I have made a program to plot y(t) vs x(t). Can you please modify to plot y vs x data from an excel file.
Given x in A column and y in B column in 5 rows.
Example data: [[1,1],[2,4],[3,9],[4,16],[5,26]]
StLine_VRK.msim
Ramakrishnan V
x dot produces x dot (t)
How do I suppress the t in the output display?  The help page shows an Unsuppress all so I thought a Typsetting:-Suppress(all) would do it, but it throws an error message.
Typesetting:-Suppress(x(t)) would do it but I'd prefer the option all.
I have a set of points. I want to make a linear spline of that points and plot the resulting function:
function:=CurveFitting[Spline](points_x,points_y,x,degree=1):
However I need the function to define constant y endpoint values where x is out of points_x range (i.e. first-derivation is zero where x is out of points_x range). Endpoint options does not work for me.
             constant1   x < xmin
function :=  ..
             constant2   otherwise
How can I define spline function like this?
Having difficulties solving pde. Below is the problem and its not plotting. Anyone with useful informations. Please
with(PDEtools, casesplit, declare);
with(DEtools, gensys);
with(Physics);
PDE := diff(theta(x, t), x, x)+beta*theta(x, t)*(diff(theta(x, t), x, x))+beta*((diff(theta(x, t), x))^2)-M^2*theta(x, t)-S[h]*(theta(x, t)^2)+M^2*G*(1+E*theta(x, t))-P[e]*(diff(theta(x, t), x)) = diff(theta(x, t), t);
/ d  / d             \\
|--- |--- theta(x, t)||
\ dx \ dx            //
                      / d  / d             \\
   + beta theta(x, t) |--- |--- theta(x, t)||
                      \ dx \ dx            //
          / d             \     2                               2
   + beta |--- theta(x, t)|  - M  theta(x, t) - S[h] theta(x, t)
          \ dx            /
      2                              / d             \    d
   + M  G (1 + E theta(x, t)) - P[e] |--- theta(x, t)| = ---
                                     \ dx            /    dt
  theta(x, t)
BC := theta(x, 0) = 0, Dt(theta(0, t)) = 0, theta(1, t) = 1;
Codes := [beta = .1, M = .1, S[h] = .1, G = .1, P[e] = .1, E = .1];
S1 := pdsolve({BC, subs(Codes, PDE)});
PDEplot(S1, [[t, theta(x, t)], [x, theta(x, t)]], t = 0 .. 1, x = 0 .. 1, iterations = 2, numchar = [10, 10], stepsize = 0.5e-1, numsteps = [-5, 5]);
   PDEplot([[t, theta(x, t)], [x, theta(x, t)]], t = 0 .. 1,
     stepsize = 0.05, numsteps = [-5, 5])
I've got Maple 2017 linked to MATLAB R2017a but I can't get MATLAB R2017a linked to Maple 2017.
I've got MATLAB R2016b linked to Maple 2017.
Any ideas? (Or do I just need to wait for an update?)
Hello guys!
Could you tell me what are the state-of-the-art algorithms to compute Hermite and Smith normal forms (well or just Hermite since the later can be computed by applying Hermite twice)? I am interested in these algorihtms which outputs also the respective unimodular matrices.
hello...i have a problem with this program.
I want to save the result(y,u(y)) in a text or another format file, but I encounter with this error message:
Error, (in fprintf) number expected for floating point formatBVP.mw
A1:= 5.5:  n:= 0.59:  A2:= 11818.:  h0:= 0.402e-3:
L:= .1:  dpx := -11823.9:  uc:= 0.44e-2:
ODE:= (A3,y)->
   (h0^(n+1)*L/sqrt(n)*(A1*exp(sqrt(n)*y/L)-A2*exp(-sqrt(n)*y/L))+dpx*y*h0^(n+1)+A3*(h0)^n)^(1/n)
proc (A3, y) options operator, arrow; (h0^(n+1)*L*(A1*exp(sqrt(n)*y/L)-A2*exp(-sqrt(n)*y/L))/sqrt(n)+dpx*y*h0^(n+1)+A3*h0^n)^(1/n) end proc
ODEINT:= proc(A3)
option remember;
local y;
   evalf(Int(ODE(A3,y), y= 0..1, epsilon= 1e-7)) - uc
ReINT:= proc(A3x, A3y)
   Digits:= 15:
   Re(ODEINT(A3x + I*A3y))
ImINT:= subs(Re= Im, eval(ReINT)):
Digits:= 7:
a3:= fsolve([ReINT, ImINT]);
[6.3610757968979, 0.]
