When I use functions from the DocumentTools to display information in a Maple document, they display a weird bracked along the left hand side of the display. I would like them to display in the same way they do in the help pages. I have attached a document showing the results I get when I repeat some of the examples from the help pages.
display-problems.mw
subs can not make diff(1, t) = 0
sys := simplify(subs(diff(1,t)=0,subs(c(t)=1,[ode1a,ode3a])));
sys := [diff(a(t), t) = 1.342398800*10^5*a(t)+89591*b(t)+44647, 44647*a(t)+44902*b(t)+44859];
DEplot(sys, [a(t), b(t)], t = 0 .. 16, a = -16 .. 16, b = -16 .. 16, color = magnitude, title = `Stable Limit Cycles`, arrows = curve, dirfield = 800, axes = none);
Error, (in DEtools/DEplot/CheckDE) derivatives must be given explicitly
why can not plot?
How do I use characters in a file using the "read" statement?
Example: The following function code is written in a textfile test.mpl.
test:=proc()
print("hüstel");
I read the file with
> read("test.mpl");
> test()
"h�stel"
The Letter "ü" appears like "�".
If the comand is input direct in the document mode it appears correct:
print("hüstel");
"hüstel"
ygraph1 := -.736312023696564122*exp(2.26140104440167664*10^5*tt)-.591826613918776445*exp(28994.5376895644186*tt)+.328002839648234568*o*exp(13767.7178702679158*tt);
ygraph2 := -.591859486202007235*exp(2.26140104440167664*10^5*tt)+.328381376616263988*exp(28994.5376895644186*tt)-.736116852194203974*o*exp(13767.7178702679158*tt);
ygraph3 := -.327943520064913564*exp(2.26140104440167664*10^5*tt)+.736143281263262450*exp(28994.5376895644186*tt)+.592069351595225779*o*exp(13767.7178702679158*tt);
FunctionAdvisor(branch_points, ygraph1);
plot(ygraph1, tt=-5..5);
plot(ygraph2, tt=-5..5);
plot(ygraph3, tt=-5..5);
Warning, unable to evaluate the function to numeric values in the region;
how to plot this system?
I have encountered bug in factors/fsolve while working with 19-th degree polynomial:
Digits:=150:
T:=-6.22380759047872668130713536877030256364968636070065651396334810246948704517800844289400608484048587112392332204805530128070851889819985512874202683743*10^11*x^15+1.30320674544020861155773378297484119553167774488351680864188235543008368581731239587845304516984389100205019741111280194189829856859808540642557769603*10^10*x^6-4.66269056752439302342961934783764679009596024511170531603537327397832302302620600217387943312388922053304167698527169182278585860427802821480352854136*10^11*x^9-2.23704996926446119043671514798254764988240075983626880645807120500701523185370168392321824617257975062292105400290171941856646211919772527234308968846*10^9*x^5+1.70227750800986164284793608409450414651109713000703213281475661248797845709368255736580952492853671050778821135335145407044800619189451776936359075686*10^12*x^12+2.75132914316444017343930750158891109941047127103886960894939389127711887329536485172215512793127850186551483171384960841607262449527761786758828223621*10^8*x^4-34932.1305741980482332724462824276603543110574918698909627427160477228536038554704823433224807581628905769847550345090785500099182662763447500819501675*x+1.14859089243616386902401277001127426741536679789632050800564282457083136981495352758127041512610195469873039580049988570650313838832989727748112868586*10^12*x^14-6.60479740997269404871863401649844958253760499264982628400515571200965556608668632440745621931354881132921476624343305820884923453724427367494415551238*10^10*x^17-5.62833694496139881587566825658979473046292640751330993837612787833792702707901920475562429114656627532669843830531312111426766840057855202536781521123*10^10*x^7-1.41317084251894030640575308228417182186337397538022537825365672333611503622567981167488384741420461775617951229535582868905