My assignment is to plot 3 graphs when u0=65.70 and 95 and I thought I did my code properly but now I am getting weird errors
a0:=80;
a1:=-5;
b1:=-5*(3)^0.5;
w:=Pi/12;
k:=0.2;
u0:=65;
t=0:0.001:100;
c0=u0-a0-(k^2*a1-k*w*b1)/(k^2+w^2);
c1=(k^2*a1-k*w*b1)/(k^2+w^2);
d1=(k*w*a1+k^2*b1)/(k^2+w^2);
u=a0+c0*exp(-k*t)+c1*cos(w*t)+d1*sin(w*t);
plot(t,u,'r');
I am getting an error here that says Error, (in plot) unexpected options: [65., r] and I don't know how to fix this
legend('u(0)=65');
hold on;
u0=70;
plot(t,u,'-');
I am also getting an error with the '-' portion of my plot "Error, invalid uneval"
legend('u(0)=70');
hold on;
u0=95;
plot(t,u,'g');
I am getting an error yet again with my plot and this time it is "Warning, expecting only range variable u in expression t to be plotted but found name t"
legend('u(0)=90');
I am new to maple, having recently made the switch from mathCAD, and I am having problems getting the basics to do what I think they ought to be doing.
I am trying to get maple to go step by step through a derivation of a formula. In one line I define a variable
U4 := expression
In the next line I will call the same variable and take the derivative of it. Sometimes it works and sometimes it evaluates to zero when it should not. I can't seem to pin down a pattern of when it does and does not work. I will change something that is not working, and then change it back, and it will work. Am i assigning my variables inconsistently?
I took a screencapture of the worksheet in question. Thanks in advance for the help.
Screen shot
****** My question *****
for k from 0 to n do    # n is any integer.
func := f(x):             # func is any funciton of x.
D := diff(func, x$k);   # The maple don't allow to uses k but I want to diff k-th order in each k-loop.
end do;                    # How to diff func for k-th times in each k-loop.
Hello guys,
I am stuck with the following code. I cannot get a solution. Mapple doesn't even run. Please help, I am in urgent need on help!!!
Compared to Maple on Windows, how do ppl like Maple on Macs ?
Any comments ??
Thanks, cheers !
I'm trying to solve a system of four pdes and I know that the Newton method won't converge.
Are there other numerical methods that I can use?
Any help would be greatly appreciated!
Eve
I'm an industrial engineering student who's running into problems with solving a simple system of non-linear equations.
Why do I get this error when issuing the solve command? I'm pretty sure I'm only passing two lists into the function?
Thanks a lot in advance,
Joshua
Is there any way to remove the empty space that comes under images when printing the project, while using document mode?
Nicolai
Please fix the MapleCloud service. Is no longer working. E uploaded jobs and are not shown. Fix it please.
I have a matrix A for which the basis of the left null space using NullSpace() is the empty set {}  while the column space is {e1,e2,e3}. By definition, we need every vector in col space . every vector in basis of left null space =0 but how would I show that in this case? Can I determine another basis for the left null space?
Hi everyone! I need to weight a serie of values which x1 range go from 280 to 4000 by the factors provided by another serie of values, which x2 values go from 206.6 to 12400. In the graphs, the red curve is a listplot of the serie which y1 values I want to weight by the y2 values of the listplot of the serie in black. I want the resulting serie in the x1 range, but with the y3 values equal to y2*y1. How can I do that since the series have different intervals?