A3:= Complex(a3[]);
6.3610757968979+0.*I
Solve as IVP:
Digits:= 15:
sol:= dsolve({diff(u(y),y) = ODE(A3,y), u(0)=0}, numeric, range=0..1,  output=listprocedure):
plots:-odeplot(
   sol, [[y, Re(u(y))], [y, Im(u(y))]], y= 0..1,
   legend= [real, imag], labels= [y, u(y)]
F53 := proc (y) options operator, arrow; U end proc; G53 := proc (y) options operator, arrow; Re(evalf[20](F53(y))) end proc; Temp3 := cat("u(y)-y.dat"); fd53 := fopen(Temp3, WRITE, TEXT); for i from 0 by 0.5e-1 to 1 do tt := i; u := eval(G53(y), y = tt); fprintf(fd53, "%10.5e %10.5e  \n", tt, u) end do; fclose(fd53)
Download BVP.mw
please help me
According to the help page:
interface(displayprecision=n)
sets the number of decimal places to be displayed to n.
But this is true only if interface(typesetting=extended).
For interface(typesetting=standard),  n represents the number of decimal places after the decimal point.
Is there any reason for this decision?
x:=123.456789012345:
interface(displayprecision=4):
interface(typesetting=standard): x;
                        123.4568
interface(typesetting=extended): x;
                        123.5
I'm trying to calculate forces between particles. I defined all my variables and the equation for force, but when I plug it all in, it gives me 0 when I know for a fact it's not 0. I should be getting something like f12=-0.4, f13=-0.24, and f23=-0.5.
failforce.mw
Basically I defined variables like x1,y1, m1 , etc. and made my force equation fij with all variables having appropriate i and j subscripts.
hello. i want to write this function with  "for"loop. but i don't know
1.mw
Used PolyhedralSets for plotting.
At the moment there are a number of questions in the construction of graphs:
How to adjust the rotation of this figure around the z axis?
How to make, what color of a figure received in a cut would be much darker or Darker color?
with(PolyhedralSets);
P1 := PolyhedralSet({-x-20 <= 0, -x-20 <= 20-y, -x-20 <= -(1/2)*y, -x-20 <= -z, -x-20 <= -(x+y)*(1/2), -x-20 <= -(y+z)*(1/2)});
Plot(P1, axe
s = normal, view = [-40 .. 40, -40 .. 40, -40 .. 40], orientation = [30, -30, -60], color = blue, thickness = 2);
Plot(P1, axes = normal, view = [-40 .. 40, -40 .. 40, -40 .. -40], orientation = [0, 0, 0], color = blue, thickness = 2)
I'm trying to obtain integral of Planck radiation law in Maple:
with this command:
f := (2*h*(c)^(2))/((x)^(5))*(1)/(exp((h*c)/(x*k*T))-1);
int(f,x=0..infinity);
but I get some terrible limit that cannot be solved instead of the correct result:
How to obtain correct integral?
planck.mw
I followed the basic example RLS circuit first. It worked out well for R = 24 ohms, L = 160 mHand C = 200 microF. Signal is step input h = 1 and  t0 =  0.1 s. Simulation td = 0.5 s
When I extended it for DC motor, the output for torque (tou) and speed (w) not plotted for h = 1  t0 =  1s and simulation td = 5 s for the same parameters as above the output required (shown in manual) is not coming. Is it because default values shown were different? Then how do i change? I am enclosing the file for view and help.
DCmotort_model1.msim
Ramakrishnan V
How to label in inline math mode. I tried labels = ['theta', Typesetting:-Typeset(cos(1/theta)/sqrt(1-theta^2))] which gives a big expression on Y axis spreaded in two lines. But i want to label one line as in latex $\cos(1/\theta)/sqrt(1-\theta^2))$ . Is there a way to do it ?
the program shows that the error please verify it sirprogram11.mw
First 997 998 999 1000 1001 1002 1003 Last Page 999 of 2463
