What Maple15 commands will display a Rouleaux tetrahedron or a Meissner tetrahedron?
I'm having a challenge solving an integration that has some error functions associated with it.
Description:
I am trying to find the Riemann midpoint of the integral. All the parameters are known except the u and du terms which came into the expression following a laplace transform.
the output I get from the above input is shown below, and as it can be seen, the u and du terms coupled with a complimentary error function still exist. I have tried the "simplify" function and it returns similar output expression.
Any help will really be appreciated.
plot(x^2, x = -2 .. 2)
Error, (in plot) incorrect first argument x^2
plot(2);
solve(x-1 = 0, x)
Error, (in coulditbe) invalid input: `coulditbe/internal` uses a 1st argument, obj, which is missing
Download Maple_Worksheet.mw
I'm using Maple 18 and none of my worksheets that I've developed on earlier versions work on it. I tried starting a new worksheet with a very simple command (attached) and even that's giving me problems. As you can see, I have no trouble plotting constant functions, but as soon as I put in a variable it breaks down. It won't solve equations either.
FYI I'm using an HP G72 laptop with Windows 7 and no installation issues came up.
Can anyone tell me what's going on here?
Tom
I'm trying to use logplot but it's very time consuming. Any suggestion please!
Cheers!
restart:with(plots):
S1:=x+x^2*Sum(t^(k*alpha+1)/GAMMA(k*alpha+2),k=0..infinity);
S2:=x+x^2*Sum(t^(k*alpha+1)/GAMMA(k*alpha+2),k=0..n);
alpha:=0.75:x:=0.5:n:=10:
logplot(abs(S1-S2),t=0..1);
So here is the issue: I have a 50 by 50 tridiagonal matrix. The entries in the first row, first column are -i*x and the last row last column is -i*x; these are along the main diagonal, where i is complex and x is a variable. Everything in between these two entries is 0. Above and below the main diagonal the entries are -1. My issue is that I have to find a conditon on x that makes the eigenvalues real. I am completely new to maple and have no programming experience.. Can someone show me how to this?
Using Maple 18, I solved for minimum and maximum price. Instead of using fsolve I wanna use procedure programming structure in order to get the same results. How can I do it?
min_sol := fsolve([bc_cond, slope_cond, x[G, 1] = w[aggr, 1]], {p = 0 .. 1, x[G, 1] = 0 .. w[aggr, 1], x[G, 2] = 0 .. w[aggr, 2]}); p_min := subs(min_sol, p); max_sol := fsolve([bc_cond, slope_cond, x[G, 2] = w[aggr, 2]], {p = 0 .. 1, x[G, 1] = 0 .. w[aggr, 1], x[G, 2] = 0 .. w[aggr, 2]}); p_max := subs(max_sol, p);
{p = 0.3857139820, x[G, 1] = 127.8000000, x[G, 2] = 38.99045418}
0.3857139820
{p = 0.8841007104, x[G, 1] = 44.30160890, x[G, 2] = 164.2000000}
0.8841007104
I am trying to realize the following calculation in Maple.
  \left[\sum_{i=0}^n y_i(x) \partial_x^i , \sum_{j=0}^m z_j(x) \partial_x^j \right]  \\
=   \sum_{i=0}^n \sum_{j=0}^m \sum_{l=0}^i  \binom il y_i(x) \left( \partial_x^{i-l} z_j(x)\right) \partial_x^{l+j} \\
- \sum_{j=0}^m \sum_{i=0}^n \sum_{l=0}^j  \binom jl z_j(x) \left( \partial_x^{j-l} z_i(x)\right) \partial_x^{l+i} \ .
Is there a way to make maple understand d/dx as a differential opperator and calculate with it? When i for example try to calculate diff(d/dx, x) it should give me d^2/dx^2 as a result. Unfortunately i don't know how to realize this.
Basic problem is i don't know how to realize operator expressions in maple like for example:
f(x) d/dx      ( f(x) is a smooth function of x here )
where when applied to a function h(x) it should result in f(x) d/dx h(x) .
Is that possible?
Thank you very much in advance.
I am trying to expand out the terms  of equation 13.  The expand command causes the lhs to be zero?
