test.mw
Hello. As you can see the minimum of set X is 2.
the time pair in set W whose difference is 2 corresponds to elements 54 and 55. How do i locate and print these automatically?
Digits:=4:
U := [1.010, 1.110, 1.210, 1.310, 1.410, 1.510, 1.610, 1.710, 1.810, 1.910, 2.020, 2.120, 2.220, 2.320, 2.420, 2.520, 2.620, 2.720, 2.820, 2.920, 3.030, 3.130, 3.230, 3.330, 3.430, 3.530, 3.630, 3.730, 3.830, 3.930, 4.040, 4.140, 4.240, 4.340, 4.440, 4.540, 4.640, 4.740, 4.840, 4.940, 5.050, 5.150, 5.250, 5.350, 5.450, 5.550, 5.650, 5.750, 5.850, 5.950, 6.060, 6.160, 6.260, 6.360, 6.460, 6.560, 6.660, 6.760, 6.860, 6.960, 7.070, 7.170, 7.270, 7.370, 7.470, 7.570, 7.670, 7.770, 7.870, 7.970, 8.080, 8.180, 8.280, 8.380, 8.480, 8.580, 8.680, 8.780, 8.880, 8.980, 9.090, 9.190, 9.290, 9.390, 9.490, 9.590, 9.690, 9.790, 9.890, 9.990, 10.01, 11.11, 12.21]:
W := select(proc (t) options operator, arrow; .59 >= frac(t) end proc, U);
[1.010, 1.110, 1.210, 1.310, 1.410, 1.510, 2.020, 2.120, 2.220, 2.320, 2.420, 2.520, 3.030, 3.130, 3.230, 3.330, 3.430, 3.530, 4.040, 4.140, 4.240, 4.340, 4.440, 4.540, 5.050, 5.150, 5.250, 5.350, 5.450, 5.550, 6.060, 6.160, 6.260, 6.360, 6.460, 6.560, 7.070, 7.170, 7.270, 7.370, 7.470, 7.570, 8.080, 8.180, 8.280, 8.380, 8.480, 8.580, 9.090, 9.190, 9.290, 9.390, 9.490, 9.590, 10.01, 11.11, 12.21]
X:=[seq(trunc(W[i+1])*60+frac(W[i+1])*100-(trunc(W[i])*60+frac(W[i])*100),i=1..nops(W)-1)];
[10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 11.00, 10.00, 10.00, 10.00, 10.00, 10.00, 2.00, 70.00, 70.00]
min(X),{W[54],W[55]};
2.00, {9.590, 10.01}
Download test.mw
Good afternoon sir.
I request your kind suggestion to my cited query.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
Need to evaluate above summation in maple. For simplicity infinity can be replaced by some constant say 1000.
The value of parameters used are:
alpha=73.11
beta=76.11
E=4.75
help....
I have been trying to solve 2D Diffusion Equation with zero Neumann BC over the unit disk. If I use Gaussian type function with a sharp peak as initial condition, I get huge errors between initial values. Let's say u(r,phi,t) is the solution of the PDE and f(r,phi) is initial value function. The expectation is for the point (r*,phi*) ,  u(r*,phi*,0)=f(r*,phi*), but it is not.
Is Numerical integration in Maple not able to handle such sharp peak? I tried some of the built-in methods such as MonteCarlo,CubaVegas but no difference.
It might be a good idea to specify some nodes arround the peak. There is a command called "peaks", but I could not use it, error message says "invalid arguments".
Soln_2D_Gaussian.mw
I am a research student and I am writing up my thesis. I was reading one of the paper written earlier by authors in 2003.
The authors calculated a symbolic rank of a matrix A, and got 9, using Maple 6.
Then new methods developed in 2012 and proved that the "true" rank should be 8. The later paper that "Most  recent versions of Maple have this simplification built in and are able to return a rank of 8.".
I just noticed that in Maple 18.01, this matrix was still evaluted for a symbolic rank 9, if no simplifcaiton was done before using Rank(), see attached.
I didnt explore a lot, but just as a notice. I am a bit concerned as most of my research was trying to deal with exponentials.
Is that something to be fixed in future versions?
 Bug.mw
Maple does not cancel out a variable.
Why is that?
Is there a way to solve this?