095341476313150469092017698*10^12*x^11-8.21268191019727949807038061270674769712976810595535494085869238004490345847174711476348954310804852930678468602300916137608391140935636924900016951244*10^8*x^19+397.252699937115297695173788383107213691513398731729934944369484808586994493337920006396692649274392699364304534062337678482629861430643165733668575822+2.45061767631130714142188028061597642324588736935628490184983950396964320020866945354270367821778753632385377702112725604392839751008695021580743844404*10^11*x^16+1.08699947236093139248842860047684411564605736115175003178583710408973712475471303403438454553797809672473740940054172927497665894877177132800140413775*10^10*x^18+1.84485142971549353599220669614768264648023215439682851036030548807708252959822522849421648368214446092969270608024147362000126035954415744321702508798*10^11*x^8-2.30461084758765666852675422975553976835398815305842562217293737088819307979848024374022174488508670823626363788957243202121075401744096241597591787541*10^7*x^3+9.17691101238967627829517731270700894639677345422963842539705370480050031196020089039807157125184117990094461042715726886282973724309183151499484709563*10^11*x^10-1.59505142070054081045558935086478494555622632474984266672719416019069437321867830698450310020630535513817946854845186492455277659549284062382504657541*10^12*x^13+1.21399269842294123787022397507857250840398420627023248941081275489711499859955449395398103964932227544163416388726749227644470585060488880538430515276*10^6*x^2:
infolevel[fsolve]:=3:
fsolve(T,fulldigits); # <-- completes without issues
factors(T);           # <-- freezes with log:
fsolve: ill-conditioned polynom of degree 19, with 0(0) given roots
fsolve: 1th root found in 9 iters at 165 Digits
fsolve: 2th root found in 11 iters at 164 Digits
fsolve: 3th root found in 11 iters at 165 Digits
fsolve: 4th root found in 10 iters at 174 Digits
fsolve: 5th root found in 10 iters at 167 Digits
fsolve: 6th root found in 11 iters at 168 Digits
fsolve: 7th root found in 11 iters at 174 Digits
fsolve: 8th root found in 11 iters at 170 Digits
fsolve: 9th root found in 11 iters at 181 Digits
fsolve: 10th root found in 11 iters at 172 Digits
fsolve: 11th root found in 12 iters at 175 Digits
fsolve: 12th root found in 11 iters at 182 Digits
fsolve: 14th root found in 14 iters at 177 Digits
fsolve: 15th root found in 10 iters at 176 Digits
fsolve: 16th root found in 11 iters at 173 Digits
The most interesting thing is that standalone 'fsolve' finishes fine, but 'factors' freezes in 'fsolve:-polyill' on the same polynomial.
My system is: Windows 7 x64, Maple 2017.0.
Would appreciate any help on how to avoid the issue with 'factors'.
ode1a := diff(a(t), t) = 1.342398800*10^5*a(t)+round(89591.20000)*b(t)+round(44647.44000)*c(t);
ode2a := diff(b(t), t) = round(89591.20000)*a(t)+round(89803.24000)*b(t)+round(44901.60000)*c(t);
ode3a := diff(c(t), t) = round(44647.44000)*a(t)+round(44901.60000)*b(t)+round(44859.24000)*c(t);
sol := dsolve([ode1a=exp(t), ode2a=exp(t), ode3a=exp(t)], [a(t),b(t),c(t)]);
Error, (in dsolve) invalid input: `PDEtools/NumerDenom` expects its 1st argument, ee, to be of type algebraic, but received diff(a(t), t) = (3355997/25)*a(t)+89591*b(t)+44647*c(t)
initially i guess the error come from decimal number coefficient
but after round it, still have error
ode1a := diff(y1(tt), tt) = 1.342398800*10^5*y1(tt)+89591.20000*y2(tt)+44647.44000*y3(tt);
ode2a := diff(y2(tt), tt) = 89591.20000*y1(tt)+89803.24000*y2(tt)+44901.60000*y3(tt);
ode3a := diff(y3(tt), tt) = 44647.44000*y1(tt)+44901.60000*y2(tt)+44859.24000*y3(tt);
would like to find the origin eigenstate before it collapse to eigenvalues
how to apply ricci flow in this situation?
