I have the following procedure to do the above. It works but it returns [9,10],[10,9],[12,1] for n=1729(for example). How do I modify this to
a) to count 9,10 and 10,9 as the same and hence only show one of them
b) get 1,12 to show as a solution?
cubesum:=proc(n::nonnegint)
global listcub:=table();
local k:=0, x:=iroot(iquo(n,3),3),y:=x,x3:=x^3,y3:=y^3;
if 3*x3 <> n then x=x+1; x3:=x^3;y:=x;y3:=x3 end if;
while x3<=n do
y:=iroot(n-x3,3); y3:=y^3;
if(x3+y3 = n) then k:=k+1; listcub[k]:=[x,y]end if;
x:=x+1; x3:=x^3;
convert(listcub,list);
I have my question makes any sense. I am from Denmark and not used to write math in english.
I have an characteristic matrix with an variable λ that takes on differen values.
How do I write λ in the matrix so Maple knows that when I call out a row with the variable λ in it and asssign
λ to a specific value, Maple changes λ to the specific value.
Example (I was thinking something like this):
A:=Matrix(2,2,[(1-λ_i),2,3,(4-λ_i)])
λ_1:=2
λ_2:=4
A[1],λ_1               (1-2) 2
A[1],λ_2               (1-4) 2
A[2],λ_1               3 (4-2)
A[2],λ_2               3 (4-4)
Hi, I am an student and I am currently working on a system that sketches the relation of predator and prey of yellowstone's gray wolf and elk. I tried using the Lotka-Volterra model, but I wanted to add more parameters and add a carrying capacity for the system. Unfortunatley I cannot find a way to edit the Lotka model to my needs, and because I am new i do not know how to create my own model. This is the two equations I want to use: (D(x))(t) = alpha*x(t)-ax^2/k-b*x(t)*y(t)-gx(t), (D(y))(t) = -beta*y(t)+c*x(t)*y(t)-gy(t)
were k is carrying capacity.
Basically what I am asking is that if someone can help make the system workable on Maple and some steps of how to do it.
What I tried is at
http://apfp.sourceforge.net/maple_interval_arith.pdf
I would like to be able to do comparisons of intervals.
At least take min or max - I thought I saw that on help pages but didn't get it to work.
Would also like to use with complex numbers - tried evalrC - but did not do what I expected.
Is there a way to tell Maple to export a figure to PDF with a proper bounding box, like all of its other graphics export formats?
To export a graphics produced by Maple's plot(), I right-click on the plot, select Export, and then one of the several choices of graphics formats.  All options, other than the PDF, work fine—they produce graphics files whose bounding boxes correspond to the extents of the image.  Exporting to PDF misbehaves—it produces the equivalent of a 8.5''x11'' paper and inserts the graphics somewhere near the upper left corner.  I am absolutely at a loss to see the utility of that.  What in the world is the use of such an export?
Is there a configuration setting that tells Maple to save to PDF with a proper bounding box?  I looked around but couldn't find one.