Serie in red=S and serie in black=t
S:=
...[417., .96392], [418., .92392], [419., .96354], [420., .88467], [421., 1.0067], [422., .99499], [423., .96531], [424., .96182], [425., .99312], [426., .96667], [427., .9355], [428., .94625], [429., .87766], [430., .70134], [431., .63779], [432., 1.0628], [433., .9905], [434., .91653], [435., 1.007], [436., 1.1061], [437., 1.1306], [438., .99368], [439., .95753], [440., 1.0993], [441., 1.0859], [442., 1.164], [443., 1.1823], [444., 1.1537], [445., 1.1992], [446., 1.0766], [447., 1.2257], [448., 1.2422], [449., 1.2409], [450., 1.2881], [451., 1.3376], [452., 1.2822], [453., 1.1854], [454., 1.273], [455., 1.2655], [456., 1.3088], [457., 1.3213], [458., 1.2946], [459., 1.2859], [460., 1.2791], [461., 1.3255], [462., 1.3392], [463., 1.3452], [464., 1.3055], [465., 1.2905], [466., 1.319], [467., 1.2616], [468., 1.3178], [469., 1.3247], [470., 1.2749], [471., 1.2975], [472., 1.3661], [473., 1.3144], [474., 1.3304], [475., 1.3755], [476., 1.3299], [477., 1.3392], [478., 1.3839], [479., 1.3586], [480., 1.3825], [481., 1.3836], [482., 1.3899], [483., 1.3742], [484., 1.3492], [485., 1.3457], [486., 1.0918], [487., 1.2235], [488., 1.3252], [489., 1.2492], [490., 1.3968], [491., 1.3435], [492., 1.2818], [493., 1.3719], [494., 1.3402], [495., 1.4238], [496., 1.3548], [497., 1.3788], [498., 1.3421], [499., 1.3429], [500., 1.3391], [501., 1.299], [502., 1.2991], [503., 1.3597], [504., 1.2682], [505., 1.3598], [506., 1.4153], [507., 1.3548], [508., 1.321], [509., 1.385], [510., 1.3497], [511., 1.3753], [512., 1.4125], [513., 1.3277], [514., 1.3003], [515., 1.3385], [516., 1.3514], [517., 1.1017], [518., 1.2605], [519., 1.2222], [520., 1.3349], [521., 1.3452], [522., 1.376], [523., 1.2976], [524., 1.3962], [525., 1.3859], [526., 1.3479], [527., 1.1795], [528., 1.3508], [529., 1.4142], [530., 1.3598], [531., 1.4348], [532., 1.4094], [533., 1.259], [534., 1.3491], [535., 1.3701], [536., 1.4292], [537., 1.3229], [538., 1.3896], [539., 1.3558], [540., 1.3096], [541., 1.2595], [542., 1.3714], [543., 1.3493], [544., 1.3971], [545., 1.3657], [546., 1.3536], [547., 1.3717], [548., 1.3331], [549., 1.3752], [550., 1.3648], [551., 1.3639], [552., 1.3923], [553., 1.3533], [554., 1.3802], [555., 1.3883], [556., 1.3651], [557., 1.3321], [558., 1.3613], [559., 1.2885], [560., 1.3118], [561., 1.3885], [562., 1.3225], [563., 1.3731], [564., 1.3466], [565., 1.3555], [566., 1.2823], [567., 1.3673], [568., 1.3554], [569., 1.3228], [570., 1.324], [571., 1.281], [572., 1.3534], [573., 1.3595], [574., 1.3527], [575., 1.3225], [576., 1.3118]...
