How to generate all basis of a set? (rather an the one basis that basis generates)
Please help in writing finite difference algorithm for a nonlinear PDE using Maple.
for a[j], b[j] known at time n, I want to compute A[j]  for a[j] at time n+1 according to the equation below
EQs:=A[j]-theta*tau*(A[j-1]-2*A[j]+A[j+1])=a[j]+sqrt(a[j])*b[j]*h^2/tau+(1-theta)*tau*(a[j-1]-2*a[j]+a[j+1]) ;
hi guys , i have this warning for solving a complicated equation with 7 parameters. how can i overcome to this warning ?
odesys := {(1/4)*(-4*r^(2+p+a)*p*a-11*r^(2+a+c)*a*c-4*r^(2+p+c)*p*c+22*r^(2+a+n)*a*n+8*r^(2+p+n)*p*n-22*r^(2+a+c)*a+8*r^(2+p+a)*p-8*r^(2+p+c)*p+22*r^(2+b)*b+32*r^(2+p)*p^2+32*r^(2+p)*p+22*r^(2+b)*b^2+22*r^(2+2*a)*a+65*r^(2+2*a)*a^2-8*r^(2+p+c)*p^2+8*r^(2+p+a)*p^2-22*r^(2+a+c)*a^2)/r^4+(1/4)*(4*r^(a+n)*n^2-2*r^(n+c)*n*c-4*r^(n+c)*n^2+3*r^(2*n)*n^2-4*r^(a+c)*c+8*r^(a+n)*n+4*r^(2*c)*c-8*r^(n+c)*n+4*r^m*m^2-4*r^d*d+8*r^m*m+4*r^m-4*r^d)/r^2}
res := op(odesys);
SOL1 := solve(identity(res = 0, r), {a, b, c, d, m, n, p})
Download sol.mw
Dear I want to define a general operator D for Fractional derivative whose behave like this
(D^alpha)(t^beta) = GAMMA(1+beta)*t^(beta-alpha)/GAMMA(1+beta-alpha)
How to generate an undirected graph with a given set of its verticies and a given list/set of the degrees of its verticies?
guys, i have this equation which a, n, c, phi[0] are parameters and r is variable. maple solved this equation with n=0,c=c,phi[0]=5/4-1/4 c but i obtained another solution for this equation : a = 1, c = 5, n = 1, phi[0] = 1 ( you can check).
odesys := {5*r^a+4*n-c*r^n-4*phi[0]}
res := op(odesys);
SOL := solve(identity(res = 0, r), [a, n, c, phi[0]]);
[[a = 0, n = 0, c = c, phi[0] = 5/4-(1/4)*c]]
eval(5*r^a+4*n-c*r^n-4*phi[0], [a = 1, c = 5, n = 1, phi[0] = 1])
how can i get all solutions for a equation like this ?
Download eq000.mw
Concerning the 3D visualization of my multibody systems, in the visualization windows, i can see both :
- the display of geomtry of the elements which has been defined as simple forms (as cylindrical geometry)
- the display of the geometry of the elements where the display of the geometry has been defined with CAD.
However, concerning the 3D animation, i have only see the components where the display of the geometry is defined as simple forms (as cylindrical geometry).
Have you some ideas why I can not see the elements which has been defined with CAD ?
For your information, the CAD geometries have been defined with STL files and, in the CAD geometry component, I let the box "Transparent" empty.
Thank you for your help
As I am beginner in maple, how to verify Bianchi Identities?
For Riemannian manifold,
1) R(X, Y)*Z+R(Y, Z)*X+R(Z, X)*Y = 0
2) ((∇)[X]R)(Y,Z)W+((∇)[Y]R)(Z,X)W+((∇)[Z]R)(X,Y)W=0
I am not getting how to define vector fields. From my previous question I understood defining vector fields particularly. From that post I tried to verify the proof, but I cant. Please tell me about how to define vector fields without taking examples.
Thank in advance.
Hi, does anyone know how to plot a Bode diagram (phase and amplitude plot)? I am not looking for preparation of data but rather for the technicality of producing a plot that looks like I want, given I have data in the right form (which in my case are three Vectors: frequency, amplitude and phase).
Below is a rough sketch of what I am looking for. Note that the amplitude is on a log scale. It would be acceptable having to take the log of the data "by hand" to allow both vertical scales to be linear (I'd just convert the amplitudes to dB). The important things are the common frequency scale (horizontal) and the separation of amplitude and phase. I know plots has  dualaxisplot, and I know I can use plots:-transform to move a curve around, but I want the two axes on the left side, below each other, rather on the left and right. I'd like the frequency scale in the middle between the two curves, although I could settle on that scale to be below both curves.
I had some look around the Maple applications but did not find anything looking like this.
Mac Dude
Can Maple look for the limit of a sequence  f(n)  for n=1,2,3, ... ? Of course, if there is a limit of the function of continuous argument, the limit of the sequence is the same number. But it is easy to give examples of when there is the limit of the sequence, and the limit of the function does not exist:
assume(n, posint):
 limit(sin((n^2+1)/n*Pi), n=infinity);  # Obviously the correct answer is  0
                            -1 .. 1
My code works in Maple (18.02), not Maple Player (2015.1). Much headache ensued.
I've isolated the problem in a toy form:
Defn := proc (scaleby)
whattype(scaleby);
end;
Explore(Defn(p), parameters = [p = [1, 10, 100]]);
In Maple will return "integer" for any value of p selected in the combobox.
In Maple Player returns "string" for any value of p selected in the combobox
Is there something I'm missing here? Is Maple Player not backwards compatible to versions of Maple prior to 2015?
My understanding is that Maple Code should export without headache to Maple Player. Is this a solid understanding?
Thanks for helping out a newbie!
hi guys ,
i have two set equations and i want to solve them. eq.mw
thanks guys
Is Maple 18 student version CUDA enabled? I am getting when I tried CUDA:-IsEnabled();
Error, `CUDA` does not evaluate to a module
I am very confused about function is():
1. is(a-b=0) assuming a::real,b::real,a^2=b^2,a>0,b>0;
2. is(a-b=0) assuming a::real,b::real,a^2=b^2,a>=0,b>=0;
the first command gives me false, and the second command gives me true...
any thoughts?
First 1260 1261 1262 1263 1264 1265 1266 Last Page 1262 of 2430
