I'm using maple to solve non linear DE system. The error below appeared. What to do?
eqd1:={diff(u(x),x)=U(x)}:
eqd2:={diff(v(x),x)=V(x)}:
eqd3:={0.004*x*diff(U(x),x)+(x-8*x*V(x)+0.006*U(x)+(3/2-12*V(x)-8*x*diff(V(x),x))*u(x)=0}:
eqd4:=(0.008*x*(V(x)^2)+2*(0.6+x)*v(x)*V(x)+v(x)*u(x)+(v(x)^2)=0}:
fonc:={U(x),u(x),V(x),v(x)}:
sol:=dsolve(eqd1,eqd2,eqd3,eqd4,fonc}:
Error, (in PDEtools/sdsolve) too many arguments; some or all of the following are wrong: [{U(x), u(x)}, {diff(v(x), x) = V(x)}, {1/250*x*(diff(U(x), x))+(x-8*x*V(x)+3/500)*U(x)+(3/2-12*V(x)-8*x*(diff(V(x), x)))*u(x) = 0}, {1/125*x*V(x)^2+2*(3/5+x)*v(x)*V(x)+v(x)*u(x)+v(x)^2 = 0}]
How can I obtain series expansion of a known mathematical function? for example I Need a command to get a formula for expansion of Bessel function as bellow
I know how interpolating curves using 1D Fourier tranform.
see http://www.mapleprimes.com/questions/121551-Fourier-Serie-And-Discrete-Fourier-Transform
How to use 2D Fourier transform to find a 2D Fourier series to interpolate surfaces as:
f := proc (x, y) options operator, arrow; sin(x)^2+cos(y)^2 end proc
plot3d(f(x, y), x = 0 .. Pi, y = 0 .. Pi)
Or surface data [x,y,f(x,y)].
I'm attempting to plot the Nyquist plot for a complex system such that Maple cannot determine the frequency limits automatically, and suggested I use 'range' to specify the frequency limits. How do you do this? For example if you have a system G=1/(s+1), how do you plot the Nyquist plot in the frequency range 0 to 1rad/s?  Thanks
I make a new parameter in MapleSim, but I don't konw why it becomes to something as shown in the above figure.
In MapleSim environment, I can see these code, but I find that I cannot edit them.
Is there a method that I can edit these codes?
Helo friends. Hope you will be fine. I need the command for take the conjugate of exp(I*x). I need the result exp(-I*x), x treated as real number.
PhD (Scholar)
Department of Mathematics
In a plot command, how do I indicate not to show the legend ?
(I know about unchecking "show legend" with a right click, and I have searched mapleprimes.)
Thanks, all !
Is it possible to have Maple display square brackets, instead of a subscript ? (Seperately, I would still like to use subscripts. So, I don't want everything in square-bracket notation.)
Input:
x[n]
Evaluates to:
x[n]
I'd like to plot a surface from three lists in the following way:
For each item in the list X we have a specific curve "plotted" in the plane Y vs Z.
In other terms, we have something like that: each X[i] will be related to two lists, say, Z[1], Z[2], Z[3] and Y[1], Y[2], Y[3], X[i+1] will be related to Z[4],Z[5],Z[6], and Y[4],Y[5],Y[6] and so on...
A very 'thin' surface following this would be, as a example:
X=[1,2]
Y=[[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29], [2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]]
Z=[[20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49], [21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50]]
I am looking for some tutorial showing something similar but without any success. Please, any kind of help certainly will be absolutely very appreciated. Thanks in advance! Best regards,
Write a Maple code that performs the Gaussian elimination for an nxn matrix, converting it to an upper triangular matrix.
(Hint: you will need to use three for .. do loops.)
How to add values in vector? This is what I am trying in my code below. I know there are more than one values satifying my conditon.
What is the best way constructing such vectors. If there are other options, please let me know. Thanks.
Write a recursive Maple procedure, called “decToBin”, that converts an integer from decimal (base 10) to binary (base 2). Ensure that only integers are allowed as arguments to the procedure. Passing a negative integer should result in no output. Test your procedure by outputting the result of the following:
decToBin(10)
decToBin(163)
decToBin(213)
decToBin(-1)
decToBin(“A”) # should result in an “invalid input” error
Hey guys!
My maple document won't open... Everytime I try to open it, it opens a blank page and I get this message "How do you want to open this text file"
Please help me.
Matematikaflevering_9_-_Cilla_1.x.mw
Hi, is there any best turorial to learn maple for Mathematics. thanks
First 1294 1295 1296 1297 1298 1299 1300 Last Page 1296 of 2429
