue.
Anyone else have this problem? Why didn’t it happen with older Maple versions? What am I missing by using standard typesetting instead of the default advanced?
how can I get a positive output in the following example
solve((hv*hw+lv*lw)/(lv+hv)*(lv+hv) = dw*(lv+hv), hv)
instead of -lv*(dw-lw)/(dw-hw) I would like lv*(dw-lw)/(hw-dw)
Hi. how can maple determine whether a vector is linear compostion of two or more vectors?
for example w=a*v+b*u so that w is linear compostion of vectors u and v ( a and b are scalar numbers). tnx for the help.
 Given  any graph , I want to  determine the number of cycles of the graph .  What should I do?
I have this equation but maple solve root is 2
Root_eq.mw
Root is 4 x1 =1, x2= 8.95006470,
x3 =0 .6939575785
x4 = -0.6440222825
Local*Gamma:
v[1](x, t) = v[1]*(-x*v[1]-x*`θv`[2]-v[1]-v[2]+1)
v[2](x, t) = gamma*v[2]*(lambda-v[1]-v[2]-eta*(x*v[1]+x*`θv`[2]))
Download DTM_TO_SOlve.mw
Is there any way to transfer to transfer a table into Maple? I made a table in Google Sheets / Excel and I want to put it in my maple worksheet
What's going wrong here?
The Matrix is created by using the Matrix Palette.
It seems that in a matix it is not possible to use division by a noninteger. Is that right?
(I use Maple 2018.2 and this is tested on both Windows and MacOS.)
Kind regards,
Mikkel
with*PDE(tools):
`∂`(v[1])/`∂`(t) = v[1]*[-x*v[1]-x*`θv`[2]-v[1]-v[2]+1]
`∂`(v[2])/`∂`(t) = gamma*v[2]*[lambda-v[1]-v[2]-eta*(x*v[1]+x*`θv`[2])]
Hello, for an assignment I was given the task of iteratively calculating the water depth of a flow using Newton's method. For this I tried to create a procedure wich uses a number of input values. The code is listed below;
Newton := proc (n, y0, Q, b, m, k, S0) local A, P, Sf, y, F, dAdy, dPdy, Fdiff, i; global ylist; y[0] := y0; for i from 0 to n do A[i] := (b+m*y[i])*y[i]; P[i] := b+2*y[i]*sqrt(1+m^2); Sf[i] := Q*abs(Q)*P[i]^(4/3)/(k^2*A[i]^(10/3)); F[i] := S0/Sf[i]-1; dAdy[i] := b+2*m*y[1]; dPdy[i] := 2*sqrt(1+m^2); Fdiff := (2/3)*(F[i]-1)(5*dAdy[i]/A[i]-2*dPdy[i]/P[i]); y[i] := procname(evalf(y[i]-F[i](y[i])/Fdiff[i](y[i]))) end do; ylist := [seq(y[i], i = 0 .. n)]; return ylist end proc;
Newton(10, 1, 5, 12, 1, 30, 0.1e-4);
Error, (in Newton) invalid input: Newton uses a 2nd argument, y0, which is missing
As you can see, I get an error referring to the second argument y0, which is the starting value of the calculation. The error says the argument is missing, however it is right there in the brackets of the Newton procedure (along with the values of all other parameters). I have tried explicitly stating that y0:=1, and changing the name of the parameter, however that didn't help.
Am I missing something really simple, or is there something wrong with my code?
First 750 751 752 753 754 755 756 Last Page 752 of 2459
