I'd like to try the new Maple IDE
http://www.maplesoft.com/products/toolboxes/IDE/index.aspx
Maple IDE - Integrated Development Environment
Is there a way to obtain a trial version even for a week just to try it out? I do not want to spend all this money then find out it does not work well.
any one here uses this and can recommend it or comment on how well it works? For example, can one run Maple code directly from it and have the code execute in Maple, or must one load the file manually from the editor into Maple to run it each time they make any changes to the code?
I want to sum over several variables at once.
For example, something like
add(add(add(f(k1,k2,k3),k1=range1),k2=range2),k3=range3);
sums over 3 variables. But this can only be done if I know the number of variables in advance. I want to write a code that will sum over m variables, with m being supplied on demand.
Maple can do this for integrals. If I write
int(f(seq(k[i],i=1..m)),[seq(k[i]=range[i],i=1..m)]);
the integral is computed over m variables, for any m.
How can something like this be implemented for summation?
So suppose in one maple worksheet, I run:
>assume(w, real); y:=2*w;
>save y, "test.m";
And then I open another, and run
>read "test.m";
>subs(w=1,y);
The substitution won't work, while it works if I don't make any assumptions about the variable w.  However, in the piece of code I'm actually running (this snippet is just to illustrate the problem), I need to make the assumption that w is real for solving a system of equations (otherwise maple seems to run out of memory).  Is there a way to save my result y in such a way so that I can make substitutions for w later?
As am trying to solve this integration:
A(c,n,m):=evalf(int(1/(y)*exp(-c*y^(2)),y=n..m))
B(c,n,m):=evalf(int(exp(-c*y^(2)),y=n..m))
C(c,n,m):=evalf(int(y*exp(-c*y^(2)),y=n..m))
d(c,n,m):=evalf(int(y^(2)*exp(-c*y^(2)),y=n..m))
E(c,n,m):=evalf(int(y^(3)*exp(-c*y^(2)),y=n..m))
F0 := exp(beta*s1)*exp(gamma0^2*exp(beta*s1)/(2*gamma1))*A((1/2)*gamma1*exp(beta*s1), gamma0/gamma1,gamma0/gamma1+tau1)/gamma1+exp(beta*s2)*exp(gamma0^2*exp(beta*s2)/(2*gamma1))*A((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1+exp(beta*s3)*exp(gamma0^2*exp(beta*s3)/(2*gamma1))*A((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1
F1 := exp(beta*s1)*exp(gamma0^2*exp(beta*s1)/(2*gamma1))*(gamma0^2*A((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)/gamma1^2-2*gamma0*B((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)/gamma1+C((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1))/gamma1+exp(beta*s2)*exp(gamma0^2*exp(beta*s2)/(2*gamma1))*(gamma0^2*A((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1^2-2*gamma0*B((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1+C((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a))/gamma1+exp(beta*s3)*exp(gamma0^2*exp(beta*s3)/(2*gamma1))*(gamma0^2*A((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1^2-2*gamma0*B((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1+C((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b))/gamma1
F01 := exp(beta*s1)*exp(gamma0^2*exp(beta*s1)/(2*gamma1))*(B((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)-gamma0*A((1/2)*gamma1*exp(beta*s1), gamma0/gamma1, gamma0/gamma1+tau1)/gamma1)/gamma1+exp(beta*s2)*exp(gamma0^2*exp(beta*s2)/(2*gamma1))*(B((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)-gamma0*A((1/2)*gamma1*exp(beta*s2), gamma0/gamma1+a, gamma0/gamma1+tau2-tau1+a)/gamma1)/gamma1+exp(beta*s3)*exp(gamma0^2*exp(beta*s3)/(2*gamma1))*(B((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)-gamma0*A((1/2)*gamma1*exp(beta*s3), gamma0/gamma1+b, gamma0/gamma1+c-tau2+b)/gamma1)/gamma1
`Fβ` := int((s1^2*(gamma0*t+(1/2)*gamma1*t^2)*exp(beta*s1)*(gamma1*t+gamma0)*exp(beta*s1))*exp(-(gamma0*t+(1/2)*gamma1*t^2)*exp(beta*s1)), t = 0 .. tau1)+int((s2^2*(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2)*exp(beta*s2)*(gamma0+gamma1*(a+t-tau1))*exp(beta*s2))*exp(-(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2)*exp(beta*s2)), t = tau1 .. tau2)+int((s3^2*(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)*(gamma0+gamma1*(b+t-tau2))*exp(beta*s3))*exp(-(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)), t = tau2 .. c)+int((s3^2*(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)*(gamma0+gamma1*(b+t-tau2))*exp(beta*s3))*exp(-(gamma0*(b+t-tau2)+(1/2)*gamma1*(b+t-tau2)^2)*exp(beta*s3)), t = c .. infinity)
I need to have tau2 as varibles to get there optimal values ..
Minimize(1/((F0*F1-F01^2)*n^3*`Fβ`), tau2 = 237..273})
But this error keeps coming :
Error, (in Optimization:-NLPSolve) integration range or variable must be specified in the second argument, got HFloat(1.0) = 121.0828419 .. HFloat(193.0828419)
Please Help ..