(I pasted my code on the bottom of this message)
Thanks for your help/advice,
Stephan
M(x):=piecewise(x<=l,1/2*(q*x^2)/(EI)-3/8*(q*l*x)/(EI),l<x,1/2*(q*x^2)/(EI)-13/8*(q*l*x)/(EI)+5/4*(q*l^2)/(EI)):
M(x):=M(x)*(-EI);
# simplify() does not work.....?
M(x):=simplify(%) assuming EI>0;
# Wiht EI cancelled out by hand it schould look like:
M(x):=piecewise(x<=l,1/2*(q*x^2)-3/8*(q*l*x),l<x,1/2*(q*x^2)-13/8*(q*l*x)+5/4*(q*l^2));
EDIT 2: Ok, here is what I am trying to do with Maple.
I have the following expression:
with
 (j times)
Now the above expression should be zero. I get a set of equations in orders of lambda. The H matrices are known. I only need to find the S matrices.
Anyways, the HOffDiag is the sum above and the GetAdvCommutator0 is this nested commutator. And I need this sum evaluated up to order n (n is a given input-number) in lambda. The rest is really not that performance hungry.
EDIT: Ok, it realy seems that this sum of commutators is something that takes Maple forever. I have written a new MWE. Is it possible to speed things up? Maybe using assumptions or so?
restart;with(Physics):with(LinearAlgebra): Setup(mathematicalnotation=true):Setup(noncommutativeprefix={M,H,S});
[noncommutativeprefix = {H, M, S}]
GetAdvCommutator0:=proc(power::integer,order::integer,M)
    if power <= 0 then return M fi:
    if power = 1 then
        return mtaylor(Commutator(M,add(lambda^l*S[l],l=1..order)),lambda, order+1) fi:
    return mtaylor(Commutator(GetAdvCommutator0(power-1,order,M),add(lambda^l*S[l],l=1..order)),lambda,order+1):
HOffDiag:=n->eval(add(1/((2*j+1)!)*'GetAdvCommutator0'(2*j+1,n,H[0]),j=0..iquo(n-1,2)+1)+add(1/((2*j+1)!)*'GetAdvCommutator0'(2*j+1,n,lambda*H[1]),j=0..iquo(n-2,2)+1)+add(1/((2*j)!)*'GetAdvCommutator0'(2*j,n,lambda*H[2]),j=0..iquo(n-1,2)+1)):
HOffDiag(3); # still fast
lambda^3*Physics:-Commutator(H[0], S[3])+lambda^2*Physics:-Commutator(H[0], S[2])+lambda*Physics:-Commutator(H[0], S[1])+(1/6)*lambda^3*Physics:-Commutator(Physics:-Commutator(Physics:-Commutator(H[0], S[1]), S[1]), S[1])+lambda^2*Physics:-Commutator(H[1], S[1])+lambda^3*Physics:-Commutator(H[1], S[2])+lambda*H[2]+(1/2)*lambda^3*Physics:-Commutator(Physics:-Commutator(H[2], S[1]), S[1])
HOffDiag(6); # takes a very long time, I didn't even try entering higher numbers
SumOfCommutators.mw
I know this question is really unspecific. However, since I am still new to Maple, and since you don't program with Maple as you would do with c++, I would appreciate some advise. I have written a program in Maple and I don't know if it works correctly. All I know is, it is pretty slow :(.
So if anyone of you could just have a short look at my attached worksheet and could tell me, if I at some point used an obvious "don't", I would greatly appreciate it.