Initialize the metric and tetrad
restart; with(Physics); with(Tetrads); with(PDETools)
0, "%1 is not a command in the %2 package", Tetrads, Physics
(1.1)
X = [zetabar, zeta, v, u]
(1.2)
ds2 := Physics:-`*`(Physics:-`*`(2, dzeta), dzetabar)+Physics:-`*`(Physics:-`*`(2, du), dv)+Physics:-`*`(Physics:-`*`(2, H(zetabar, zeta, v, u)), (du+Physics:-`*`(Ybar(zetabar, zeta, v, u), dzeta)+Physics:-`*`(Y(zetabar, zeta, v, u), dzetabar)-Physics:-`*`(Physics:-`*`(Y(zetabar, zeta, v, u), Ybar(zetabar, zeta, v, u)), dv))^2)
2*dzeta*dzetabar+2*du*dv+2*H(zetabar, zeta, v, u)*(du+Ybar(zetabar, zeta, v, u)*dzeta+Y(zetabar, zeta, v, u)*dzetabar-Y(zetabar, zeta, v, u)*Ybar(zetabar, zeta, v, u)*dv)^2
(1.3)
declare(ds2)
Ybar(zetabar, zeta, v, u)*`will now be displayed as`*Ybar
(1.4)
vierbien = Matrix([[1, 0, -Ybar(zetabar, zeta, v, u), 0], [0, 1, -Y(zetabar, zeta, v, u), 0], [Physics:-`*`(H(zetabar, zeta, v, u), Y(zetabar, zeta, v, u)), Physics:-`*`(H(zetabar, zeta, v, u), Ybar(zetabar, zeta, v, u)), 1-Physics:-`*`(Physics:-`*`(H(zetabar, zeta, v, u), Y(zetabar, zeta, v, u)), Ybar(zetabar, zeta, v, u)), H(zetabar, zeta, v, u)], [Y(zetabar, zeta, v, u), Ybar(zetabar, zeta, v, u), -Physics:-`*`(Y(zetabar, zeta, v, u), Ybar(zetabar, zeta, v, u)), 1]])
vierbien = (Matrix(4, 4, {(1, 1) = 1, (1, 2) = 0, (1, 3) = -Ybar(zetabar, Zeta, v, u), (1, 4) = 0, (2, 1) = 0, (2, 2) = 1, (2, 3) = -Y(zetabar, Zeta, v, u), (2, 4) = 0, (3, 1) = H(zetabar, Zeta, v, u)*Y(zetabar, Zeta, v, u), (3, 2) = H(zetabar, Zeta, v, u)*Ybar(zetabar, Zeta, v, u), (3, 3) = 1-H(zetabar, Zeta, v, u)*Y(zetabar, Zeta, v, u)*Ybar(zetabar, Zeta, v, u), (3, 4) = H(zetabar, Zeta, v, u), (4, 1) = Y(zetabar, Zeta, v, u), (4, 2) = Ybar(zetabar, Zeta, v, u), (4, 3) = -Y(zetabar, Zeta, v, u)*Ybar(zetabar, Zeta, v, u), (4, 4) = 1}))
(1.5)
Setup(tetrad = rhs(vierbien = Matrix(%id = 18446744078213056502)), metric = ds2, mathematicalnotation = true, automaticsimplification = true, coordinatesystems = (X = [zetabar, zeta, v, u]), signature = "+++-")
[automaticsimplification = true, coordinatesystems = {X}, mathematicalnotation = true, metric = {(1, 1) = 2*H(X)*Y(X)^2, (1, 2) = 1+2*H(X)*Y(X)*Ybar(X), (1, 3) = -2*H(X)*Y(X)^2*Ybar(X), (1, 4) = 2*H(X)*Y(X), (2, 2) = 2*H(X)*Ybar(X)^2, (2, 3) = -2*H(X)*Ybar(X)^2*Y(X), (2, 4) = 2*H(X)*Ybar(X), (3, 3) = 2*H(X)*Y(X)^2*Ybar(X)^2, (3, 4) = 1-2*H(X)*Y(X)*Ybar(X), (4, 4) = 2*H(X)}, signature = `+ + + -`, tetrad = {(1, 1) = 1, (1, 3) = -Ybar(X), (2, 2) = 1, (2, 3) = -Y(X), (3, 1) = H(X)*Y(X), (3, 2) = H(X)*Ybar(X), (3, 3) = 1-H(X)*Y(X)*Ybar(X), (3, 4) = H(X), (4, 1) = Y(X), (4, 2) = Ybar(X), (4, 3) = -Y(X)*Ybar(X), (4, 4) = 1}]
(1.6)
gamma_[4, 1, 1] = 0
diff(Ybar(X), zeta)-(diff(Ybar(X), u))*Ybar(X) = 0
gamma_[4, 2, 2] = 0
diff(Y(X), zetabar)-(diff(Y(X), u))*Y(X) = 0