i find help file , and can not find some relationship between this application and inputs of ricci related function
which functions in maple can help to find origin of eigenstate
DEplot3d({ode1a,ode2a,ode3a}, {y1(tt), y2(tt), y3(tt)}, tt=0..10,[[y1(0) = 0, y2(0) = 0, y3(0) = 0]],scene=[tt,y1(tt),y2(tt)]);
DEplot3d({ode1a,ode2a,ode3a}, {y1(tt), y2(tt), y3(tt)}, tt=0..10,[[y1(0) = 0, y2(0) = 0, y3(0) = 0]],scene=[tt,y1(tt),y3(tt)]);
DEplot3d({ode1a,ode2a,ode3a}, {y1(tt), y2(tt), y3(tt)}, tt=0..10,[[y1(0) = 0, y2(0) = 0, y3(0) = 0]],scene=[tt,y2(tt),y3(tt)]);
can it plot 3 functions ?
and why it return a straight line 3d graph
is there some interesting graph from this system?
iam trying to apply newton method on non liner system but i have a problem for apply while loop inside other while loop
any help please
with(VectorCalculus):
f[1] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(x^2, VectorCalculus:-`-`(VectorCalculus:-`*`(z, exp(y)))), VectorCalculus:-`-`(VectorCalculus:-`*`(y, exp(z)))), 61):
f[2] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(x, y), z), VectorCalculus:-`-`(exp(x))), -3):
f[3] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(x^2, y^2), z^2), -14):
F := Matrix([[f[1]], [f[2]], [f[3]]]):
FF := eval(F, [x = x[k], y = y[k], z = z[k]]):
X := Matrix([[x], [y], [z]]):
XX := eval(X, [x = x[k], y = y[k], z = z[k]]):
J := Jacobian([f[1], f[2], f[3]], [x, y, z]):
JJ := eval(J, [x = x[k], y = y[k], z = z[k]])
JJ := Matrix(3, 3, {(1, 1) = 2*x[k], (1, 2) = -z[k]*exp(y[k])-exp(z[k]), (1, 3) = -exp(y[k])-y[k]*exp(z[k]), (2, 1) = y[k]*z[k]-exp(x[k]), (2, 2) = x[k]*z[k], (2, 3) = x[k]*y[k], (3, 1) = 2*x[k], (3, 2) = 2*y[k], (3, 3) = 2*z[k]})
k := 0:
xi := convert(exp(-10), float):
maxval := 10^4:
while convert(Norm(FF, 2), float) > xi do alpha[k] := min(1, alpha[k]/lambda); L := 1/JJ.FF; K := -L*alpha[k]+XX; x[k+1] := evalf(Determinant(K[1])); y[k+1] := evalf(Determinant(K[2])); z[k+1] := evalf(Determinant(K[3])); A := convert(Norm(FFF, 2), float)^2; B := convert(Norm(FF, 2), float)^2; while A > B do L := 1/JJ.FF; alpha[k+1] := lambda*alpha[k]; K := -L*alpha[k+1]+XX; x[k+1] := evalf(Determinant(K[1])); y[k+1] := evalf(Determinant(K[2])); z[k+1] := evalf(Determinant(K[3])) end do; k := k+1 end do
alpha[0] := 1
L := Matrix(3, 1, {(1, 1) = -(12900-300*exp(8)-1200*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)-(2*exp(8)+31*exp(2))*(77-exp(5))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)-(395/2)*(7*exp(8)-4*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500), (2, 1) = (84+exp(5))*(86-2*exp(8)-8*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)+(5/2)*(4+exp(8)+8*exp(2))*(77-exp(5))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)+(79/4)*(exp(8)*exp(5)+8*exp(2)*exp(5)-16*exp(8)-128*exp(2)-400)/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500), (3, 1) = -(-39+4*exp(5))*(86-2*exp(8)-8*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)-(5/2)*(16+2*exp(8)+exp(2))*(77-exp(5))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)-(79/4)*(2*exp(8)*exp(5)+exp(2)*exp(5)-32*exp(8)-16*exp(2)-100)/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)})