Below is my code:
> restart:
> q:=1.6*10^(-19):e0:=8.85*10^(-12):k:=1.38*10^(-23):t:=300:ni:=1.45*10^(16):eox:=3.9*e0:esi:=11.7*e0:
> tox:=2*10^(-9):tsi:=25*10^(-9):L:=1*10^(-6):cox:=(eox/tox):csi:=esi/tsi:a:=sqrt(q^2*ni/(2*k*t*esi)):V:=0:vgs:=2:u:=0.04:
> mm:=(cos((q*cox*(vgs-psi11)/(esi*k*t*a))*(exp(q*(V-psi11)/(2*k*t))))-((2*q*cox*(vgs-psi11)/(esi*k*t*a^2*(tsi)))*(exp(-q*(psi11-V)/(k*t))))):
> psi1:=solve(mm=0,psi11);
psi1 := 0.5434311697 - 0.003168514913 I
> mm:=(cos((q*cox*(vgs-psi22)/(esi*k*t*a))*(exp(q*(vds-psi22)/(2*k*t))))-((2*q*cox*(vgs-psi22)/(esi*k*t*a^2*(tsi)))*(exp(-q*(psi22-vds)/(k*t))))):
> qq2:=seq(solve(mm=0,psi22),vds=[0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1,1.1,1.2,1.3,1.4,1.5,1.6,1.7,1.8,1.9,2]):
> psi2:=(vector([qq2]));vds:=[0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1,1.1,1.2,1.3,1.4,1.5,1.6,1.7,1.8,1.9,2]:
psi2 := [0.5434311697 - 0.003168514913 I, 0.6398902333 - 0.003560933110 I,
0.7360983262 - 0.003949922699 I, 0.8586260376, 0.9544714953, 1.066786341,
1.145104060, 1.239782678, 1.333965608, 1.427671475, 1.521739902,
1.612717888 + 0.004670871971 I, 1.699606898 + 0.007295737134 I,
1.782802467 - 0.009645080463 I, 1.913366188, 1.969622161, 1.996631837,
1.999909512, 1.999998089, 1.999999960, 1.999999999]
> for i from 1 to 21 do
> Qgg[i] := Re( tsi*cox*L*(1/6*psi2[i]^3-1/2*psi2[i]^2-1/2*psi2[i]^2*vgs-1/2*psi2[i]^2*k*t/q+1/2*psi2[i]*vgs^2+psi2[i]*k*t*vgs/q+psi2[i]*vgs-8*psi2[i]*esi*k*t/(q*tsi*cox)-64*esi^2*k^2*t^2*ln(-8*esi*k*t-q*tsi*cox*vgs+q*tsi*cox*psi2[i])/(q^2*tsi^2*cox^2)-1/6*psi1^3+1/2*psi1^2+1/2*psi1^2*vgs+1/2*psi1^2*k*t/q-1/2*psi1*vgs^2-psi1*k*t*vgs/q-psi1*vgs+8*psi1*esi*k*t/(q*tsi*cox)+64*esi^2*k^2*t^2*ln(-8*esi*k*t-q*tsi*cox*vgs+q*tsi*cox*psi1)/(q^2*tsi^2*cox^2))/(k*t*(vg-psi2[i])/q+1/8*(vgs-psi2[i])^2+4*k^2*t^2*esi*ln(cox(vgs-psi2[i])+8*k*t*esi/(q*tsi))/(q^2*tsi*cox)-k*t*(vg-psi1)/q-1/8*(vgs-psi1)^2-4*k^2*t^2*esi*ln(cox(vgs-psi1)+8*k*t*esi/(q*tsi))/(q^2*tsi*cox)));
> end do:
> Qg:=simplify((Qgg));
/[ -15
Qg := TABLE\[1 = Float(infinity), 2 = -2.726896811 10 ,
-15 -15 -15
3 = -2.681258392 10 , 5 = -2.579829239 10 , 4 = -2.623431373 10 ,
-15 -15 -15
7 = -2.495397349 10 , 6 = -2.529657206 10 , 10 = -2.378078479 10 ,
-15 -15 -15
11 = -2.341729539 10 , 8 = -2.454901580 10 , 9 = -2.415751244 10 ,
-15 -15 -15
15 = -2.212746094 10 , 14 = -2.250797897 10 , 13 = -2.277803789 10 ,
-15 -15 -15
12 = -2.308132152 10 , 21 = -2.192572935 10 , 20 = -2.192572943 10 ,
-15 -15 -15
16 = -2.198907782 10 , 17 = -2.193213670 10 , 18 = -2.192589892 10 ,
-15]\
19 = -2.192573293 10 ]/
i have to plot Qg with respect to vds. the value of Qg are stored in a table which have mixed entries. also please suggest how can i set the x-axis of the plot in decimal notation?
please explain how to write a code to calculate and output the actual area using integration for y=X^3 over range (0,2) using left-hand rule and 200 subdivisions?
I currently have a function quadsum(n) that determines the [x,y] solutions of the above equation for an integer n. :
quadsum:= proc(n::nonnegint)
local
k:= 0, mylist:= table(),
x:= isqrt(iquo(n,2)), y:= x, x2:= x^2, y2:= y^2;
if 2*x2 <> n then x:= x+1; x2:= x2+2*x-1; y:= x; y2:= x2; end if;
while x2 <= n do
y:= isqrt(n-x2); y2:= y^2;
if x2+y2 = n then k:= k+1; mylist[k]:= [x,y] end if;
convert(mylist, list)
How would I alter this so that I get [x,y] for n= (5^a).(13^b).(17^c)(29^d) for non-negative integers a,b,c,d?