t:=
[[206.6000, 0.9110470095e-3], [210.1000, 0.8504840202e-3], [213.8000, 0.8153191021e-3], [217.5000, 0.7517070516e-3], [221.4000, 0.7035057451e-3], [225.4000, 0.6694785180e-3], [229.6000, 0.6318423899e-3], [233.9000, 0.5994622965e-3], [238.4000, 0.5764355678e-3], [243.1000, 0.5331430203e-3], [248.0000, 0.4950946716e-3], [253.0000, 0.4422658739e-3], [258.3000, 0.4023846661e-3], [263.8000, 0.3732428357e-3], [269.5000, 0.3444825682e-3], [275.5000, 0.3307336604e-3], [281.8000, 0.3570645679e-3], [288.3000, 0.4052774535e-3], [295.2000, 0.4741877081e-3], [302.4000, 0.5345931300e-3], [310.0000, 0.6002211844e-3], [317.9000, 0.7217256785e-3], [326.3000, 0.9176207886e-3], [335.1000, 0.1271492339e-2], [344.4000, 0.1679935813e-2], [354.2000, 0.1976514731e-2], [364.7000, 0.2169413297e-2], [375.7000, 0.2420056977e-2], [387.5000, 0.2698356864e-2], [399.9000, 0.3092320191e-2], [413.3000, 0.3891714441e-2], [427.5000, 0.4875961623e-2], [442.8000, 0.6098167657e-2], [459.2000, 0.8645631738e-2], [476.9000, 0.1639763449e-1], [495.9000, 0.1611551307e-1], [516.6000, 0.1102654621e-1], [539.1000, 0.5287562153e-2], [563.6000, 0.3253578980e-2], [590.4000, 0.2176718340e-2], [619.9000, 0.1510939515e-2], [652.5000, 0.1117755662e-2], [688.8000, 0.8568924681e-3], [729.3000, 0.6693019750e-3], [774.9000, 0.5484788449e-3], [826.6000, 0.4632457834e-3], [885.6000, 0.3982461677e-3], [953.7000, 0.3505755460e-3], [1033.000, 0.3130972421e-3], [1127.000, 0.2814970511e-3], [1240.000, 0.2609345123e-3], [1305.000, 0.2500612658e-3], [1378.000, 0.2397447628e-3], [1459.000, 0.2312899569e-3], [1550.000, 0.2268792462e-3], [1653.000, 0.2197119097e-3], [1771.000, 0.2106962051e-3], [1907.000, 0.2046935228e-3], [2066.000, 0.2003490235e-3], [2254.000, 0.1974613611e-3], [2480.000, 0.1948841680e-3], [2755.000, 0.1957355188e-3], [3100.000, 0.1937027704e-3], [3542.000, 0.1867538618e-3], [4133.000, 0.1849393481e-3], [4959.000, 0.1835339010e-3], [6199.000, 0.1838769393e-3], [8266.000, 0.1869179329e-3], [12400.00, 0.1990760933e-3]]
Can anyone coax Maple to solve this reccurence relation? It seems harmless enough but Maple is struggng a bit with "hypergeomsols."
f := c -> (2*n-c)*f(c-1) - (c-1)*n*f(c-2);
f(0) := 1;
f(1) := 2*n-1;
Determine using determinants the range of values of a (if any) such that
f(x,y,z)=4x^2+y^2+2z^2+2axy-4xz+2yz
has a minimum at (0,0,0).
From the theory, I understand that if the matrix corresponding to the coefficients of the function is positive definite, the function has a local min at the point. But, how do I get the range of values of a such that f is a min? Is this equivalent to finding a such that det(A) > 0?
2.
Now modify the function to also involve a parameter b: g(x,y,z)=bx^2+2axy+by^2+4xz-2a^2yz+2bz^2. We determine conditions on a and b such that g has a minimum at (0,0,0).
By plotting each determinant (using implicitplot perhaps, we can identify the region in the (a,b) plane where g has a local minimum.
Which region corresponds to a local minimum?
Now determine region(s) in the (a,b) plane where g has a local maximum.
I don't understand this part at all..
I've got the following matrix :
A:=[<a,a-1,-b>|<a-1,a,-b>,<b,b,2a-1>] where <> are the column elements of A, a is  a real number defined on [0,1] and b^2=2a(1-a)
a) to show A is an orthogonal matrix, I understand that I need A.Transpose(A)=Identity(3*3) but is there a way in which I can let a take a random real numbered value between 0 and 1? The rand() only returns an integer within a range. Directly multiplying A and Transpose(A) will return an expression in a, so what's the right approach?
b) from a) we can infer that A is a matrix that describes a rotation in e1,e2,e3 where these are the standard bases vectors in R3. How can I determine the rotation axis? The hint I've been given says I need to consider the Eigenvalues and eigen vectors but I don't quite understand how.
I have the function:   f(x,y) = 1/(sqrt(2*Pi)) * e-1/2(x^2+y^2)
I need to take the total derivative of this function in maple, but I don't know the syntax.
First 1310 1311 1312 1313 1314 1315 1316 Last Page 1312 of 2429