Cheers
NOh
A Maple worksheet
Setup Maple
restart;with(Physics):with(LinearAlgebra):Setup(mathematicalnotation=true):Setup(noncommutativeprefix={MA,MB,H,S});
[noncommutativeprefix = {H, MA, MB, S}]
(1.1)
Input parameter
H0:=Matrix([[ 0 , 0 , 0 , 0 ],
            [ 0 , 0 , 0 , 0 ],
            [ 0 , 0 , U , 0 ],
            [ 0 , 0 , 0 , U ]]);
H0 := Matrix(4, 4, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = U, (3, 4) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = U})
(2.1)
H1:=Matrix([[ 0 , 0 , 0 , 0 ],
            [ 0 , 0 , 0 , 0 ],
            [ 0 , 0 , 0 , 0 ],
            [ 0 , 0 , 0 , 0 ]]);
H1 := Matrix(4, 4, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0})
(2.2)
H2:=Matrix([[  0 , 0 , -t , -t ],
            [  0 , 0 ,  t ,  t ],
            [ -t , t ,  0 ,  0 ],
            [ -t , t ,  0 ,  0 ]]);
H2 := Matrix(4, 4, {(1, 1) = 0, (1, 2) = 0, (1, 3) = -t, (1, 4) = -t, (2, 1) = 0, (2, 2) = 0, (2, 3) = t, (2, 4) = t, (3, 1) = -t, (3, 2) = t, (3, 3) = 0, (3, 4) = 0, (4, 1) = -t, (4, 2) = t, (4, 3) = 0, (4, 4) = 0})
(2.3)
orderNumber:= 4 ;
4
(2.4)
Define all necessary functions
GetAdvCommutator0:=proc(power::integer,order::integer)
    local Comm:
    if power <= 0 then return H[0] fi:
    if power = 1 then return add(coeff(Commutator(H[0],add(lambda^l*S[l],l=1..order)),lambda,n)*lambda^n,n=0..order) fi:
    return add(coeff(Commutator(GetAdvCommutator0(power-1,order),add(lambda^l*S[l],l=1..order)),lambda,n)*lambda^n,n=0..order):
GetAdvCommutator1:=proc(power::integer,order::integer)
    local Comm:
    if power <= 0 then return lambda*H[1] fi:
    if power = 1 then return add(coeff(Commutator(lambda*H[1],add(lambda^l*S[l],l=1..order)),lambda,n)*lambda^n,n=0..order) fi:
    return add(coeff(Commutator(GetAdvCommutator1(power-1,order),add(lambda^l*S[l],l=1..order)),lambda,n)*lambda^n,n=0..order):
GetAdvCommutator2:=proc(power::integer,order::integer)
    local Comm:
    if power <= 0 then return lambda*H[2] fi:
    if power = 1 then return add(coeff(Commutator(lambda*H[2],add(lambda^l*S[l],l=1..order)),lambda,n)*lambda^n,n=0..order) fi:
    return add(coeff(Commutator(GetAdvCommutator2(power-1,order),add(lambda^l*S[l],l=1..order)),lambda,n)*lambda^n,n=0..order):
HOffDiag:=n->eval(add(1/((2*j+1)!)*'GetAdvCommutator0'(2*j+1,n),j=0..iquo(n-1,2)+1)+add(1/((2*j+1)!)*'GetAdvCommutator1'(2*j+1,n),j=0..iquo(n-2,2)+1)+add(1/((2*j)!)*'GetAdvCommutator2'(2*j,n),j=0..iquo(n-1,2)+1)):
HOnDiag:=n->eval(add(1/((2*j)!)*'GetAdvCommutator0'(2*j,n),j=0..iquo(n,2)+1)+add(1/((2*j)!)*'GetAdvCommutator1'(2*j,n),j=0..iquo(n-1,2)+1)+add(1/((2*j+1)!)*'GetAdvCommutator2'(2*j+1,n),j=0..iquo(n-2,2)+1)):
computeHBlockDiag:=proc( n::posint,firstBlockWidth::posint, H0::Matrix, H1::Matrix, H2::Matrix )
    local expr, Orders, i, eq, j, eq2, orders,smatrices,rows::posint,evallist,m,l,cols,Hdiag,ff;
    expr:=HOffDiag(n);       # !!!!! this one is one of the slowest parts I think
    Orders:=[$1..n];
    for i from 1 to n do
        eq:=add(coeff(expr,lambda,l)*lambda^l,l=0..i)=0;
        for j from 1 to i-1 do
            eq:=eval(eq,Commutator(H[0],S[j])=Orders[j]);
        od;
        eq:=subs(Commutator(H[0],S[i])=MX,eq);
        eq2:=solve(eq,MX);
        Orders[i]:=eq2;
    od;
    rows,cols:=Dimension(H0);
    smatrices:=[seq(H0,i=1..n)];
        evallist:=[`*`=`.`,H[1]=H1,H[2]=H2];
            evallist:=[op(evallist),S[j]=smatrices[j]];
        od;
        smatrices[i]:=eval(Orders[i],evallist);
        for m from 1 to firstBlockWidth do
            for l from firstBlockWidth+1 to rows do
                smatrices[i][m,l]:=smatrices[i][m,l]*1/(H0[m][m]-H0[l][l]);
                smatrices[i][l,m]:=smatrices[i][l,m]*1/(H0[m][m]-H0[l][l]);
            od;
        od;
    od;
    expr:=HOnDiag(n);            # !!!!! and this one of course (almost identical to the one above)
    Hdiag:=eval(add(coeff(expr,lambda,l)*lambda^l,l=0..n),lambda=1);