gamma_[1, 4, 4] = 0
(diff(Ybar(X), u))*Y(X)*Ybar(X)-Y(X)*(diff(Ybar(X), zeta))-Ybar(X)*(diff(Ybar(X), zetabar))-(diff(Ybar(X), v)) = 0
gamma_[2, 4, 4] = 0
(diff(Y(X), u))*Y(X)*Ybar(X)-Y(X)*(diff(Y(X), zeta))-(diff(Y(X), zetabar))*Ybar(X)-(diff(Y(X), v)) = 0
gamma_[3, 4, 4] = 0
0 = 0
gamma_[4, 4, 4] = 0
0 = 0
shearconditions := {diff(Y(X), zetabar)-(diff(Y(X), u))*Y(X) = 0, diff(Ybar(X), zeta)-(diff(Ybar(X), u))*Ybar(X) = 0, (diff(Y(X), u))*Y(X)*Ybar(X)-Y(X)*(diff(Y(X), zeta))-(diff(Y(X), zetabar))*Ybar(X)-(diff(Y(X), v)) = 0, (diff(Ybar(X), u))*Y(X)*Ybar(X)-Y(X)*(diff(Ybar(X), zeta))-Ybar(X)*(diff(Ybar(X), zetabar))-(diff(Ybar(X), v)) = 0}:
RicciT := proc (a, b) options operator, arrow; SumOverRepeatedIndices(Ricci[mu, nu]*e_[a, `~mu`]*e_[b, `~nu`]) end proc
proc (a, b) options operator, arrow; Physics:-SumOverRepeatedIndices(Physics:-`*`(Physics:-`*`(Physics:-Ricci[mu, nu], Physics:-Tetrads:-e_[a, `~mu`]), Physics:-Tetrads:-e_[b, `~nu`])) end proc
SlashD := proc (f, a) options operator, arrow; SumOverRepeatedIndices(D_[b](f)*e_[a, `~b`]) end proc
proc (f, a) options operator, arrow; Physics:-SumOverRepeatedIndices(Physics:-`*`(Physics:-D_[b](f), Physics:-Tetrads:-e_[a, `~b`])) end proc
SlashD(f(X), 1)
diff(f(X), zeta)-Ybar(X)*(diff(f(X), u))
SlashD(f(X), 2)
diff(f(X), zetabar)-Y(X)*(diff(f(X), u))
SlashD(f(X), 3)
(1+H(X)*Y(X)*Ybar(X))*(diff(f(X), u))-H(X)*((diff(f(X), zeta))*Y(X)+Ybar(X)*(diff(f(X), zetabar))+diff(f(X), v))
SlashD(f(X), 4)
-Y(X)*Ybar(X)*(diff(f(X), u))+Ybar(X)*(diff(f(X), zetabar))+(diff(f(X), zeta))*Y(X)+diff(f(X), v)
  simplify(RicciT(1, 2), shearconditions) = 0
H(X)*(diff(diff(Y(X), zeta), zetabar))*Ybar(X)-H(X)*Ybar(X)*Y(X)*(diff(diff(Ybar(X), u), zetabar))-H(X)*Ybar(X)^2*(diff(diff(Y(X), u), zetabar))-H(X)*Y(X)^2*(diff(diff(Ybar(X), u), zeta))-2*H(X)*Y(X)*Ybar(X)*(diff(diff(Y(X), u), zeta))+H(X)*Y(X)^2*Ybar(X)*(diff(diff(Ybar(X), u), u))-H(X)*Y(X)*(diff(diff(Ybar(X), u), v))+H(X)*Y(X)*Ybar(X)^2*(diff(diff(Y(X), u), u))-H(X)*(diff(diff(Y(X), u), v))*Ybar(X)+H(X)*(diff(Ybar(X), zetabar))^2+(-3*H(X)*Y(X)*(diff(Ybar(X), u))-(diff(H(X), u))*Y(X)*Ybar(X)+(diff(H(X), zeta))*Y(X)+(diff(H(X), zetabar))*Ybar(X)+diff(H(X), v))*(diff(Ybar(X), zetabar))+H(X)*(diff(Y(X), zeta))^2+(-4*H(X)*(diff(Y(X), u))*Ybar(X)-(diff(H(X), u))*Y(X)*Ybar(X)+(diff(H(X), zeta))*Y(X)+(diff(H(X), zetabar))*Ybar(X)+diff(H(X), v))*(diff(Y(X), zeta))+2*H(X)*Y(X)^2*(diff(Ybar(X), u))^2-Y(X)*(-(diff(H(X), u))*Y(X)*Ybar(X)+(diff(H(X), zeta))*Y(X)+(diff(H(X), zetabar))*Ybar(X)+diff(H(X), v))*(diff(Ybar(X), u))+2*(diff(Y(X), u))*Ybar(X)*(H(X)*(diff(Y(X), u))*Ybar(X)+(1/2)*(diff(H(X), u))*Y(X)*Ybar(X)-(1/2)*(diff(H(X), zeta))*Y(X)-(1/2)*(diff(H(X), zetabar))*Ybar(X)-(1/2)*(diff(H(X), v))) = 0
0 = 0
0 = 0
(14)
Why does the expand command cause the lhs to be zero?
