I need to build a multibody model in MapleSim 6.4 in which with few global parameters I can describe all the other parameters. In other words the final user will enter this few parameters, that are coordinates of specific points, and then the model will calculate all the relative distances on the base of those coordinates.
The problem is that if I apply trigonometric function and square root (like in the screenshot) the model is not calculating any value. Is it possible to make those calculculations?
this is the model (don't worry about the nonsense plots, it's because it's not ultimated):
DWS.msim
a+c^2
5*a+b^5
2*a+b^2*c+3*c
assume system of polynomials are above, how to test whether inverse exist
and find inverse of them
Hi all
I want to produce following c_nm's(which are differentiation based formula) . assume that N and M are known and f(t) is arbitrary. also n=1,2,...,N and m=0,1,..,M-1
how can we do this?
regards
Mahmood   Dadkhah
Ph.D Candidate
This Maple 13 so maybe things have been fixed. Here are four points whose convex hull consists of three points. Sometimes the result comes out correct, more often it does not. With numbers this small it shouldn't be an issue of roundoff. But changing digits changes the result!
Hi all
kx,ky is the wavenumber, how can I get the 4 cases of piecewise function according to kx=0,kx≠0 and ky=0,ky≠0. Thanks
J := `assuming`([4*(int(int(JJ*exp(-I*(kx*x+ky*y))*sin(2*l*pi*x/a)*sin(2*k*pi*y/b), x = 0 .. a, AllSolutions), y = 0 .. b, AllSolutions))/(a*b)], [k::posint, l::posint, a > 0, b > 0, JJ > 0])
Let a planar polygon P without selfintersections be given through the plottools:-polygon command.
How to find its triangulation as a set of triangles (The indication of common sides is desired too.) in an optimal way with Maple? This is used in the finite element method.
Triangulation
So this is the errorcode I get and my code is
> r := (x1, y1, x2, y2) options operator, arrow; (sqrt((x2-x1)^2+(y2-y1)^2))^2
> hreg := (A, C, x) options operator, arrow; A*x+C
> hpconf := (Q, x1, y1, x2, y2) options operator, arrow; Q*(1/4)*ln(2.25*b*K*t/(S*r(x1, y1, x2, y2)))/(3.14*K*b)
> he1 := (x, y, C) options operator, arrow; hreg(A1, C, x)+hpconf(Q1, x, y, xp1, yp1)+hpconf(Q2, x, y, xp2, yp2)+hpconf(Q3, x, y, xp3, yp3)+hpconf(Q4, x, y, xp4, yp4)
> C1 := solve(he1(-75, 0, C) = 20, C);
> plot3d(he1(x, y, C1), x = -75 .. 75, y = -75 .. 75, style = surfacecontour, axes = box);
I have defined all the constants, and squareboxes shouldn't be needed for the plot, right?
properties of operations on sets?
Example:
is((A minus B) intersect (A minus C) = A minus (B union C)) assuming A::set, B::set, C::set;
        FAIL
I currently have:
plot3d(78.9*x+49.1*y+15.7*(1-x-y), x = 0 .. 1, y = 0 .. 1)
I have ratios x, y and z and the ratio of z is implicit from the ratios of x and y (z=1-x-y), therefore whenever x+y>1 the surface is meaningless as it gives z as a negative ratio.
I want the surface to be plotted only for x+y<1, so something like:
plot3d(78.9*x+49.1*y+15.7*(1-x-y), x = 0 .. 1, y = 0 .. 1, x+y<1)
But I can't find a suitable command.
Thanks in advance,
Tom.
I am stuck with the following problem:
convert(cos(alpha), exp); works fine for me.
Once I have the trigonometric functions in a matrix, it does not work any more:
In the latter line, A keeps the trigonometric functions. Why is this the case? Is there any way to force maple to keep the complex exponentials instead of trigonometric functions?
I am using LinearAlgebra and VectorCalculus.
Best Regards
Wassja
how to calculate the RicciTensor for system of 3 polynomials equations in 3 variables
i find examples using differential expression, how to do for system of polynomial equations
Riemannian metric of constant sectional curvature
expect to test whether metric of constant sectional curvature g(t) = 1 when t tends to infinity or finite T
with(DifferentialGeometry):
with(Tensor):
DGSetup([x,y,z],M);
C1 := Connection();
R1 := CurvatureTensor(C1);
Ric1 := RicciTensor(R1);
sys := Diff(g(t), t) = -2*Ric1;
According to kernelopts(version), I am using Maple 16.02, X86 64 LINUX, Nov 18 2012, Build ID 7888210 , having just updated
Maple 16.
I have a Maple worksheet with some graphs of 10^5 data points. When I export the worksheet to a pdf for inclusion in a LaTeX document (with pdfpages package, this recognizes page breaks), the file is around 100 Mb, much larger than I would like.
It seems that the file is large as a figure in the pdf is not just an image, the pdf seems to contain all of the information necessary to plot each data point individually.
Is there some way to encourage Maple 16 to treat figures as bitmaps (or something similarly much smaller than the original figures) upon exporting a worksheet to a pdf? I'll be happy for any suggestions.
NOTES:
1. This question was originally for Maple 16.00. Updating to 16.02a has not solved the problem.
2. I am suspicious that there is some bug in how Maple 16 exports figures made with "plot" to a pdf file.
When I try various methods of compressing the pdf that I've seen on the web, such as with pdftk 1.44, or ghostscript 8.70 or 9.07,  or pdf2ps followed by ps2pdf ,
error messages are returned. For example using pdftk:
pdftk input.pdf output.pdf
gives
"Done. Input errors, so no output created"
Ok guys, so i have a bunch of datapoints in 3d (x,y,z)
I'm trying to calculate an equation using maple that will express z as a function of x and y.
I've been browesing around for like 2 hours now with no hope. Help?
Is there any command in maple that can show us an assigned varibale how much bytes occupied on memory ?
a:=["just a string", 3.14 , 123 , x/y]
d:=array( 1 .. 2, 1 .. 2, [( 1, 1 ) = ("just a string"), ( 1, 2 ) = (3.14), ( 2, 1 ) = (123), ( 2, 2 ) = (x/y)  ] )
c:=a x^2 + b x + c
b := Matrix(2, 2, {(1, 1) = "just a string", (1, 2) = 3.14, (2, 1) = 123, (2, 2) = x/y})
It should be great for benchmarking !
how to add another line in this template of formula
use the expression template
how to add another line like
thank you in advance for your help
First 1364 1365 1366 1367 1368 1369 1370 Last Page 1366 of 2429