K := Matrix(3, 1, {(1, 1) = 5+(12900-300*exp(8)-1200*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)+(2*exp(8)+31*exp(2))*(77-exp(5))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)+(395/2)*(7*exp(8)-4*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500), (2, 1) = 8-(84+exp(5))*(86-2*exp(8)-8*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)-(5/2)*(4+exp(8)+8*exp(2))*(77-exp(5))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)-(79/4)*(exp(8)*exp(5)+8*exp(2)*exp(5)-16*exp(8)-128*exp(2)-400)/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500), (3, 1) = 2+(-39+4*exp(5))*(86-2*exp(8)-8*exp(2))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)+(5/2)*(16+2*exp(8)+exp(2))*(77-exp(5))/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)+(79/4)*(2*exp(8)*exp(5)+exp(2)*exp(5)-32*exp(8)-16*exp(2)-100)/(2*exp(8)*exp(5)+31*exp(2)*exp(5)-207*exp(8)-396*exp(2)-1500)})
14.35960152
-12.24471811
39.82986865
HFloat(5.911285325999999e36)
35235903.22
hey... can u help me how to solve my problem using the Implicit Crank Nicolson Finite different Method. 1_ques_crank.mw..... problem in variable name A and u .. how to solve this
for i from 0 while i <= N+1 do u[i, 0] := 1 end do:
for i while i <= N do A[i, 0] := u[i-1, 0]+u[i+1, 0] end do:
for j from 0 while j <= N do A[0, j] := u[1, j]-.1*u[0, j]; A[10, j] := u[9, j]-.1*u[10, j] end do:
c := Matrix(10, 10, {(1, 1) = 2.1, (1, 2) = -1, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (1, 8) = 0, (1, 9) = 0, (1, 10) = 0, (2, 1) = -1, (2, 2) = 4, (2, 3) = -1, (2, 4) = 0, (2, 5) = 0, (2, 6) = 0, (2, 7) = 0, (2, 8) = 0, (2, 9) = 0, (2, 10) = 0, (3, 1) = 0, (3, 2) = -1, (3, 3) = 4, (3, 4) = -1, (3, 5) = 0, (3, 6) = 0, (3, 7) = 0, (3, 8) = 0, (3, 9) = 0, (3, 10) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = -1, (4, 4) = 4, (4, 5) = -1, (4, 6) = 0, (4, 7) = 0, (4, 8) = 0, (4, 9) = 0, (4, 10) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = -1, (5, 5) = 4, (5, 6) = -1, (5, 7) = 0, (5, 8) = 0, (5, 9) = 0, (5, 10) = 0, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = 0, (6, 5) = -1, (6, 6) = 4, (6, 7) = -1, (6, 8) = 0, (6, 9) = 0, (6, 10) = 0, (7, 1) = 0, (7, 2) = 0, (7, 3) = 0, (7, 4) = 0, (7, 5) = 0, (7, 6) = -1, (7, 7) = 4, (7, 8) = -10, (7, 9) = 0, (7, 10) = 0, (8, 1) = 0, (8, 2) = 0, (8, 3) = 0, (8, 4) = 0, (8, 5) = 0, (8, 6) = 0, (8, 7) = -1, (8, 8) = 4, (8, 9) = -1, (8, 10) = 0, (9, 1) = 0, (9, 2) = 0, (9, 3) = 0, (9, 4) = 0, (9, 5) = 0, (9, 6) = 0, (9, 7) = 0, (9, 8) = -1, (9, 9) = 4, (9, 10) = -1, (10, 1) = 0, (10, 2) = 0, (10, 3) = 0, (10, 4) = 0, (10, 5) = 0, (10, 6) = 0, (10, 7) = 0, (10, 8) = 0, (10, 9) = -1, (10, 10) = 4})
C := MatrixInverse(c):
for l from 0 while l <= N+1 do Known[l] := Matrix(N+1, 1, proc (i, j) options operator, arrow; A[i-1, l] end proc) end do:
for l from 0 while l <= N+1 do Known[l+1] := evalm(abs(Typesetting:-delayDotProduct(C, Known[l]))) end do:
Download 1_ques_crank.mw
please see attachment and explain why the output of the 2nd line is not 0
`mod`(2*n+1, 2)
`mod`(2*n+1, 3)
2*n+1
`mod`(2*n, 2)
Download mod_maple_help.mw
I'm trying to plot dispersion curves in Maple but I'm having some trouble. The code is attached as a file also.
f1  is my main function and I want to plot Vx with regard to f as all the rest are known variables, but I'm not able to do so.