Hi everyone,
Consider the following worksheet (Maple 13):
Euler.mw
 (or as a Google Drive link)
https://drive.google.com/file/d/0Bzr3EyK8arkOUkZPcEE5b0NySVU/view?usp=sharing
Choose execute entire worksheet on both Maple 13 and Maple 18.
Maple 13 is blindingly fast at 40 seconds, entire wroksheet upon completion
Maple 18 crawls and hangs forever.
Can anyone recognise what the problem with Maple 18 is?
Running on a two core 1.7GHz AMD Athlon.
Many thanks
Yiannis
I can not my software,I get this error"the specified procedure could not be found"
what should I do?
Given a  vector v (parallel to the principle axis) and a center point c,
and generating vectors u(beta) orthogonal to v for 0 < beta < 2pi,
and real positive parameters a and b
I want to plot the hyperboloid  c + a*v*sec(alpha) + b*u(beta)*tan(alpha)
for -pi/2 < alpha < pi/2.
I am able to generate something of a plot, but can't control the size and appearance.
  Hi there,
  I want to use maple 13 for calculating mean value theorem for differentiable function  f:=piecewise(-2≤x≤0, -x2 ,0≤x≤2,x2
on the interval [-2,2]. But an error occured, that is,"function must be continuous".Any help will be appreciated.
REGARDS
 Yegan
please is there any one can help me to find a solution of a sytem of 3 non linear equations each with 3 variable and with more than 30 unknown coefficients
this is the system
solve({EEE_x(x, y, z) = 0, EEE_y(x, y, z) = 0, EEE_z(x, y, z) = 0}, {x, y, z})
where x,y,r are the unknowns
and the three equations are simply the partial derivative with respect to x,y and z repectively
EEE_x(x,y,z):=(&DifferentialD;)/(&DifferentialD; x) EE(x,y,z)
EEE_y(x,y,z):=(&DifferentialD;)/(&DifferentialD; y) EE(x,y,z)
EEE_z(x,y,z):=(&DifferentialD;)/(&DifferentialD;z)EE(x,y,z)
the main equation is EE where (it has 3 variables and more than 30 qunknowns coefficients
(x, y, z) ->
/ 2 2 2\
hh \ii + jj x + ll z + mm y + 100. y + nn y z + oo x + pp z /
/ 2 2 2 2 3 2
\p z y + q z y + l z x + g z x + o z y + n z x + m y x
2 2 2 3 2 2 2
+ j y x + k y x + i z y + d z y + f z x + h z y
2 2 4 3 2 3
+ e y x + u z y x + v z y x + a + b x + c x + r x + s z
2 2 4 3 4 \
+ t z + bb z + cc y + dd y + ee y + ff y + gg z + aa x/
1.  a procedure quadsumstats whose input is an integer n. This procedure should return a list of length
n whose kth  entry is the number of solutions to
x^2 + y^2 = k
for
1 <= k and k <= n
I am sort of confused as to how to construct that list of length n and how to obtain integer solutions to the equation in maple.
2.
a procedure firstCount(k) that finds the first integer
n
with
k
representations as
"x^2+y^2= n." What does it mean for an integer to have k representations?
I am trying to use maple to plot a poincare section for the following Hamiltonain:
H:=(1/8)*(p1^2+16*p2^2-4*p1*p2*cos(q1-q2))/(3+sin(q1-q2)^2) - cos(q2)-8cos(q1)
I've been using Maples built in command as follows:
poincare(H, t=-5000..5000, ics, stepsize = 0.1, iterations = 1, scene = [q2,p2]);
for a given set of initial conditions ics. My problem is however I need to restrict the plotting value to p1>0, as otherwise i seem to get two overlapping maps as seen below:
How exactly can i do this?
Connor
First 1308 1309 1310 1311 1312 1313 1314 Last Page 1310 of 2429