Download Question_R12.mw
I want to know with what x,y, z,  function f is minimum, whereas function g is constant.
regards
I want to know with what x/y, z,  function f is minimum, whereas function g is constant.
regards
Hello every one,
Is any one knows how to solve the following inequality with assumptions that all parameters are real positive and k<1 and delta > c*alpha
(1/2)*((alpha*k^2-3*alpha*k-2*beta)*sqrt(delta^2*(k-1)*(k-2)*(c*alpha-delta)^2)-k*delta*(alpha*k^2-3*alpha*k+2*alpha-2*beta)*(c*alpha-delta))/(delta^2*(alpha*k^2-3*alpha*k-2*beta))<0
I tried the following code but it  dosn't make sense:
u:=(1/2)*((alpha*k^2-3*alpha*k-2*beta)*sqrt(delta^2*(k-1)*(k-2)*(c*alpha-delta)^2)-k*delta*(alpha*k^2-3*alpha*k+2*alpha-2*beta)*(c*alpha-delta))/(delta^2*(alpha*k^2-3*alpha*k-2*beta))
solve({u < 0,alpha > 0, beta > 0, c > 0, delta > 0, delta > c*alpha, k > 0, k < 1, })
In fact I want to know under which circumastances the above inequality is negative.
THX
Is there a command in maple that shows which files were read during start up? I am confused as to which maple init file is being read on my PC.  From http://www.maplesoft.com/support/help/Maple/view.aspx?path=worksheet/reference/initialization
it says
"Under Windows, the initialization file is called maple.ini.
If <Maple>\lib\maple.ini exists, it is loaded first (where <Maple> is your Maple installation directory). With a  network installation of Maple, the commands in this initialization file will be executed by all users on the network.
To execute a user's personal set of commands, only the first initialization file in one of the following paths will be loaded.
1) The binary directory of your current working directory (for example, "c:\Program_Files\Maple\bin.win\maple.ini")
2) The <Maple>\Users directory (for example, "c:\Program_Files\Maple\Users\maple.ini")
3) The user's personal profile directory (multiuser only) (for example, "c:\Documents_and_Settings\userid\maple.ini")
Maple reads and executes the network initialization file before the personal initialization file."
How do I find out, from inside Maple, which file(s) were read? Or make maple shows a trace of the loading process to see what files ini files it is reading?
Maple 18.2 on windows. btw, the above help page seems old. I am on windows 7, and I do not have "c:\Program_Files\Maple\" folder. And do not have "c:\Documents_and_Settings" folder. So the above help is not very useful. May be it was written during windows 95 times?
I have some "boolean variable" constraint equation like this:
a1*x1+a2*x2+...+an*xn>=b1*y1+b2*y2+...+bn*yn
where a1,a2,...,an and b1, b2, ..., bn are 1 or -1
These equations will be used in LPSolve or the other command to find a group of parameters which can fit them.
Now I used for-loop to deal with this kind of question, for example:
But there are more than 10 boolean variables in my case and It's very inefficient. On the other hand, using for-loop to determine the equation we solve in the command will lead to great confusion.
I think there should be some ways able to solve this kind of "boolean variables" question in Maple, such as, through assume command to define the type of "boolean variable".
But I have no idea how to do it.
I have the following construct:
for i from 1 to 10 do
cubeprod:=i^3;
if irem(cubeprod,3)=0  and if(modp(cubeprod,2)<>0 then
cubesum(cubeprod);// I need both if statements to be true in order to invoke cubesum(). I've noticed that using an and between both if statements is incorrect but :
cubeprod:=i^3;
if irem(cubeprod,3)=0 then
 if modp(cubeprod,2)<>0 then cubesum(cubeprod) fi;
gives me an error as well. What is the right syntax to achieve this?
First 1307 1308 1309 1310 1311 1312 1313 Last Page 1309 of 2429
