I need help solving Translation Step4 and Dilation Step5
Translation
Ta,b(x,y)=(x+a,y+b)
Dilation
Dk(x,y)=(kx,ky)
This works:
plot(tickmarks = [spacing(1), spacing(2)]);
but not this:
plot(axis = [tickmarks = [spacing(1), spacing(2)]]);
Error, (in plot) incorrect value for option tickmarks or gridlines: [spacing(1), spacing(2)]
Seems wrong, and the problem is that for gridlines neither form works, so gridlines=[spacing(1), spacing(2)] doesn't seem to be possible.
In the partial fraction decomposition Maple often changes the order of the terms.
For example,
How do we remedy this?
mapleatha
Dear Maple  users,
I am facing the memory allocation problem while calculating the inverse Laplace transformation of a big expression. I have many such terms (401) and I am importing them from a text file.
For an individual term itself, Maple consumes huge memory but at the end, it is able to calculate it in about an hour. I want to automate the process of reading and writing the terms one by one from the different text files. While doing so, maple eats a lot of memory and I see the error msg
"Error, (in expand/bigprod) Maple was unable to allocate enough memory to complete this computation.
Please see ?alloc "
Is there a way to do so? The maple file is attached.
InvLaplace_ex.mw
I have invalid operator parameter name, i don't know where is the mistake.
Many thanks for your help
fdfd.mw
I'm producing multiple matrices via a for-loop (n = + 100) and I want to export each matrix into the same Excel-sheet, however I want to insert all matrices in cells beneath each other. I'm wondering if anyone knows how to do this? I've tried a loop variable but that doesn't work inside the "  " to specify the cells...
Note: Matrices are all 11x6. That means I want them inserted in the same sheet, in cells like this:
1st matrix: A1:F11
2nd matrix: A12:F23
3rd matrix: A24:F35
etc.
In other words: how to execute a loop-variable inside the " ", or to bypass it???
Please help! It's for my MSc Thesis:)
Helo dearz!
I want to find the inverse laplace transfrom (numerically) of the attached file of solution u and v for any values of M. I am waiting for your positive response.
Help_v2.mw
how to download  wkptest from http://cpc.cs.qub.ac.uk/summaries/ADTY_v1_0.html and install on maple?
I understand that matlab has function 'rfwrite' to generate touchstone file. This is a datafile used for high frequency modeling.
Is there any such package in Maple?
I´m new to Maple and I´m trying to find the minimum distance of an ECC from its parity check matrix or the generator matrix. Is this possible?
I have work sheet full of greek letters as words and parameters, some times I need to find where the specific letter is, but it seems find facility (Ctrl+F) couldnt find greek letters.
Suppose I have following workshee
II := 1
JJ := 1
N := 1
UK2
U1 := add(add(add(add(add((2*Rr[i, m]*Rr[k, m]/((2*m+1)*(2*j+1))*(2*b/(2*a)))*(A[1, 1]*U[i, j]*U[k, j]+2*A[1, 6]*U[i, j]*V[k, j]+A[5, 5]*W[i, j]*W[k, j]+A[6, 6]*V[i, j]*V[k, j]+2*B[1, 1]*Phi[i, j]*U[k, j]+2*B[1, 6]*V[i, j]*Phi[k, j]+2*B[1, 6]*Xi[i, j]*U[k, j]+2*B[6, 6]*Xi[i, j]*V[k, j]+Dd[1, 1]*Phi[i, j]*Phi[k, j]+2*Dd[1, 6]*Phi[i, j]*Xi[k, j]+Dd[6, 6]*Xi[i, j]*Xi[k, j]+(-R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^4+4*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^3-6*T[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+4*K[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-Delta[1, 1, q])*GAMMA[i, j, q]*GAMMA[k, j, q]+(2*R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^3-6*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+6*T[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-2*K[1, 1, q])*Omega[i, j, q]*GAMMA[k, j, q]+(-2*R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+4*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-2*T[1, 1, q])*Theta[i, j, q]*GAMMA[k, j, q]+(2*E[1, 5, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2-4*F[1, 5, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]+2*G[1, 5, q])*W[i, j]*GAMMA[k, j, q]+(-R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+2*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-T[1, 1, q])*Omega[i, j, q]*Omega[k, j, q]+(2*R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-2*S[1, 1, q])*Theta[i, j, q]*Omega[k, j, q]+(-2*E[1, 5, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]+2*F[1, 5, q])*W[i, j]*Omega[k, j, q]-R[1, 1, q]*Theta[i, j, q]*Theta[k, j, q]+2*E[1, 5, q]*W[i, j]*Theta[k, j, q]), i = 0 .. II), k = 0 .. II), m = 0 .. II), j = 0 .. JJ), q = 1 .. N):
Download greekfind.mw
t, how to find for example `#mover(mi("z"),mo("&uminus0;"))`[q] in it?
A fact that seems to be not documented. Probably it should be obvious.
Digits := d0
evalf[d](expr);
The toplevel float sub-expressions in expr  are computed with Digits=d0 but in procedures Digits is set to d.
Notice that the actual float parameters of the toplevel procedures are evalf-ed with Digits=d0.
g:=proc() convert(1/3., string) end:
h:=proc() 1/3. end:
Digits:=3;
evalf[10]([
  1/3. = h(),
  convert(1/3.,string) = g(),
  fsolve(3*x=1) = add([1/3]),
  fsolve(x/3=1/9.) # 1/9. being at top level is evalf-ed with Digits=3
[.333 = .3333333333, ".333" = ".3333333333", .3333333333 = .3333333333, .3330000000]
k:=proc(x) convert(x,string) end:
kernelopts(floatPi);
4.+Pi;
7.14
evalf(k(1/3.+Pi));
# floatPi seems to be ignored inside actual parameters
".333+Pi"
evalf(k(4+evalf(Pi)));
"7.14"
evalf(k(4+Pi));
# 4 not being float (or "infected" by a float) is not evalf-ed
"4+Pi"
### (this is documented)
`evalf/h` := proc() 7.777 end:
evalf(h(1/3));
.333
evalf('h'(1/3));
7.777
Download digits.mw
(edited)
variables := s, phi(s);
                           s, phi(s)
expr := (k*s^2+1)*(diff(phi(s), s, s))-k*phi(s)+s*k*(diff(phi(s), s));
  /   2    \ / d  / d        \\                  / d        \
  \k s  + 1/ |--- |--- phi(s)|| - k phi(s) + s k |--- phi(s)|
             \ ds \ ds       //                  \ ds       /
expr2 := int(expr, s);
                           /   2    \ / d        \
             -s k phi(s) + \k s  + 1/ |--- phi(s)|
                                      \ ds       /
int(expr2, s);
            /              /   2    \ / d        \   \
         int|-s k phi(s) + \k s  + 1/ |--- phi(s)|, s|
            \                         \ ds       /   /
solve({int(expr2, s)});
Error, (in solve) cannot solve expressions with int(-s*k*phi(s)+(k*s^2+1)*(diff(phi(s), s)), s) for s
I DIDN'T GET THE SOLUTION.PLEASE HELP
I have two big symbolic and numerical matrices in a worksheet, whats the best way and easiest way to transfer them to another maple worksheet?
Why is Maple 13 giving me
instead of (s-3)/((s-3)^2+4)?
mapleatha
First 938 939 940 941 942 943 944 Last Page 940 of 2460