I hope that someone can tell me why do I have this error.
Thanks in advance!
f1 := (C33*Rp*kzp+C13*kx)*(Rm*kx+kzm)*sin(kzp*h)*cos(kzm*h)-(C33*Rm*kzm-C13*kx)*(Rp*kx+kzp)*sin(kzm*h)*cos(kzp*h)=0;
Rp := (-C11*kx^2-C55*kzp^2+omega^2*rho)/((C55+C13)*kx*kzp);
Rm := (-C11*kx^2-C55*kzm^2+omega^2*rho)/((C55+C13)*kx*kzm);
kzp := sqrt(((-M+sqrt(M^2-4*N))*(1/2))*kx^2);
kzm := sqrt(((-M-sqrt(M^2-4*N))*(1/2))*kx^2);
M := (C11*C33/rho^2-2*C55*C13/rho^2+C13^2-omega^2*(C33+C55)/(rho*kx^2))*rho^2/(C33*C55);
N := (omega^2/kx^2-C11/rho)*(omega^2/kx^2-C55/rho)*rho^2/(C33*C55);
C11 := 0.435e10;
C13 := 0.259e10;
C55 := 0.112e10;
C33 := 0.108e11;
rho := 923;
h := 0.7e-2*(1/2);
kx := omega/Vx;
omega := 2*Pi*f;
f1;
plot(f1, f = 10 .. 0.100e6);
Error, (in plot) unexpected options: [(.4633081900*(-0.1717311166e12*f^2/Vx^2-0.2210791386e11*(...
Asim_dispers.mw
Display only the +'ve xyz axis, and also display +'ve axis as a different color than the negative axis.
I am having trouble exporting a matrix.  Attached is my file.  When I export the matrix the values for tpeak are not numeric.  They are string values indicating the analytical expression that MAPLE is displaying.  I cannot seem to find the option to express the results as numeric.
Can anyone help?
untitled5.mw
i have 4 equation and 4 variables with DirectSearch package it will give me a solution but not in a good time
when i try fsolve it just give me a blank
these are my equations :
POL[0] := .42810/(.65429+c[-2])
 POL[1] := -8.4078*c[-1]-162.64*c[0]+84.228*c[1]-6/(.80888+c[-2])^2+9.7066/(.80888+c[-2])^3-3.9257/(.80888+c[-2])^4+(1/2*(.42786*c[-1]+.42786*c[0]+.42786*c[1]+.65429/(.80888+c[-2])))*(-49.180*c[-1]+31.921*c[0]-8.6921*c[1]+2/(.80888+c[-2])-3.2355/(.80888+c[-2])^2+1.3086/(.80888+c[-2])^3)
POL[2] := 53.965*c[-1]+43.012*c[0]-103.98*c[1]-6/(1.+c[-2])^2+12./(1.+c[-2])^3-6./(1.+c[-2])^4+(1/2*(.50000*c[-1]+.50000*c[0]+.50000*c[1]+1./(1.+c[-2])))*(22.229*c[-1]-37.815*c[0]+22.229*c[1]+2/(1.+c[-2])-4./(1.+c[-2])^2+2./(1.+c[-2])^3)
POL[3] := -30.115*c[-1]+43.264*c[0]+52.171*c[1]-6/(1.2363+c[-2])^2+14.836/(1.2363+c[-2])^3-9.1704/(1.2363+c[-2])^4+(1/2*(.52893*c[-1]+.52893*c[0]+.52893*c[1]+1.5284/(1.2363+c[-2])))*(-4.5997*c[-1]+16.892*c[0]-26.026*c[1]+2/(1.2363+c[-2])-4.9452/(1.2363+c[-2])^2+3.0568/(1.2363+c[-2])^3)
i even change digits to 100 but still no awenser
my fsolve syntax
K := fsolve({seq(POL[v], v = 0 .. 2*N+2)})
the awenser fsolve gave me
K:=
thats all it gave me
First 970 971 972 973 974 975 976 Last Page 972 of 2463