    evallist:= [op(evallist), H[0]=H0,S[n]=smatrices[n]];
    Hdiag:=eval(Hdiag,evallist);
    return Hdiag;
computeHBlockDiag(2,2,H0,H1,H2);
Matrix(4, 4, {(1, 1) = -2*t^2/U, (1, 2) = 2*t^2/U, (1, 3) = 0, (1, 4) = 0, (2, 1) = 2*t^2/U, (2, 2) = -2*t^2/U, (2, 3) = 0, (2, 4) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = U+2*t^2/U, (3, 4) = 2*t^2/U, (4, 1) = 0, (4, 2) = 0, (4, 3) = 2*t^2/U, (4, 4) = U+2*t^2/U})
Eigenvalues(%);
Vector(4, {(1) = 0, (2) = U, (3) = -4*t^2/U, (4) = (U^2+4*t^2)/U})
Testing
#Fast
(4.1)
#Not so fast
computeHBlockDiag(4,2,H0,H1,H2);
Matrix(4, 4, {(1, 1) = -2*t^2/U-(8/3)*t^4/U^3, (1, 2) = 2*t^2/U+(8/3)*t^4/U^3, (1, 3) = 0, (1, 4) = 0, (2, 1) = 2*t^2/U+(8/3)*t^4/U^3, (2, 2) = -2*t^2/U-(8/3)*t^4/U^3, (2, 3) = 0, (2, 4) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = U+2*t^2/U+(8/3)*t^4/U^3, (3, 4) = 2*t^2/U+(8/3)*t^4/U^3, (4, 1) = 0, (4, 2) = 0, (4, 3) = 2*t^2/U+(8/3)*t^4/U^3, (4, 4) = U+2*t^2/U+(8/3)*t^4/U^3})
(4.2)
#Already pretty slow :(
computeHBlockDiag(6,2,H0,H1,H2);
Download MapleWorksheet.mw
How can error of invalid range be corrected FDM.mw
I am running a Maple procedure in CLI Maple (mainly because it just provides colored random numbers for other work). When the procedure runs I am getting this kind of output scrolling by:
memory used=10732.9MB, alloc=344.0MB, time=895.85
memory used=10809.2MB, alloc=345.6MB, time=904.26
memory used=10885.5MB, alloc=347.3MB, time=912.67
memory used=10961.8MB, alloc=348.9MB, time=921.27
So I am wondering what "memory used" and "memory allocated" mean here. In "Activity Monitor" (this is Mac OS X) I see that the "memory allocated" values correspond rather closely to the "real memory" usage. No idea what the "memory used" column is. Note that this is a 32 bit process running on a PPS Mac, and it merrily "uses" unlimited amounts of memory that don't exist on the machine and that a 32 bit process should not be able to use (I think Mac OS X limits 32 bit processes to 4 GB). It is clearly not paging as the machine stays perfectly useable.
So, what am I to make of these numbers?
Mac Dude.
I was just wondering if there is such thing as a technique for solving integrals using a PFD(partial fraction decomposition) if the denominator's rational roots are complex numbers???
Hi there,
I am trying to display multiple pointplots in the same plot. I would like to either distinguish the plots by their color or by the symbol (square, traiangle, circle) at each data-point. May be both, although I ignore whether using symbols at data-points is possible in Maple.
The plot i would like to achieve is this:
Maple says that my points are not in the correct format: MapleSimulation_test6.mw
My data array N has two parameters, and the free variable. The two parameters are also varied over a certain range. For plotting purposes, I would like to have one of the variables fixed, select three parameters for the other variable, and plot all data-points for them.
The resulting data array N seems to be OK, but I am aware that my attempt for plotting multiple arrays may be wrong. May be pointplot is not even the best choice.
Any ideas?
Thank you,
jon
A concho-spiral is a curve C that has a parametrization :
x=a(e)^mu(t)*cos(t)
y=a(e)^mu(t)*sin(t)
z=b(e)^mu(t)
t>=0
where a, b, mu, are constants.
  1. Show that C lies on the cone a^2*z^2=b^2*(x^2+y^2).
  2. Sketch C for a = b = 4 and mu=-1.
  3. Find the length of C corresponding to the t-interval [0,infinity].
How to include a derivative boundry condition in pde?
diff(u(1,t),x)=0. I got 0=0
Any advice?
Please find my Maple-worksheet attached below.
How do I solve this problem? I can not drawn it.
I would really appriciate if somebody could help me.
  Given this equation:       (chi^2*(xi^2-1)^2+1-Omega^2)*(xi^2-Omega^2)-xi^2 = 0
   chi^2=1/1200;  I want to plot xi vs Omega. Can anyone help me out?
First 1361 1362 1363 1364 1365 1366 1367 Last Page 1363 of 2429