Every time I type
`Δε`(T, z)
it becomes
T Deltaε z
Is there any way to tell maple to stay what it is as I've typed, just like other function express f(x), etc
Hi all
I have a mathematical problem and I asked it in various sites but the answers till yet are not correct.
Assume that we have:
T[m]:=t->t^m:
b[n,m]:=unapply(piecewise(t>=(n-1)*tj/N and t<n*tj/N, T[m](N*t-(n-1)*tj), 0), t):
where n,N,tj are known constants. furthermore assume that we want to comute the following integral:
for following approximations:
I have written the following code but it seems to be incorrect:
V1:=Vector([seq(seq(b[n,m](t),m=0..1),n=1..3)]);
V:=evalf(V1.Transpose(V1));
the original program is :
taaylor.mws
I will be so grateful if any one can help me to solve it by maple
Mahmood   Dadkhah
Ph.D Candidate
Hi all.
After installation of the MSK, there is no desktop icon, and there is nothing to click in the start menu to launch it. I have to click on the executable in the Maple folder on the hard drive. It then launches Maple 18 first, and opens up some tabs related to the Survival Kit.
How can I open the MSK up from within Maple, without having to search for the executable first on the hard drive?
Hi all
I am trying to maximize a function f(x,y,z,w) in terms of x. (Only x is treated as a variable, and the others are treated as parameters).
However, all I know is that y,z,w they are parameters and they are non-negative. I have already tried with the "optmization help page" from maplesoft's website, and it looks like it will search the range of x,y,z,w, and it will return numerical values at which this function is maximized.
However, what I want is instead a close-form solution of x=g(y,z,w) that will maximize the function.   In other words, I would like to keep the parameter in symbolic forms.
Can Maple do that?
k:=1;
sum(k^2,k=1..10);
      (in sum) summation variable previously assigned, second argument
gives an error, since k is not free. Fine. No problem. But add() has no problem with an assigned variable:
k:=1;
add(k^2,k=1..10);
and seq() has no problem either
k:=1;
seq(k^2,k=1..10);
It is confusing when learning Maple since it does not seem to behave the same way in all its functions. What is the reason for this design?
I have 3 column vectors:
phi contains the number of radians from the North Pole
theta contains the number of radians from the Greenwich meridian
D contains number data corresponding to the point (phi,theta) on the sphere.
How do I plot:
a) a contour plot on the surface of the sphere where each point at (phi, theta) has a corresponding data value D?
b) a plot where the height above the surface at (phi, theta) is some linear function of D such as radius*D*constant?
On page 32 (PDF)
Two different results were obtained using the Global optimization.
Log likelihood does not differ much. BUT the estimates vary a lot, such as mu[p].
tmp.mw
tmp.pdf
When I tried to use one of the answer from a particular run, I get the HFLOATING error, see picture.
So how reliable is this? Could there be a better way to optimize this ?
As an additional note, if I have Matlab R2014a, could I use Matlab to optimize the target function? DO I need to purchase a seperate addon?
I have a Matrix of data points I am plotting using plots:-listdensityplot. That works fine.
However, the axes are labeled by row and column number of the Matrix (e.g. 1..20 or whatever). In reality, these are of course some parameters the range of which has been mapped onto the rows and columns of the Matrix.
How can I display the axes using the values of the original parameters? I know the transformation from Matrix row or column to the actual parameters (and in this case it is linear).
TIA,
Mac Dude
Hi experts,
the standard resolution for maple contourplots is 72 dpi wich is not suitable for publication purposes. I need at least a resolution between 500 - 1000 dpi. How do I get better resolutions for my contourplots when exporting them to .bmp or .jpg-files?
Somebody any ideas?
Consider the differential equation   d/dx y(x)=2*y(x)*(y(x)-4), on the rectangle -1 < x < 1, -2 < y < 7.40 in the xy-plane.
(a) Use DEplot to plot the direction field for the differential equation on the given domain. Assign your answer to my_plot_1.
restart: with(DEtools):
DEexp1:=2*y(x)*(y(x)-4);
DE:=Diff(y(x),x)=DEexp1;
DEplot(DE, y(x), x=-1..1, y=-2..7.4);
Error, (in DEtools/DEplot/CheckDE) derivatives must be given explicitly
Thanks for your help!
Level: Idiot (Me)
I have a matrix of 3 columns and lots of rows M
  • First column is latitude in degrees
  • Second column is longitude in degrees
  • Third column is data
So I set lambda:=M(..,1) and phi_g:=M(..,2) giving me two column vectors.
I want to convert lambda and phi_g to polar coordinates theta and phi
theta:=90-lambda produces "Error, (in rtable/Sum) invalid arguments"
WHY?
I also want to convert phi_g to phi where phi=phi_g when phi_g is 0...180 and phi=phi_g +360 when phi_g <0
How do I create a conditional function like this?
First 1401 1402 1403 1404 1405 1406 1407 Last Page 1403 of 2429
